Question about NetGear WGR614 Wireless Router
Hi, I am trying to connect my xbox360 to my netgear router, after i insert the network key it doesnt do anything and wont connect, are there any specific known settings i need to change on the router?
  • eecom May 11, 2010
    Hi ... when you say it doesn't do anything - am I right in thinking no message appears, such as 'Windows Can't Connect' ? It just doesn't connect?
    In the meantime, try a look at the router's MAC filtering settings, also called Wireless Card Access Control.
    Login to the router (with a wired connection), and go to Advanced > Wireless settings > and click the 'Setup' button next to Wireless Card Access list. If 'Access Control' is enabled, you can either disable it, or add your Xbox MAC address to the list.
    If this is not the problem, ensure there are no devices which could interfere with the wireless signal nearby - such as a DECT phone, or wireless speakers.
    If this doesn't help, please come back to Fixya
  • 854 Answers
A. Determine the IP Address and MAC Address of the Xbox. Note: You may find the IP address and MAC address of your Xbox on your Dashboard's Network Settings. Please refer to your Xbox manual for more information on this. B. Reserve the IP address. 1. Please open any web browser like Internet Explorer or Netscape Navigator. 2. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key. 3. For security reasons, the router has its own user name and password. When prompted, enter admin for the User name and password for the Password, both in lower case letters. Note: If it does not take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you cannot remember the password, you need to reset the router and run the Setup CD to reconfigure it. 4. When the setup page opens, click on LAN IP Setup under Advanced tab. 5. Click on Add under Address Reservation. 6. Under Address Reservation window, please select the radio button of the computer you wish to add from the Address Reservation Table. 7. If the computer you want is not on the list, please click on the Refresh button to update the table. 8. If the computer is still not on the Address Reservation Table, please type in the IP Address, MAC Address, and Device Name of the computer you wish to add. 9. Click the Add button when done. C. Forward the ports. 1. Click on the option with the name Port Forwarding/Port Triggering under the Advanced. For older firmware version, click on Port Triggering tab or just click Port Forwarding on Please select the service type. 2. Click Add and another window will pop up. 3. Type Xbox for Name. Set the radio button to Enable. 4. On Outgoing Port Range, set the Start Port and End Port to 3074. 5. On Incoming Port Range, you also have to indicate 3074 for Start Port and End Port. Save the settings by clicking on Apply. 6. Please repeat steps b to e and indicate 88 for Start Port and End Port. Then change the Name to Xbox2. Note: If it still does not work, you may try these other options: D. Lower down the MTU. 1. Access the Setup page of the router (refer to Step 2 above). 2. Click on the WAN Setup under Advanced tab. 3. Lower down the MTU size to 1492, 1400, 1358 or 1300. 4. Click on the Apply button. E. Enable UPnP. 1. Go to UPnP tab of the router. 2. Enable UPnP and then save the settings by clicking on Apply. Some websites and devices require UPnP or Universal Plug and Play. Just make sure that it is enabled on the router. F. Upgrade the firmware. Note: Follow the steps below if the above troubleshooting still do not allow Xbox to connect using the router. 1. Please verify the router version and model either underneath or at its side panel. 2. Go to http://kbserver.NETGEAR.com/downloads_support.asp and please select the model of the router. 3. Click the appropriate version of the router. 4. Select the link of the latest firmware. Click the button Right-click and Save to Download. Save the file to the Desktop. Note: Please perform firmware upgrade with Wired or Ethernet connection only. 5. Before upgrading, please write down all current settings since you need to enter them manually. 6. Using the computer hardwired on the router, please launch Internet Explorer and access the Setup page of the router (refer to Step 2). 7. Click on Maintenance and then Router Upgrade. 8. Click on Browse and locate the upgraded file in your Desktop. Then click on Upload. 9. Please wait for the router to reboot. After a successful firmware upgrade, you need to reset the router. E. Reset the router. 1. Please push the reset button at the back of the router and release after 30 seconds. 2. Unplug the power adapter for 10 seconds and then plug it back in. (this note should go before the step to Reset the router) Note: Resetting the router will erase all the settings so it needs to be reconfigured afterwards. The router can be reconfigured using the setup CD or by manual configuration.
Posted on Jun 08, 2009
Cant get my netgear to work at all. tried re setting it and it stil wont work
to configure the netgear router. . . . 1, first make sure that your laptop is connected directly to the netgear router via ethernet cable. 2. after securing step 1, on your computer, open browser, ( internet explorer or firefox ) 3. go to the address bar, the one with the http:\\ and erase everything inside it. 4. type in there, 192.168.1.1 or www.routerlogin.net. 5. username is " admin " password is " password " 6. you would see netgear set up wizard. 7. for wireless configuration, click wireless settings on the left side of the set up wizard. 8. you can edit network name, and get your network security key under security options. make sure to choose WPA PSK TKIP. so that you can have a personalize network key and make sure its 8 characters long. 9. the network security key is the " passphrase " then click apply. then your all set for wireless connectivity.
Aug 31, 2011 | NetGear WNR1000 Router
Network Key for netgear wgr614
Hi, taffy_man, the network key is something you configure yourself. If you dont know it you have to RESET the router to the factory defaults.
Take a paper clip, or something sharp, and insert it into the little reset hole in the back of the router, and hold for 15 seconds or so, that'll reset the router. Wait for all the lights to stop flashing and remain on, then try to connect to the internet.
Or you could type www.routerlogin.com into your internet address bar and it'll ask you for the username and password, the defaults are admin and password..
If that doesnt work do the same thing but first disconnect the power cable. Then while pressing the reset button THEN connect the power cable again but keep the reset button for 10 secons and then go to the routerlogin.com or (192.168.1.1) and do what I wrote above. Then you will have to reconfigure your settings. I hope this helps.
Apr 29, 2010 | NetGear WGR614 Wireless Router
Cannot connect ipod to netgear router. Every time I get same message cannot connect. My son has an ipod too and he has no problems connecting. I called Ipod and they say to call netgear. Netgear wont anser...
First make sure you have the WiFi capability turned on on the Ipod. You can go to settings, and turn it on there. After you have that on, can you see the Network Name? (SSID)When you see the name of the router, select it to connect now you will have to have the Network Key. It is usually located on the adapter(Netgear) itself. You have to make sure that number is the same number unless it has been changed. Your son should be able to see what your Network name is. Once you see that name try to connect, it will ask you for the wireless network key, ou should be able to connect.
Dec 24, 2009 | NetGear RangeMax WPN824 Router
Xbox360/netgear WGR614 V9 connection issue
Do you have encryption enabled on your router? If so you will need to enter the encryption key of the passphrase in the network setup of the xbox 360
Sep 19, 2009 | NetGear WGR614 54 Mbps Wireless Router -...
I cant connect thru my netgear router model wgr614v7
If you hook your PC directly to the router using an Ethernet cable you don't need the key. You can log into the router and change the WEP Key to anything you want, but u have to be directly connected to the router not going through the wireless.
Jan 25, 2009 | NetGear WGR614 Wireless Router
I have installed a netgear wireless router according to the wizard disc and it says I have completed it..however it is still connected to the computer..how do I make it wireless?? If I just disconnect it...
wireless hasnt got nothing in relation to the wired internet ports on your computer. think of it as two seperate books.
if you have brought a wireless router, you SHOULD have brought a wireless card to go inside your computer, just like you need a skybox to watch t.v from the satelite, it doesnt go straight to your tv. just like the wireless signals doesnt get 'absorbed' by your pc.
IF you have also brought, inserted, and installed the wireless card you should follow these steps.
firstly you need to go into 'network connections' and find your wireless connection you have. double click it and you should see a screen where you search for your wireless network, which the netgear wireless router will be sending out the signal. Once youve found your wireless network you can double click it and connect. some people will have a password, called a network key. this should be provided in the paperwork of the netgear wireless router.
GIMME A 'FIXYA' :)
Jul 28, 2008 | Computers & Internet
The microsoft wireless adapter on my Xbox360 does not connect to my wireless network
How Can I connect a network adapter from my room to downstairs about 20 yards away?
I need XBOX LIVE badly, everyone has it cmon FIXYA help me out on this.
The router downstairs is a TalkTalk modem help me!
Jun 28, 2008 | Computers & Internet
Xbox360 connection problem
The generic connection and configuration document
http://www.microsoft.com/windowsxp/using/networking/setup/xbox.mspx
This is a good description of possible router options.
http://www.ianarchbold.com/xboxlive/index.html
If you need assistance setting this up in your environment leave a comment on this problem and I will respond.
Dec 22, 2007 | NetGear WGR614 Wireless Router
Connecting to a netgear DG834G with vista
so u r triying to login to ur netgear router>check with conn>connect the pc through the lan and login to the net gear and configured ur w/l part and dis the laptop restart and check
Oct 12, 2007 | NetGear DG834G 802.11G Wireless ADSL...
NetGear WGR614 Wireless Router Logo
83 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
