Question about Kitchen Ranges
Eroded burner tops
I have a gaggenau modular gas stove top which is 15 yrs. old. The burner tops are badly eroded. The numbers on the parts are 3-2047-63 and 2-2047-62. Please advise where I can get them replaced.
reg501
  • 413 Answers
SOURCE: what could be wrong with
The flame is 'yellow tipping'. This means there is incomplete combustion and will leave black soot on everything. Did you recently start using propane? If so the stove will need to be converted to propane use, or the incoming gas pressure is too high. You may need a gas professional to check the gas pressure.
Posted on Jun 07, 2008
  • 126 Answers
SOURCE: GE gas stove the burners on top work, the oven won't get hot
The most common reason a gas oven won't heat is a bad igniter. It is located near the valve and burner under the oven bottom. You can usually see it glow orange just before the fire lights. Most GE ranges take a cylindrical igniter part #WB2X9154 or #WB13K21 rectangular igniter.
Posted on Jan 02, 2009
jumptrout51
  • 3361 Answers
SOURCE: whirlpool gas stove
Replace the regulator on the gas line.
Posted on Feb 21, 2009
  • 56 Answers
SOURCE: How can I tell the model number on a magic chef
most of the time the top will lift straight up with a few clips that let it just pop up and there is a prop rod under the top. also you can look in the bottom drawer area that is usually where the model # is if it has sealed burners.
Posted on Jun 29, 2009
SOURCE: Kitchenaid Gas convection range lower burner will
whirlpool oven wont turn on top burner work.
model #SF315PPQ2
Posted on Sep 05, 2009
Where can I buy the stovetop burner gaskets?
  1. Gaggenau Range/Stove/Oven Parts - RepairClinic.com
    www.repairclinic.com/Shop-For.../Gaggenau-Range-Stove-Oven-Parts Huge selection of Gaggenau Range/Stove/Oven parts in stock. Same day shipping. Open 7 days a week. ... Door hinge, top/bottom. OEM Part - Manufacturer # ...
Jul 11, 2015 | Gaggenau Cooktops
One gas burner in whirlpool gas stove top will not light when turned on. Has to be lit manual
the electrode on that particular burner has eroded or is dirty enough from boiled over items that it cant spark to ground anymore,you can try filing the electrode off carefully with a fine nail board to see if its just dirt or its actually defective
Dec 03, 2012 | Kitchen Ranges
My 5-burner 36" gaggenau has stopped working. I
Hello.
What the problem is a part in the cooktop that opens to let gas flow to the knobs as soon as they are turned on is bad and no gas coming to surface unit burners. This a safety feature that the German goverment(where Gaggenau is made) requires that part to prevent a gas leak when cooktop is off.
Gene
Aug 08, 2011 | Gaggenau 36 in. KG 291 Dual (Electric &...
Jan 02, 2009 | Jenn-Air JES9750AAS Electric Kitchen Range
Whirlpool gas stove
Jan 01, 2009 | Whirlpool SF325 Gas Kitchen Range
Replacement Parts For Vintage Magic Chef stove
You probably have a 1940's model of Magic Chef. Check for the model number under the lid of the cook top on the upper right hand side of the stove. It should have the model number and the serial number, too. You will need both. The Old Applicance Club run by Jack Santoro is the place to go along with a site called "Antique gas stoves"in Georgia. Good luck with the world of vintage stoves.
Sep 23, 2008 | Kitchen Ranges
Gaggenau Cook-top VG 352-812 problems
Hi, interesting. I have the same units on my GasHob and my problems are exactly reverse. To turn the burners on it takes about 15 clicks and with some luck you'll get gas! Sorry, wished I could help.
Claus.
Jun 08, 2008 | Cooktops
Gaggenau VG-352-812 Cook top
You should be able to go online to Gaggenau and in the service area there is a link for order parts
Jan 03, 2008 | Gaggenau 23 in. KG 260 Gas Cooktop
Ge spectra gas stove top not lighting
no gas flow sounds like a bad gas regulato on the stove. as for the 5 year old ge profile with ignitors not working, you need a part called a spark modual
Nov 16, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
