Question about Mitsubishi VS-50607 50" Rear Projection Television
My Mitsubishi VS-60707 Problem...Need Help!
My Projection TV has lines running horizontally but roll vertically. When it first started, It would do it on startup for about 10 to 20 mins. then flip to an great picture. I can see the picture faily good behind the lines. Very Annoying!!!! I have heard there are problems with the PiP board. If anyone that has had this problem, please post any feedback. Thanks in advance for any help on this. Rino
  • 2 more comments
  • hsorkhabi Oct 10, 2008
    Sometimes I have great audio but I do not have the picture.
    We turn off the TV, picture comes back after 1/2 Hr again.
    Thank you
  • thakandahs Oct 18, 2008
    have lines on top of picture and bottom black lines that r horizontzail
  • arindee Dec 08, 2008
    I have a mitsubishi vs-50607 has 3 bands of horizontal lines but rolls verticle can anyone help
  • Anonymous Apr 11, 2009
    I am having the same problem as well, It would roll at first for just a few minutes at start up but know it does it continuously. It is so annoying that I thought about rolling it out to the curb.
    Novelist:
  • 192 Answers
There are two common problems with this set that cause the symptoms you described. Both of them are caused by capacitors: CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01. CHECK C2P08 100 UFD 16 V OFF PIN 3 OF IC2P03. They are located on the signal PCB. Both capacitors are inexpensive and will more than likely solve your problem. Hope this helps.
Posted on Apr 29, 2007
Vs-45607 was a hand me down and did not come with a remote. the picture has very fast rolling vertical lines........Help!
Typically you can open the back case and you will see two screws, one for vertical scroll and one for horizontal scroll. with a rubber head flat head you can adjust this. Please be advised this is very dangerous and has high voltage. Please get a tech to look at this, he must be familiar with this TV.
Sep 03, 2009 | Mitsubishi VS-50607 50" Rear Projection...
Picture rolling horizontally and vertically
tv needs repair c2c52 and c2po5 need to remove .both should be on the signal pcb
Nov 16, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi VS-6071 60" Rear Projection TV Problem
can you give me the number of the manufacture of a 60in mitsubishi VS-60707
Oct 25, 2008 | Mitsubishi VS-60707 60" Rear Projection...
Mitsubishi rear projection tv problems
this problem is going to be several bad capacitors on the signal board inside your tv. i suggest calling a technician
Feb 16, 2008 | Mitsubishi VS-60707 60" Rear Projection...
Horizontal lines
Sounds like you need a service call to check your convergence amps. This is not a repair you should attemp on your own. More parts are probably defective than just the amps. Fuse and resistors in the amps circuit.
Dec 27, 2007 | Mitsubishi VS-60707 60" Rear Projection...
Had horizontal Lines replaced now have error 21 xray circuit
White horizontal line (no vertical deflection)
Check / replace R548, R549
Sound but no picture except for a couple of horizontal colour lines
Replaced the frame chip TDA8356, set now ok
Severe vertical jitter on picture, horizontal sides of picture ragged
Replacing the TDA4950 cured the fault
White line down centre of screen (top to bottom}
Replace C805
Nov 24, 2007 | Mitsubishi VS-60707 60" Rear Projection...
Mitsubishi VS-60707 60 in. Rear Projection Television
When it gets better after warm up it can be a capacitor in the 160 Volt high voltage circuit or a cold solder joint. these 2 thinks would be my best guess on this set.
Oct 26, 2007 | Mitsubishi VS-60707 60" Rear Projection...
Horizontal lines and screen bounce
You have some leaky filter caps - C2C52 = 10MFD 50 VOLT (off base of Q2C51 on signal board) also check C2P05 = 100 MFD 16 VOLT off pin #3 of IC2P01 and C2P08,C2P03 = 100 MFD 16 VOLT
Aug 22, 2007 | Mitsubishi VS-60707 60" Rear Projection...
Mitsubishi VS-60707
Have same problem on 42in. Problem appears to be a short on one of the boards. If hold the cable input connection and give it a jiggle, it will usually pop in.
May 05, 2007 | Mitsubishi VS-60707 60" Rear Projection...
Mitsubishi VS-50607 50" Rear Projection Television Logo
1,233 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
