Question about Kenmore 40494 / 40495 / 40499 Electric Single Oven
My kenmore oven/stove is showing F4 what is this
  • ammar148 Jan 01, 2009
    the stove beep and f 11 appears, can you help me to stop it?
  • 1,959 Answers
F4 indicates the oven temperature sensor is bad. Not knowing the exact model you have I can't give you an exact price but I've always used http://www.appliance-parts-warehouse.com/ for my parts but you're free to shop elsewhere if you plan to make the repair yourself. The part isn't very expensive and is fairly easy to install yourself.
Posted on Apr 19, 2009
M# 911 4288816 s# OV609596Q showing a F-4 code...what does this mean?
F4 is an error code that flashes on Kenmore electric ovens when the oven's temperature sensor has shorted. You should check the wiring harness and replace the sensor if necessary.
Hope helps.
Rea
Jun 08, 2011 | Kenmore 41389 Electric Double Oven
Kemore Mod# 911 4298814 Ser# 9762371 it is giving me a code F1 what is the proplem&
911= Roper stove made by whirlpool
F0 Defective ERC Replace ERC (ERC electronic range control; that expensive stove electronic control)
F1 Defective ERC Replace ERC
F2 Oven over heat Replace defective Sensor
F3 Oven Sensor Open Check/Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Defective ERC Replace ERC
F6 Problem with time keeping circuit Reset Time or cooking operation and check for proper ground
F7 Shorted or sticking button Clean button or replace ERC
F8 Defective ERC Replace ERC
F9 Door Latch Error Check latch and latch circuit
Jan 24, 2011 | Kenmore Ovens
F4 comes up on my stove, keeps beeping what to do
Sorry to say you will need an engineer to check the heat sensors as they may be faulty
Sep 21, 2009 | GE Ovens
Getting F4 error
I dislike new electronically contolled ovens so much. Electronics are never meant to be near temperatures reaching more then 200 degress.
F3 or F4 Open or shorted oven temperature sensor Replace oven temperature sensor
Aug 01, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
Older Ge F4 error Code
Your oven temperature sensor is bad and must be replaced.
Feb 28, 2009 | GE JTP85 Electric Double Oven
Oven comes on then beeps and a code F4 comes on
how do I solve a F4 problem in the Decor electric stove?
Feb 02, 2009 | Ovens
Stove-top works, oven showing all 888888 across the screen
You're stove must be perfectly fine, but the thing displaying all those options may have a problem. Try to get this fixed as soon as possible.
Jan 31, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore model # 911-494-79790
F6 Problem with time keeping circuit Reset Time or cooking operation and check for proper ground.
May 11, 2008 | Kenmore 30169 Electric Single Oven
G.e electic profile slide in oven
All three codes, very odd, f3 f4 pertain to oven sensor short, or connection issue, f5 also asks to check resistance of sensor , so id try replacing oven sensor. sort probe located on top left or right side of oven cavity, 2 screws hold it place(sometimes youget lucky and will remove from front, if not you need to remove back panel and unplug and replug new sensor.cost for part can be $40-100, depending ion model
Feb 24, 2008 | Ovens
Kenmore 40494 / 40495 / 40499 Electric Single Oven Logo
109 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
