Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
Brush bar on my dyson dc07 will not turn.
The unit itself seems to be running just fin
  • Anonymous Jan 04, 2009
    I have the same problem the brush will not turn and there appears to be no suction.
  • Anonymous Jan 12, 2009
    Yup - same problem - vacuum runs fine but no suction thru the bottom, only thru the hose. Brushes not turning
  • 372 Answers
Hi.
Your Dc07 may have A clutch unit.
Check that when you pull back handle to vacuum that the clutch control knob which is located front lower left side of machine moves to drive position & is not stuck in off or park position.
Rotate it to drive if its at off or park when you have lowered handle.
If adter checking this you still have no brush rotation you will need to remove clutch unit to either replace thr belts or fit new clutch.
Try this site for further help http://dysonmanuals.llc.nu/
If you dont have the clutch arangement then just turn the three plastic screws on the sole plate ( Under front of machine) to unlock pull off sole plate & fit new belt to brush roller.
Easy job to do.
Posted on Jan 11, 2009
Make brushes turn - band is intact but not turning the brushes
Hi there, it's Jack at Dyson.
Are you able to confirm whether your DC07 includes the brush control feature or not? The brush control would be a round dial on the cleaner head which allows you to turn off the brush bar when cleaning hard floors or delicate rugs.
If your DC07 does include brush control, make sure that when the vacuum cleaner is turned on and reclined, the brush control is set to 'Carpets'. The brush bar will never rotate when the brush control is set to 'Hard floors', or when the machine is standing in the upright position.
If you're confident your machine is already set correctly but the brush bar is still not rotating, or if your DC07 is a version which doesn't include the brush control feature, we'd appreciate the opportunity to provide further assistance.
I'd encourage you to give the Dyson Customer Helpline a call when you have your DC07 easily to hand so we can take you though some simple troubleshooting checks. You can reach us by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Mar 03, 2015 | Dyson DC07 Bagless Upright Cyclonic Vacuum
How to change belt in dyson upright model dc07
There are two versions of DC07 - some include a brush bar which rotates all the time when the vacuum is running. And some include a brush control clutch mechanism which allows you to turn off the brush bar for hard floor cleaning. If your machine has the brush control, you'll see the dial on the front of the cleaner head.
If you have a DC07 without the brush control feature, you can replace the belt as shown in our online Support guide: http://www.dyson.co.uk/support/dc07/dc07-standard/maintaining-your-dyson-machine/change-the-belt1/belt-fitting-preparation
However, if you have a DC07 with the brush control feature, the clutch mechanism uses belts engineered to last the lifetime of the machine in normal use. These are not designed to be replaced by the user, and we would advise against attempting to change these as damage may be caused to your machine.
For further advice on having your machine repaired, or to order replacement belts for a DC07 without brush control, please contact our experts directly. You can reach us by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Sep 30, 2014 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Cleaner not picking up
Hi Barbara, it's Jack at Dyson.
I'm sorry to hear the brush bar in your machine isn't rotating. Please make sure that the brush control on the cleaner head is set to 'Carpets' rather than 'Hard floors', as the brush bar will not rotate when the machine is set to the Hard floors position.
Please note, the brush bar will never rotate when the machine is standing upright, so make sure it's reclined into the normal vacuuming position before testing it. You might find our online Support guide useful when troubleshooting:
http://www.dyson.com/support/dc07/dc07-animalus/diagnosis-root-menu/flo-dc07-gen-i-can-see-something-wrong-visual/i-can-see-something-wrong-visual/redirect-to-flo-dc07-clutch-does-the-brushbar-turn-with-the-power-on/flo-dc07-clutch-does-the-brushbar-turn-with-the-power-on
If you're still concerned about your machine after you've given this a try, please get in touch with us directly so our experts can provide some further advice. You can reach us on 0800 298 0298 (UK), 1-866-693-9766 (US), or 1-877-397-6622 (CA).
Best wishes,
Jack
Dyson Online Customer Support
www.dyson.com
Nov 17, 2013 | Dyson DC07 Animal Bagless Upright Cyclonic...
DC07 grinding noise
I had the same problem with mine, I took it to a repair shop. The problem is where the belt passes through from the brush and goes inside the machine. Move the belt over a bit and you will see that a plastic guide has been bent over and is pressing onto the brush, which causes the noise. Just bend it straight again and it stops.
Apr 21, 2012 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Replace brush bar on dyson dc07
Replacing the brush bar on a DC07 is quite straight forward and how to do it should be shown in the user manual.
If you dont have the manual, or if it isnt covered, have a look at www.dysonmedic.com which has some great info on your machine.
Mar 03, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Hi my dyson dc07 animal has suction but the brush bar wont turn. If I turn it on there is a horrible noise. The belt is still fine
The belt is probably worn or stretched. When this happens the belt won't turn the roller brush when it is against the carpet. Here is a link for the manual and links for the belt you need:
DC07 Manual
Replacement belts for DC07 w/ clutch system
Replacement belts for DC07 w/out clutch system
Nov 12, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
The vacumn is running but the beater brush is not turning.
This is from the Dyson website. It gives step by step guide for replacing belt and or beater bar.
http://www.dysonmedic.com/DC07%20Folder/DC07%20Belt%20&%20Brushbar%20change.html
Good luck.
Aug 10, 2009 | Dyson Vacuums
Belt not turning
It could well be the dog hair. You'll need to remove the roller brush and completely clean it off with the hair which sounds like it has wrapped itself around the brush and the brush end washers. Check that the entire roller brush is completely clear and if any dirt is found at the sides, remove it.
Mar 17, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
687 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
