I cannot get the red convergence to work - Televison & Video
  • 10,594 Answers
Let me know model and brand of tv to see tech info.
Posted on Dec 29, 2008
Horizontal red convergence jumps out after 10 seconds
This could be a transistor fault on the convergence board. You can diagnose with a can of freeze spray.
Freeze Spray works because of the way silicon chips such as transistors fail. If they are intermittent, then they'll work okay when cold. But as they heat up they'll flip to a failed status. A quick blast with Freeze Spay cools the component quickly enough to revert it back to its working status for a few seconds. That's long enough with a fault like yours to see the convergence flick back to good.
You'll have to work out for yourself where the convergence board is though.
Sep 11, 2014 | Office Equipment & Supplies
I have a toshiba tv model tp50g90 I have replaced the convergence chips stk392-110 convergence was corrected but I have a problem yet red not managed to focus on the user menu in the option of...
Thats the way it works. You have to adjust the other colors to the red. You adjust the red from the back of the set using the convergence magnets on the tubes. Then you adjust the other colors to match the red. It's much easier if you have the plastic screen from Toshiba used to align this set.
Feb 20, 2011 | Toshiba TP50G90 50" Rear Projection...
Blue will not focus causing "shadows". Magic focus will not solve the problem.
This tv have a problems call convergence,it dead.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts must be replaced to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Jun 17, 2010 | Hitachi 53FDX20B 53" Rear Projection...
My picture has red ghosting. I tried to perform
This set has a bad convergence amp ic. This can be a complicated repair involving in depth convergence adjustment. You may be better off having a shop check it out for you. Thanks for using fixya.
Dec 12, 2009 | Philips 55PP9401 55" Rear Projection...
Blue convergence wont work
This is a common problem. Your convergence has gone out.
Common symptoms are...
1) 3D Video
2) Warped Video
3) Convergence menu does not adjust the red or blue correctly. 4) TV Chirps
Go here for a solution...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Sep 05, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Red screen(rear projector tv)
Most likely bad convergence amplifiers. They are soldered in components.They can become intimentent and the lines come and go, usually red or blue.
May 14, 2009 | Televison & Video
Remote will not adjust red convergence/multi-point horizontally
check resistors around convergence i.c.(red) philips may use 2 resistors in parallell. should be about 1.8 ohms. assuming you already changed the i.c.
Jan 17, 2009 | Philips 55PP9352 55" Projection Television
Mitsubishi VS50805 Serial # 102718 No red in picture
Replace the convergence ICs your model uses two STK392-040 Convergence ICs. You can get replacements at the following link with instructions.
http://servicemanuals.vstore.ca/
Dec 28, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Red convergence wont move
if the red line is blurry and you have adjusted the screen focus control and does not work then you prob have a bad red CRT or bad red CRT fluid.........
convergence STK have nothing to do with the red being blurry
Dec 09, 2007 | Mitsubishi WS-55809 55" Rear Projection...
CONVERGENCE
http://www.digitalhome.ca/forum/showthread.php?t=21847
convergence ic bad
Dec 03, 2007 | RCA P46812BL 46" Rear Projection...
Televison & Video Logo
14 people viewed this question
Top Televison & Video Experts
Electro Med Services...
