Question about Maytag EPIC MFW9700S Front Load Washer
To soften or not to soften
The rep for my new epic z told me not to use fabric softener as it will clog up the machine. True?
KLT
  • Maytag Master
  • 744 Answers
To clean this maytag This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Jul 30, 2013
  • Maytag Master
  • 3,463 Answers
It should not cause a problem if you use the correct amount, and wash the conditioner compartment out each time you have finished a wash.
It is any conditioner that is left that can solidfy,and cause eventual blockage.
Plz rate my solution.
Thanks.
Posted on Dec 29, 2008
Front loader. Why doesn't fabric softener dispenser empty?
It can be two things. First, what is left in the dispenser? If its the fabric softener, then the water valve may be faulty. The water valve will have multiple feeds and the fabric softener might be bad. If its a combination of water and softener, then the dispenser might be clogged. You can remove the slide out tray and clean it. Look for build up of fabric softener that might be there. Good Luck?
Nov 23, 2015 | Frigidaire Washing Machines
Malber WD1000. Why is there always water in the fabric softener dispenser?
Washing machines are designed to flush the softener dispenser to prevent residue from clogging it ahead of the next wash cycle. The dispenser in your machine may have gotten clogged anyway. You may find that the problem comes and goes at the whim of the machines control logic.
Oct 03, 2015 | Washing Machines
Fabric softener leaking from bottom of washing machine
One possible cause.
Someone is pouring fabric softener in the washer's Bleach bezel.
Causing the bezel to become clogged and then overflow.
Apr 02, 2014 | Whirlpool Ultimate Care II LSQ9549L Top...
The fabric softener dispenser does not drain. I have diluted the softener with warm water every time, still the fabric softener will not drain out. In the spin cycle the softener is thrown around the top...
The softener dispenser is supposed to get flushed during the cycle to prevent clogging. The flushing may not be happening in your machine and some residue could be clogging the discharge.
Nov 12, 2017 | Maytag Centennial 3.2 cu. ft. SuperSize...
Where do I put in liquid fabric softener?
behind the soap dispenser is another spot for softener
May 24, 2010 | Maytag EPIC MFW9700S Front Load Washer
Fabric softener doesn't empty during wash. I use he softener, and don't overfill the basin. The washing machine completes the cycle, but the softener doesn't empty.
my son had this same problem and when we took the dispenser out and checked the hoses they were clogged with semi hardened fabric softener that didn't pass through. they always used a warm wash with a cold rinse and since i told them to use a hot water wash with a cold rinse at least once a month they have not had a problem. hope this helps.
Oct 14, 2009 | Frigidaire Affinity ATF7000ES Front Load...
The dispenser for fabric softener overflows all the time and does not go down.
Its clogged ... probably ... I have had success putting hot water down the hole ... but expect lots of spillage before it clears.
Oct 10, 2009 | GE WSXH208A Front Load Washer
Clogged fabric Softener
I had the same issue, and ran vinegar through the fabric dispenser with a load of towels. Not only did it solve the 'sour towel' problem I had with that load, it also cleared my fabric softener section. Now, I water down all fabric softner when I use it, which is less frequently!
~Steph
Nov 11, 2008 | GE Energy Star WCVH6260F Front Load Washer
My front loader Bosch washing machine is not draining in the fabric softener section.
Make sure it is the fabric softener that is not being added. Try running w/o fabric softener and see if the tray is still full. The reason I am asking is that after I run my washer the fabric softener tray is full, with water, not softener. The factory tells me it is because the water fill nozzles have realigned and overspray into the softener tray. Not a big problem, since my system is under warranty I am having them fix the nozzles and then I will know how to redirect.
If it is the softener that is not being added then check to make sure the line is not clogged. You can lift out the bleach / softener try and check for cloggs.
Aug 18, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Maytag EPIC MFW9700S Front Load Washer Logo
66 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
