Question about GE WPRB9220D Top Load Washer
Hot water not really hot
I have a problem with my brand new top load washer. The hot water cycle is only luke warm. I was told by the technician who came out that the hot water cycle uses cold water in it too causing the water to not be hot. He says its because the newer detergents don't require hot water. Is that true?
  • 91 Answers
Even though that may be the case, he was feeding you a line a BS. If you have the machine set for hot only, then only hot water should flow, assuming you have hot water coming from the hot water heater. If it is mixing hot and cold then the selector is sending an open signal to both hot and cold water solenoids, where is should send to hot only. Call the costumer suport line for your GE and tell them what he told you, they will send out a new tech.
Posted on Aug 30, 2009
  • 308 Answers
I have never heard of this before, and have always piped dishwashers off the hot water line. Not to say it could not be done the other way, I would refer to the instructions that came with the dishwasher, and if they say to connect to the hot water line, to have the technician come back and fix it. If it says to connect to cold water line, then manufacturers know best.....Hope this helps
Posted on Jul 14, 2009
4 Suggested Answers
SOURCE: GE washer won't fill with cold water
Cold water pipe had become frozen. FYI this model of washer has a nice feature whereas you can test each component i.e. valves, by setting the timer and reading the LED's on the front panel. Instructions are in the schematic.
Posted on Jan 19, 2009
  • 105 Answers
SOURCE: GE Profile Top loading Washer Model # WSSR3120W1WW ---
The water diverter could be plugged. or the diverters solinoid has gone bad on the hotwater side. It is located on the diverter itself.
Posted on Feb 10, 2009
  • 240 Answers
SOURCE: Luke warm water on sanitize cycle, why?
remove lower kick panel and check wire connections to heater. 2 wires go to heater terminals and a harness connector goes to temp sensor in middle of heat terminals. may be green ground connection on another term. use multimeter and check resistence on heater. during cycle heater will take time to heat.
Posted on Apr 27, 2009
Cold/cold cyle wash water not cold
try to do cold cycle first without doing warm cycle first
Apr 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore top load water temp switch problems and hot water rinse
Hi, Switch the hoses around going to the mixer/inlet valve. I am sure this will take care of the problem.
If not, please let me know so I can assist you further.
Vic
Jul 01, 2009 | Washing Machines
Getting only cold water to my washer; hot water is not there
Hot water solenoid valve on washer not working. Test resistance across connectors. No resistance equals bad solenoid. Their not expensive and easy to install.
Mar 29, 2009 | Kenmore 20722
Water not hot on hot temperature setting
BS ....on the back inside the washer are two solenoid operated valves that control the hot and cold water flow. your hot valve has ceased to function...and needs replacement.  also make sure your hot water valve is open fully and that the screen inside it isn't clogged.
Mar 29, 2009 | Kenmore 22422 Top Load Washer
Mar 16, 2009 | GE WBVH6240F Front Load Washer
Maytag Atlantis top load washer that wont' let cold water cycle through. Water is always hot or luke warm. checked screens on hoses. Any suggestions?
ok just a touch of help for ,,onthejob...i need you to start at a cycle and put unit on cold cold,,ok...now i want you to put your hand on back of unit where the inlet vavle and the hose meet at unit...do you feel a vibebration,,or here it humming,,now if hot water comes though,,all you have to do is reverse the hoses there on wrong,,im here onthejob
Dec 28, 2008 | Maytag Atlantis MAV6000 Top Load Washer
GE WPRB9220D Top Load Washer Logo
242 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
