Question about Philips 42PF9976 42 in. HDTV-Ready Plasma Television
HDMI input damaged?
Because the Philips 42PF9976 42" plasma TV only comes with one HDMI input option, I was forced to switch cables from my HD cable box to my PS3 whenever I wanted to play my PS3. I believe that the switching of cables has bent the pins in the female end of the HDMI input slot. It started out as a seemingly loose connection issue, where a jiggling of the cable seemed to restore the connection. It is at the point now where no connection is established when I put the wires in. I recently purchased a splitter box that allosw two hdmi inputs to one [dont know the tech term for it] but I fear the damage is done and I still can't get a picture. I tried contacting the extended warranty company and they informed me that they are going to charge me $300 if they come to my home and determine that I caused the damage. Now I dont mind paying $300 to have it fixed but this is a fee for the service call alone and I am fairly certain that they will blame me for the problem. I called a private repair company and they gave me an estimate of $900. Any advice or opinions on how I could repair this myself or what to do? Thanks for taking the time to read through this.
  • Anonymous Mar 12, 2014
    The picture is snowy on my Philips 42" plasma no matter what input I put it on cable/ps3/etc. can see image but its snowy and lined through out picture
    Novelist:
  • 192 Answers
This is a very common problem with the HDMI input. The cables seem to be very heavy and pull down on the input on the set, which doesn't have anything holding it down except the solder on the pins. I would not consider blaming any customer of negligence for this repair. When I do a service call for this problem, the charge of the repair is covered by the manufacture or the extended service company. If the service center are the people that told you that they would be charging you, then, contact the warranty company and get another servicer in your area to do the job. You should not be charged for this repair no matter how many times you changed the cable.
Posted on Apr 29, 2007
Connecting Ps3 with philips tv (full hd) when i got hd cable in, and click to switch so the ps3 uses hd to show things and i than switch over to the channel i plugin the hdmi cabel it gives blac kscreen
If it's the first time using your PS3, use the composite cables that came with it. Turn on the PS3 go to video settings and switch the input to HDMI. After you've switched to HDMI, turn the PS3 off and connect your HDMI cable, go back to video settings and change the resolution to 1080p. If this isn't the first time you've used HDMI for your PS3, make sure your T.V. is on the correct input. If the T.V. is on the correct input, try switching the HDMI cable to a different input. If that doesn't work try using a different HDMI cable, testing different HDMI connections if you're still getting the black screen. If none of those work then it's probably a problem with the PS3, but just to make sure try plugging something else with HDMI to see if that works. If another HDMI device works, then it's your PS3, if it doesn't then it could be a problem with your HDMI connections on the T.V.
May 04, 2011 | Philips 52 In. LCD HDTV
I need to know how to switch the TV to 1080. I'm trying to use a HD box
Connect you hd cable box to the hdmi input. If you don't have an hdmi input and have a DTV input you can get an HDMI to DTV adaptor. I hope this helps.
Mar 20, 2011 | Philips 60PP9202 60" Rear Projection...
Hi guys I have a Phillips Plasma TV 42PF5521D/10 model UK version bought in 2008 Guess what untill now i only used the HDMI ports to connect a Home Media Center PC to watch HD content. So last...
hi First, remember the old HDMI reset tech tip. Unplug all HDMI cables (one end will do.) Then remove power from all things in play. No, not just turned off but remove the AC. Wait 5 to 10 minutes, hookup re -test thanks
shaun .
Mar 09, 2017 | Philips 42PF5521D 42 in. HD-Ready Plasma...
When i go to hook up a hdmi cable to my philips flat screen it wont recognize that i have a hdmi plugged into it. so what could that be the tv? the hdmi works with my other tv though
This model has 4 HDMI inputs, do you get same problem in each HDMI input?
Did you checked HDMI input with any other video source like dvd player or PS3 etc instead of cable box?
Below are few helpful tips to connect HDMI input..
1. Ensure that your HDMI cable is certified.
2. Press SOURCE on the remote control to switch to another source and then switch back to the HDMI source.
3. Reset the accessory device and the TV.
• Turn on the TV
• Select the HDMI channel
• Turn on the accessory device
4. While the TV and the accessory device are powered on, unplug either end of the HDMI cable and then reinsert the cable.
Try above options and if tv still does not show picture of any video source through HDMI then it seems problem of HDMI processor located on main board, visual check is needed by qualified tech or call Philips if tv is under warranty.
Hope these info will help you.
Thanks.
Nov 26, 2010 | Philips 42PFL7403D/27 42 in. LCD TV
Our Samsung plasma keeps cutting out when watching a program that is not on HD... The resolution 720x480 @60mghz. What Do I need to do to stop this from happening
Best option is to switch from the HDMI to component input. This is an HDMI compatibility problem between your TV and cable box. You will still be HD but you won't have the blinking out issue. I hope this was of some assistance, best wishes.
Mar 29, 2010 | Samsung PN50A650 49.96 in. Plasma HDTV
Connecting to HD TV
This TV has no HDMI input socket. It Has a DVI input socket. Therefore you will require an HDMI to DVI converter adapter or an HDMI to DVI cable. The DVI is video only so you will require audio cables from your Sky box (Audio L and R ) which will connect to the back left of your TV (Audio L/R sockets next to the s-video and component video connectors)
Nov 02, 2009 | LG RZ32LZ55 32 in. HD-Ready LCD Television
Can i connect with hdmi cable
If tv has hdmi input you can otherwise component aav input is the best,
Jul 08, 2009 | LG DU-42PX12XC 42 in. Plasma HDTV
Change HD settings on lg plasma tv without remote
u need tv remote, with that u can go to the options for ur tv and enable the hdmi allowing ur ps3 to come onto ur tv.
Dec 31, 2008 | LG 50PX1D 50 in. Plasma Television
How to get a high definition Picture??
Hi, first of all you need a high definition source. I'm not sure if your cable box is HD but lets take it as an example. The component leads which you are using isn't 'true' HD video quality, what you need is a hdmi cable from your source to your TV.
Your cable box maybe HD with a HDMI output, if it is then you need the lead to come out of the cable box into your tv's HDMI input using a HDMI lead. Then you switch your TV's source to the HDMI input and it then should be producing a HD quality picture, but to truly get the full HD experience you may want to subscripe to a HD channel or purchase a blueray player becasue most cable TV channels are upscaled to HD and the definition is not as good as on a blue ray disc or a true HD channel.
So in conclusion the cable and input you are using is not designed for HD input. I believe your TV is HD, check for HDMI inputs or DVI inputs.
Hope this explains your problem
Nov 28, 2008 | Sansui HDLCD-2600 26 in. LCD Television
PHILIPS 50PF9630A/37
Quick test of the plasma screen itself:
1) Turn on the TV
2) Try to bring up an on screen setup menu using the remote or buttons on the tv.
3) Does the menu appear? If so, the screen itself is ok.
If it doesn't come up you make have an issue with the screen itself. I am not sure it would be possible to set contrast and brightness settings such that the picture would completely disappear, but I suspect you should be seeing something on the screen just from having turned it on.
We also need to know more about what you have connected to the television. HD televisions typically have several inputs on them including HDMI, digital cable, VGA and component. Let's say for example you have PS3 connected via HDMI. You can tell the PS3 to send audio across the HDMI cable as well as video. You also have the option of running separate connections for your audio signal. It is the existence of these options that make it necessary to understand where and how you have things connected, very specifically.
Sep 17, 2008 | Philips 50PF9630A 50 in. Plasma Television
Philips 42PF9976 42 in. HDTV-Ready Plasma Television Logo
892 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
