Question about JVC AV-48P575 48" Rear Projection HDTV-Ready Television
My girl friend was trying to trun off the tv and some menu screen show off and she trun off the tv and when i trun off the tv we have no sound can u fix that problem
    Scholar:
  • 164 Answers
It sounds like she hit the MUTE BUTTON.
Open the control setting or remote and turn it off.
Mastersage
Posted on Feb 18, 2009
I have a 42 inch flat screen tv set only the blue and red led turns on nothing else the sreen stayes black my little girl played withremote cotroll from then it stoped working i think its on stand by
Find the settings menu in the TV. It sounds like you turned the green off completely. You can usually set the hues and colors and adjust for your preference or for lighting and such. Hope that helps.
Nov 17, 2013 | Televison & Video
Sharp tv #27sc26d no picture have sound
There is a voltage loss in the main board. It will be best to contact any experienced service technician, as the work is a skilled one.
Jan 03, 2013 | Sharp 27SC26B 27" TV
My hannspree tv screen goes black blank
If the picture shows a picture briefly upon power up then goes off after a few seconds, you have a back light fault. It could have a problem in the 24vdc circuit, failing back light inverter board, or a blown CCFL lamp.
Dec 05, 2012 | Televison & Video
I have the samsung LN52A550. When I turn the tv on a blue screen appears. I tried changing the source with the menu button but does not display anything. The TV is about 2 years old. The sound works. When...
Try this
Method one- with set on, hold down the exit button on the remote for 10 seconds. It will bring up the warning it will reset to the defaults it had when removed from the box and powered up initially. in the warning box it will show the cancel button highlighted initially. press the left arrow to select the reset option. You may end up doing this blind, so you may need to try it a couple times and the only indication of where you are is just a slight flash from part of the screen.
Once that left arrow has been pressed once, the reset option choice changes to "Ok" or "reset", press "enter" The set should
do it's thing to reset and then shutdown.,
Method 2
it should get you into the hotel settings, but you can reset to factory defaults from there, changing any other settings may limit access to the normal settings.
Shut the set off.
The while holding the mute, menu and info buttons, trun the set on while holding them down. If the functions portion of the board is working, it should bring up hotel options menu.
Feb 07, 2012 | Samsung LN52A550 LCD TV
Toshiba tube tv display doesnt show
when you unplugged it,it reset the clock.you need to set the clock.
on the remote play with the input,menu and display buttons until settings come up.one the date and time is set,probably ok.the best thing is to see if your friend has the manual.there are literally hundreds of different toshiba t.v. alone
May 22, 2009 | Toshiba Televison & Video
Picture has gone blank
Press menue to see if the menue pops up (yanno for sleep timer and stuff). If not, you need to have it repaired or need a new tv. You could try unplugging it from power for a bit, might help.
If you can see the menues then and your using HDMI, switch to a regular cable line and see if it comes in. Or just tune to channel 4 or somthing and you should get snow. Could just be the HDMI cable.
But if you cant get ANYTHING not even the Ch3 or Volume to show up on the screen, its the screen, a fuse or somthing else
Oct 13, 2008 | LG 42PX5D 42 in. Plasma HDTV
The TV shows light green ring line on the screen.
Take off the speaker grill and the particle board just behind it. You'll find a block with six knobs. The 3 bottom knobs can be adjusted ever so slightly to fix your problem. Do it very slowly. You wan to adjust the center knob for green. Turn it until the lines go away. But again, do it very slowly. You're adjusting the voltage to the green tube. Do it too fast and you can damage it.
Jun 22, 2008 | Sony KP-57WS500 57" Rear Projection...
Broken Screen
Ebay is your best bet,check in the faulty section.
Apr 20, 2008 | Televison & Video
Problems with Emerson EWF2004 20" TV
I TRUN THE TV1.gif ON NO SOUND I PULL UP MENU AND THERE IS NO SOUND PLACE IN THE MUEN WHAT CAN I DO TO GET SOUND.
Feb 29, 2008 | Emerson EWF2004 20" TV
NO SOUND
you can try checking in the menu. this tv has an option in the menu can you can turn off the speakers. in some tv's it sort of hidden. go into the audio part of the menu, if you do not see it, go down to the last item in the menu screen & keep pressing down. sometimes they have more options to show that just doesn't fit on the first screen. good luck.
Jan 17, 2007 | GE 27GT271 TV
JVC AV-48P575 48" Rear Projection HDTV-Ready Television Logo
53 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
