Question about Koss KS2503 System
DVD does not work..
When I press "standby" and "start", I get a "Message 04" in the display area. It immediately goes back to "standby". It goes off so quickly that it keeps the loading door from opening and the tray selector from working. Do you know what "Message 04" is? I didn't know if my dvd player can be repaired or if I should just purchase another one. Thanks for any help or advise. Cindy
SOURCE: Koss KS2503 "MSG 04" problem
I had this MSG 04 problem. Opened the player up. Messed around. Figured out that the 5-disc tray was hanging up a little during the initialization. The issue is that the tray screws into and rotates around a stand-up beam. On the underside of the tray are gear teeth which are spun by a gear on the main unit underneath. The real culprit is the stand-up beam in the very middle. It is too long. The fix is to first try just tightening the middle black screw holding the tray onto the stand-up beam. If this tightens and MSG 04 goes away, you're done. If it does not tighten at all or much at all, then remove the screw (actually a bolt) and using a razor or sharp blade, scrape the top 1/4 millimeter off the stand-up beam. Apply some grease around the beam and on top. Note, you may have to remove the tray to do all this. If so, that is the most tricky part. Carefully lift on the tray on the front side as you rotate it. Try to free a disc circle edge over the top of the front DVD cover and free the tray. To re-set the tray, put it on the stand up beam with the front side of the tray slanted up and slowly rotate while setting it in and down. After re-seating the tray, screw the bolt down but do not tighten all the way. Tighten it enough to allow rotation and enough to rid the msg 04 problem. I shaved my stand-up beam and have never seen a MSG 04 since.
Posted on Jul 16, 2006
  • 14 Answers
SOURCE: I have a Koss KS4102 Non working dvd
yes it does
Posted on Dec 05, 2007
  • 38 Answers
SOURCE: cd tray won't open
It is Koss brand,you shouldn't expect much from it. You could have an A/V repair guy to fix it for you or buy a better brand like panasonic,denon, or even samsung.
Posted on Feb 04, 2008
SOURCE: DVD Tray stock closed Koss ks 2503
See if you can acquire the software upgrade that Koss engineers devised to solve the problem, I did have one(the upgrade) but misplaced the disc, if you manage to obtain it please e-mail me.
Art.
Posted on Jun 08, 2008
SOURCE: Door keeps opening and closing on the DVD player.
Does the dvd player gets a belt downside the tray change it
Posted on Aug 08, 2009
E7 error message Singer Patchwork
I used can air and blew out the reverse button area. Worked immediately after turning off and back on.
Mar 23, 2014 | Singer 7258 Sewing Machine
The "L ch" message is
To cancel child lock in DVP-SR200P dvd player, press power button to turn unit Off (standby mode) then press Return, Enter and Power buttons on remote.
This will cancel child lock in dvd player.
Hope this info will help you.
Thanks.
Nov 03, 2010 | Sony DVP-SR200P DVD Player
Panasonic DMR-EZ47V DVD Recorder / VCR Combo RC1 errior message how do I fix this problem
http://www2.panasonic.com/consumer-electronics/support/Video/DVD-Recorders-Players/DVD-Recorders/model.DMR-EZ47VK
http://www.retrevo.com/support/Panasonic-DMR-EZ47-DVD-Players-manual/id/2811ag420/t/2/
To get into Service Mode, first put the machine in STANDBY mode, then press the buttons ChUp OPEN/CLOSE and REC all at the same time on the front panel (Ch Up is hidden inside the AV3 input flap). Eventually the front panel display will show "SERV" (after its "HELLO" messages). Anyway, pressing [6] then [5] on the Remote Control tells me that I have an Error Code of "04" which is a Digital PCB or Communication Error (whereas an Error code of "02" means a "Defect of RAM drive"). (To exit from Service Mode, press [0] then [0] which should get you back to "SERV" and then POWER-OFF the machine).
Hopefully, your manual will display your error codes.
Perhaps the remote control is not set to the same control code as your DMR-ES40V. Codes may be set to 1, 2, or 3 on the remote by holding down the enter button and one of those number buttons for several seconds at the same time. The factory default is code 1. Try 1 first. If that doesn't work try 2. If that doesn't work try 3. If one of those codes doesn't work you may have a bad remote or a bad sensor on your machine. On DMR-ES35V models the sensor is located just to the right of center behind the black window
Jun 23, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
Receiver display started scrolling fast through set-up options on it's own and then stopped scrolling with "V1 PLX Movie" in the display and none of the front panel buttons including the power switch have...
Try this, but you'll lose any presets and setups.
To reset the AV receiver to its factory defaults, turn
it on and, while holding down the [VIDEO 1] button,
press the [STANDBY/ON] button. “Clear” will
appear on the display and the AV receiver will enter
Standby mode.
Jun 09, 2010 | Onkyo HT-S790 Home Theater System System
Message unknow disc
hello,
you can try this
This hack enables VCD playback
Power on the player with no disk in the drive
Press "PAUSE" on the remote
Enter "1472" on the remote
Press the UP arrow three times
Press "PROGRAM", "5", "PROGRAM", "5" (the characters 04 EE should now be displayed)
Press "ENTER" (the display should flash briefly)
Press "RETURN"
Power the player off and then back on
Thank you
Dec 05, 2009 | Zenith XBR716
Cyberhome dvd 1600
unplug the unit and wait 5 minutes and plug it back in. See if that helps
Oct 21, 2008 | Cyberhome DVR 1600 DVD Recorder
Stuck on Standby
Do a hard reset. Unplug it from the socket, the DVD and leave disconnected for 4 hours. This may or may not help, but it is a necessary step to restore all internal software codes to their factory settings.
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Aug 28, 2008 | JVC XV-523 DVD Player
Thomson DTI6300-16 digital TV recorder frozen, red light on constantly, no resposnse to any commands. I think it needs a factory reset - how do I do this?
Try Resetting the box to its factory setting:
  • Menu > Setup > Help
  • Then press the Green Button (Even though it doesn't show as an option)
  • Then press the Red button for a full reset
Warning: You will lose all data on the Hard Disk!
I did this when mine wouldn't record anything and dumped all my pre-recorded programs.
Worked a treat.
Jul 20, 2008 | Televison & Video
Error message when reading DVD
Try changing the region setting to region free.
1. Make sure there is no Disc in the tray.
2. Shut off the unit and unplug it from the AC outlet.
3. Press and Hold the "Play" and "Open/Close" keys,
simultaneously on the player and not the remote control.
4. While holding these keys, plug the AC cord back into the outlet. (TEST and CPU ver# will appear on the display)
5. Release the "Play" and "Open/Close" keys.
6. Press DVD Menu twice on the remote.
7. When the display reads s000 5858 use the up and down buttons to change the 000 to 02E.
8. Using the Left and Right arrow buttons, change the last four digits until they read 0000 for Region Free, 0101 for Region 1, 0202 for Region 2 or 0404 for Region 4.
9. Press Enter on the player.
10. Press Standby and wait 5 seconds.
11. Press Standby again. Your player is now set to the region you requested. If you find some titles do not play on the region 0 setting, you may have to hard select the appropriate region.
Good Luck. Let me know if it works
Jan 09, 2008 | JVC XV-S300 DVD Player
XV-N322 - Lock will not unlock
My problem was fixed by...having the DVD powered off, holding down the stop button on the player and hitting the power button on the remote.
Good luck!!
Jan 22, 2006 | JVC XV-N320 DVD Player
Koss KS2503 System Logo
21 people viewed this question
Top Koss Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
Steven Wander
Steven Wander
Steve K
Are you a Koss Audio Player and Recorder Expert? Answer questions, earn points and help others
