Question about Averatec 3250HX Notebook
Received "failure to write system32\hal.dll followed by inability to boot the system.  We have a Averatec 3250HX laptop that we use for travel and would like to know how to get a workable system32\hal.dll.  I tried copying one from one of my other laptops since I cannot find the original disks for this machine-we are the original owners.  Is there a way to get a workable ahl.dll that we can at least get back running with?
  • 151 Answers
Microsoft has posted a fix for this. You can find it here, scroll down to resolution.
Posted on Dec 29, 2008
Says windows root>\system32\hal.dll. is missing or corrupt, can't use laptop Please advise, regards Jason
some system on your windows has corrupted, it caused by a virus or bad disk
you need to restore your system to fix this issue
if your laptop build in windows xp and you have a restore disk just follow these steps
1. turn on your notebook
2.quickly press ctr and f11 simultaneously
3. click restore when "Dell PC restore" message appears
4.click confirm (it means you will lost all data in drive which contains your old operation system)
5.wait and click finish when the process of restore finish
if your laptop build in windows vista you can follow these steps
1. turn on your laptop
2. quickly press f8
3. when "Advance Boot Menu" message appears just click repair
4. select language and click next
5. log in and click ok
6. click dell factory restore and click next
7. click yes on the box "format hard drive and restore the system"
8. when the process finish click finish
if you don't have a restore disk build in your laptop you need a windows cd installer to reinstall your os
Jun 06, 2011 | Dell Inspiron 6000 Notebook
On start up <windows root>/system32\hal.dll.
Your Hall.dll is fine but you have to repair it.
ATTRIB C:\BOOT.INI -a -h -r -s
DEL C:\BOOT.INI
BOOTCFG /rebuild
FIXBOOT
Jan 17, 2011 | Acer Aspire One PC Notebook
Keep getting this message <window
  • "Windows could not start because the following file is missing or corrupt:
    <Windows root>\system32\hal.dll.
    Please re-install a copy of the above file."
  • "<Winnt_root>\System32\Hal.dll missing or corrupt:
  • "Cannot find \Windows\System32\hal.dll"
  • "Cannot find hal.dll"
The "missing or corrupt hal.dll" error displays shortly after the computer is first started. Windows XP has not yet fully loaded when this error message appears. CauseCauses of the "missing or corrupt hal.dll" error include, naturally, a damaged hal.dll DLL file or a hal.dll file that has been deleted or moved from its intended location.Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged hard drive.
    Please let me know you have any further questions or concerns.
Thanks.
May 08, 2010 | HP Compaq 6720s Notebook
The file <windows root>\system32\hal.dll.
Restart the PC. The hal.dll error could be a fluke.
Check for proper boot order in BIOS. You might see the hal.dll error if the boot order in BIOS is first looking at a hard drive other than your main hard drive.
Note: If you've recently changed your boot order or recently flashed your BIOS, this may be what's causing your problem.
Run Windows XP System Restore from a command prompt. If this doesn't work or you're receiving the hal.dll error message before you're able to complete this process, move on to the next step.
Repair or replace the boot.ini file. This will work if the cause of the problem is actually Windows XP's boot.ini file and not the hal.dll file, which is often times the case.
Note: If repairing the boot.ini does correct the hal.dll issue but the problem reappears after a reboot and you've recently installed Internet Explorer 8 in Windows XP, uninstall IE8. In this specific situation, IE8 could be the root cause of your hal.dll problem.
Write a new partition boot sector to the Windows XP system partition. If the partition boot sector has become corrupt or isn't properly configured, you may receive the hal.dll error.
Recover data from any bad sectors on your hard drive. If the physical part of your hard drive that stores any part of the hal.dll file has been damaged, you're likely to see errors like this.
Restore the hal.dll file from the Windows XP CD. If the hal.dll file is truly the cause of the problem, restoring it from the original Windows XP CD may do the trick.
Perform a repair installation of Windows XP. This type of installation should replace any missing or corrupt files. Continue troubleshooting if this does not resolve the issue.
Perform a clean installation of Windows XP. This type of installation will completely remove Windows XP from your PC and install it again from scratch.
Note: While this will almost certainly resolve any hal.dll errors, it is a time consuming process due to the fact that all of your data must be backed up and then later restored.
Feb 15, 2010 | Dell Latitude E5500 Laptop
  1. Verify the boot.ini file is found on the computer by using a boot diskette or use your Windows CD to get to the MS-DOS "C:\>" prompt.
  2. From this prompt edit the boot.ini, verify that it is pointing to the correct operating system, and that no anomalies are found within the file. Below is a listing of what to verify
  • If only one operating system is on the computer verify that the boot.ini only has one operating system listed. In some situations an alternate configuration line may be added for the same operating system, leaving the improper line.
  • Verify that the "default=" line as well as the operating system line are the same and that they are pointing to the correct operating system.
Verify that the computer has the hal.dll file
From the MS-DOS "C:\>" prompt quickly determine if your computer has the "hal.dll" file by typing "dir hal.dll /s" at the prompt. If the computer returns a "File not found" message, the hal.dll has been deleted.
To recover this file boot the Windows operating system CD and choose the option to "Restore", "Repair", or "Recover." This option will prompt you for the Windows installation to use, the administrators password and will allow you to restore the proper file. At the MS-DOS prompt type the below command.
expand C:\i386\hal.dl_ D:\windows\system32\
In the above example "D" would be the letter of your CD-ROM drive and "C" the letter of the drive your operating system is installed on. For example, your disc drive may be D: and your hard drive is likely C:.
Jun 04, 2009 | Compaq Presario 5000 PC Desktop
Missing hal.dll. file
Try this support link from Microsoft this help me to solve similar problems
http://support.microsoft.com/kb/314477
Mar 17, 2009 | Microsoft Computers & Internet
My averatec 2300 is melting the AC power cord
Okay, the driver for the system fans (hal.dll) needs to be reinstalled.
Do the following:
Press the windows key and R
Type in command
In the command prompt that comes up:
Type in cd C:\Windows\System32\
Type in taskkill /f /im "hal.dll"
Type in del hal.dll
Then restart your computer
What taskkill does is kill the system fans application that is using the driver so you can delete it. After your system restarts, Windows will automatically reinstall the system fans driver, and the problem will be fixed!
Mar 12, 2009 | Averatec 3200 Notebook
\system32\hal.dll. MISSING FILE
YOU NEED TO DOWN LOAD THIS PROGRAM FROM MICROSOFT.
WWW.WINDRIVERS.COM/HAL.DLL
OR
WWW.WINDRIVERS.COM/SYSTEM32/HAL.DLL
ONLINE ADDRESS BAR: WINDOW DRIVERS FOR SYSTEM32\HAL.DLL
OR FIND THE FILE IN THE ORIGINAL SOFTWARE YOU INSTALLED THE WINDOWS VERSION ONTO THE SYSTEM
ROD
Feb 12, 2009 | Acer Aspire 5000 Notebook
Windows>\system32\hal.dll. corrupt
HAL.DLL Missing or Corrupt
If you get an error regarding a missing or corrupt hal.dll file, it might simply be the BOOT.INI file on the root of the C: drive that is misconfigured
Insert and boot from your WindowsXP CD.
At the first R=Repair option, press the R key
Press the number that corresponds to the correct location for the installation of Windows you want to repair.
Typically this will be #1
Type bootcfg /list to show the current entries in the BOOT.INI file
Type bootcfg /rebuild to repair it
Take out the CD ROM and type exit
Regards
Mar 26, 2008 | HP OmniBook XE3 Notebook
Averatec 3250HX Notebook Logo
69 people viewed this question
Top Averatec Computers & Internet Experts
Rommel Balcita
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
