Question about Samsung LTN1785W 17 in. HDTV-Ready LCD Television
How to mount my new LTN1785 17 inch Samsung on the wall?
We bought the above 17inch flat screen to mount on the wall in our kitchen. The advertisement through Amazon said it was wall mountable and the directions have a page containing directions about using the wall mount kit (which it says is sold separately). But they don't give the name of it. There are no holes on the back that fit the wall mount kits we have. Does anyone know if there is some bracket that must first be fitted to it before using a wall mount??
  • 125 Answers
SOURCE: Can't find my manual, want to mount my 50
Yes, 2 studs is fine. You might want to goto Home Depot or Lowes and pick a bag of Hilti Toggles. They are toggle that go into the sheetrock and let you mount things to the wall without the need for a stud. They come in a few different sizes so make sure whatever size you buy, that screw fits in the mounts hole. They work very well and I have mounted 50" plasmas using these, with no studs involved.
Posted on Mar 22, 2009
  • 7 Answers
SOURCE: samsung tv wall mounting
For a true flush mount installation, you will need to recess your connections (i.e. power, HDMI, S-Vid, etc). Most tvs have the connections coming out of the bottom to allow flush mounting.
If your wall is not drywall, or you really don't want to bother with the expense of recessing your outlets and cable connections, just get a swivel arm mount. It will allow the TV to sit a bit further from the wall and still look ok.
Go to www.monoprice.com for great deals on mounts. I have 3 of them in my house and they are excellent quality.
Posted on May 22, 2009
  • 3 Answers
SOURCE: what vesta mount to fit tv on wall samsung 2333hd
100 i think
Posted on Nov 02, 2009
  • 9 Answers
SOURCE: purchased universal wall mount kit for Samsung LN46B530
Too little or too short? I've installed a few of these mounts and they should have come with a variety of different size screws. Is it possible the mount is not rated for your TV? Samsung should be able to provide you with thread size. I thought they were standard metric machine screws. Just watch length. That's where the damage could occur should scvrews go too deep into set.
Posted on Mar 03, 2010
  • 8457 Answers
SOURCE: I own a Samsung DLP
Yes it will hold,the wall mount u bought it design for weight of 160 LBS and 50"-60" screen sized right?Just make sure hook up the wall mount on and over a wall area with strong woods beams supports have many fours by fours woods beams lumbers to take off the stress of the holding of the tv by those screws alone of the screen frame screws supports only.
Posted on Jun 30, 2011
Seeking Owner's manual
have you looked in the owner's manual ?
Support LED TV UN40H5203AF Samsung TVs
don't know if this the right one for your set, I think the 40" series all have the same manual. I couldn't download it myself. Also on that webpage you can 'chat' to a Samsung rep. who should be able to give you better directions to the correct instructions
15.January.2016
Jan 15, 2016 | Universal 40-42 Inch Flat Screen Panel...
Lg 42 inch tv o power atall
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Jan 23, 2015 | Universal 40-42 Inch Flat Screen Panel...
Panasonic led viera power light blinks 10 times then stays on no power
These blinks [flashes] are fault indication. You can get an idea about the faulty stage circuit inside the TV, by the number of these blinks. Count it carefully, by switching it ON and OFF, more than 2 times at least, so that, you can make sure about the number of these blinks. If you wish to get more details, check the site linked here. Surf the site in "MOSAIC" view.
Jan 29, 2014 | Universal 40-42 Inch Flat Screen Panel...
Tv won't come on tried all the trouble shooting ideas in book but nada
hi if you brought the tv in november might best to get in contact where you got it from ask them to send a tech out, you won't have to pay as it should be covered by the warranty good luck
regards
shaun
Jan 23, 2014 | Universal 40-42 Inch Flat Screen Panel...
My screen broke moving on my sony flat screen. Tv
I would try contacting<a href="http://www.tvvideorepairil.com">flat screen tv repair in Chicago, IL</a> because that's where I went when mine broke.
Oct 03, 2013 | Universal 40-42 Inch Flat Screen Panel...
CAN YOU PLIZ HELP ME FIX MY TV
Press the AV button on the remote control. If it do not help you, make it a hard reset.
May 28, 2013 | Universal 40-42 Inch Flat Screen Panel...
Can you give me some advice on, how to mount a 46in tv above my non working fireplace mantle?
You would have to use a mounting bracket specifically designed for the type of installation you describe and it certainly would have to be fastened into the studs behind the sheetrock. A TV of that size will be heavy to lift and install in the bracket
Mar 04, 2013 | Universal Bedroom Mounting Bracket For...
I just bought a 46 inch SAMSUNG LED HD TV from Best Buy and will be mounting it on a brick wall above the fireplace. The fireplace has gas logs with a an 8 inch mantle that extends 8 inches off the...
it is not safe to mount the TV 8 inches above the mantle.
Secondly, the heat will certainly be a danger if the TV is mounted above the mantle.
I would advice you look for another position to mount the TV.
I hope the above is clear.
Regards.
Sep 27, 2011 | Televison & Video
Samsung LTN1785W 17 in. HDTV-Ready LCD Television Logo
49 people viewed this question
Henry  Thomas
Henry Thomas
