Question about SanDisk Sansa Clip MP3 Player
Sansa 2gb clip
When i plug it all it does is show a pic of the player and the pc with arrows saying its connected and writing but it wont do anything else the battery is so dead I cant turn it on what do i do Thanks!
  • 8,596 Answers
While the player is connected to the computer, you will not be able to go through the menu, play music, etc. Only after you have disconnected it from the PC will it work.
-Tha Mp3 Doctor
Posted on Jan 01, 2009
Sansa Clip 2gb not showing songs
Go to this guys tip it is a good tip on your problem, Fixya will not let me copy and paste, it so here is the link. Solve your MP3 Player Connection Problem.
Jan 25, 2010 | SanDisk Sansa Clip MP3 Player
Sansa clip will not turn on.
hey dude something is lose inside it has no connection to the battery but the actual port that you plug your pc in does ... myn is also like that and iv had it for a year now,,,,
Jul 09, 2009 | SanDisk Sansa Clip MP3 Player
My sansa clip 2gb is not working
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Mar 25, 2009 | SanDisk Sansa Clip MP3 Player
Sandisk Sansa Clip 2GB not detected by XP SP2
Change the USB Mode to auto-detect and see if you get better results. If that fails, switch entirely to MTP mode.
-Tha Mp3 Doctor
Feb 20, 2009 | SanDisk Sansa Clip MP3 Player
When i plug my sansa clip in the usb it wont pop up.
change the cable then check , or check in some different system
Nov 27, 2008 | SanDisk Sansa Clip MP3 Player
Sansa Clip 2GB...WMP11 will recognize, but will not list in device pane in Sync mode...
Hah, figured it out! Had to roll back my version of WMP, which can simply be done by (in XP) going to Start > Control Panel > Add Remove Programs, and then click on WMP11 in the program list. Click remove, and it will ask if you want to roll back to the previous version of Windows. Click yes, and it will roll it back to the previous version of WMP11. Now, assuming you have an active internet connection, after you restart your computer, it will ask if you want to update your WMP. Click yes, and it will re-install the version you started out with, replacing drivers, .dlls, and anything you were missing before hand. Long story short, the solution was patching the holes in the program. I can now plug my Sansa Clip 2GB into the USB port, and WMP will recognize it right away (I can almost hear a small voice from inside my computer saying "would you like tea with that, mr. guy?" hah). I also found out you can have more than one media player connected at the same time! How cool is that? Great if you're trying to set up multiple players with the same playlists (promotional type stuff, business type stuff, etc.).
Aug 06, 2008 | SanDisk Sansa Clip MP3 Player
Sansa Clip Mp3 Player
format it
by connecting to computer
Jun 11, 2008 | SanDisk Sansa Clip MP3 Player
Sansa clip mp3 player 2GB shows as UNKNOWN DEVICE when i connect
Sandisk website will have it, and will have the vista compatible software:
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
here is the link for the sansa updater.
Ok...here is something you might want to do....I know you already formatted your device a zillion times already but please do it one more time using the Format option under Settings menu in your device....then restart your computer....then plug in your computer again after restarting to see if it recognizes now.....if not...here is one thing you could do....go to this link
http://www.nirsoft.net/utils/usb_devices_view.html
download the USBDeView software and see if the registry has the player in there....select it and delete it and then plug in your PC again to see if it will re-register the device and works...hope this will help.
May 29, 2008 | SanDisk Sansa Clip MP3 Player
Plugging in and out Sansa
Well I'd suggest that you uninstall it from your computer then reinstall it. This is a common solution to most problems similar to this.
Feb 01, 2008 | SanDisk Sansa m240 MP3 Player
Sansa e260R
yup mine does that but mine is a coby 2gb mp4
Nov 13, 2007 | Audio Players & Recorders
SanDisk Sansa Clip MP3 Player Logo
87 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
