Question about HP OfficeJet 6110 All-In-One InkJet Printer
Fax won't work with new digital/internet phone system
I recently switched from Qwest to an internet phone service called ACN. The fax is connected to the new phone and seems to dial out and get connected fine and will even send the fax, but then I keep getting an error message -- error 388. The one change is there appears to be a long pause between the dialing/connection message and when the fax actually starts to go through the machine. I read on some message boards that the HP6110ix doesn't work with internet phone systems. True? Any way to change the settings on the fax/printer?
    Problem Solver:
  • 18 Answers
VOIP internet phone service quality is not good enough for fax use.
Xerox will not support issues with fax machines on internet phone lines.
They are good enough for voice , not for digital data.
Posted on Sep 24, 2012
    Genius:
  • 2,120 Answers
True. ALL fax machines are analog devices. Internet phone lines are DIGITAL.
There is no way to make it fax reliably.
Posted on Dec 29, 2008
I live in the USA. My caller ID stopped displaying incoming calls. Last incoming call on the display says 12.2.14. Even when phone is ringing, caller ID does not display name, number,time,date,etc.
Call Phone Co and see if you are programed for the Caller ID feature. In some areas this feature cost more. Whether or not you are paying for it, it may not be programmed in their switch for you?
Feb 06, 2015 | Vtech 5.8GHz Cordless Phone with Digital...
Hi, I need to connect my comSwitch 5500 to the Cable/internet/VOIP. Command Communications ComSwitch 5500 is a Telephone Line Sharing system- (automatic phone/Fax Switch) sold under the following...
I'm not one hundred percent sure on this, but it does look like you need a separate phone line since VOIP revolves around using your internet as a gateway for making phone calls. And since majority of VOIP uses ethernet connections, or wireless, there is no phone line to use.
Feb 28, 2011 | Computers & Internet
Got a new tranz 380. it won't stay connected .
Your shop has optical phone lines? lol I never heard of such a thing and I used to work for MCI worldcom.
All you need to do is call up Qwest or your local phone provider and have them put in a standard analogue phone or fax line.
Here it would run you about 20 bucks if you dont get it as a business line. maybe 50 if you tell them it is for a business.
Mar 27, 2010 | VeriFone TRANZ 380 Transaction System (X2,...
I can not send or recieve faxes. Ran fax test
Cox Cable is pretty much the same as comcast's and vonage's services. HP fax machines have had HUGE compatibility issues with those types of services, and may be that they did something to their service that caused your fax to stop working.....
Other than that call HP and see if they have any troubleshooting or Diagnostics that you can run, but I ran in to these problems with HP faxes all the time while installing comcast phone service, never knew WHY it didn't work, just that HP doesn't work on that type of service.....at least certain models...Also maybe call COX and see if they did anything recently that could cause it to stop working....
Jun 25, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
HP officejet 6310 cannot fax
did you have fax service on the line?
Jan 27, 2009 | HP Officejet 6310 All-In-One InkJet...
I have a Lexmark all in one printer, X5270, I cannot send or recieve fax's, so would you tell me what I need to do to fix this, as it is suppsed to do fax's. I have Qwest dsl hooked up and have an...
I have an "all in one" model X2580. I haven't attempted faxing, but I just looked up faxing in my user's manual and it appears we need a modem with fax capability to do this. Before reading the manual, I assumed it was done over the Internet.
Text from manual:
"Make Sure:
The printer is connected to a computer that is equipped with a fax modem.
The computer is connected to a working phone line.
Both the printer and the computer are turned on."
Having Quest DSL should not be a problem. but it won't help you.
If you don't have a fax capable modem in or attached to your computer, is one included in your answering machine that could be attached to your computer? If so, this could help. If not, you probably need to install either an internal or external 56K modem with fax. They are not expensive and if you're lucky, someone might give you one id they're changing their ISP from Dialup to DSL or Cable Modem.
I will ask a Lexmark person I have been in contact with recently, but I don't think this can be done over the Internet.
Aug 05, 2008 | Lexmark Office Equipment & Supplies
Trouble with the fax function
There is no setting to make this work, sorry.
This is just the nature of digital phone service. Some fax machines will work, and some won't, but generally the extremely high priced units are the one that will work (of course, right?)
It all has to do with the way the fax machine "hears" the ring, or detects the dial tone.
The only other option is to use the HP as a scanner, and send the faxes through the internet using a 3rd party fax program.
I know this is a pain, but unless you want to shell out big bucks for a new fax machine, it may be the only answer.
Apr 07, 2008 | HP OfficeJet k60xi InkJet Printer
Brother Intellifax 770 fax machine failure to receive faxes
I HAVE A BROTJERS 770 AMD ALL I DONE WAS GET A 2 SPACE TELE JACK AND PLUG IT INTO MY MODEM FROM COMCAST AND PLUG MY PHONE AND FAX INTO IT AND CAN RECEIVE AND SEND
Mar 24, 2008 | Brother IntelliFAX 770 Plain Paper Thermal...
I get calls all the time about fax issues. I work for Comcast and have guided people to the right answers about third party devices. We use a digital connection. Analog is a dying medium. Most calls are concerning HP and Brother but I know others fax machines have had problems too. The new HP machines have a digital setting. HP is aware of digital issues and can help you. It is unfortunate that old fax machines are not digital but a new fax is inexpensive if you wish to buy one. Analog takes up too much space. An example: Six digital television channels can fit in the same space (bandwidth) as one analog. That is why the FCC mandated the change. The same goes for phone lines. I Google almost every problem concerning fax machines and if you go past all the upset comments you will get to the comments that offer remedy. I also wanted everyone to know that a second, no frills fax line from Comcast is very inexpensive and our way of offering a dedicated fax line intead of a distinctive ring fax option.
Mar 21, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
HP OfficeJet 6110 All-In-One InkJet Printer Logo
269 people viewed this question
Ben Johnson
