Question about Dryers
Frigidaire Gas Dryer not heating up, Model FSG447GHS0
Dryer ignitor Clicks and glows orange, clicks again and goes off and have flame that is couple inches high hitting top of round enclosure it is housed in but dryer is still not heating but sits and burns like this but with front panel back on I can hear the ignitor or something click every few minutes as though the air through the enclosure I guess may be blowing flame out because it burns fine and doesnt reclick with front cover off watching it. Any Ideas? Frigidaire FSG447GHS0 dryer.
  • 1 more comment
  • tlowery643 Dec 30, 2008
    Have vent off the rear and the air is flowing fine....
    Checked them with meter and they ohm good
    Ohmed coils and they are good...pulled connector off of each coil one at a time and each time the flame went out, ???
  • 640 Answers
Check vent and vent ehaust tube for blockages..
Posted on Dec 29, 2008
  • 1 more comment
  • onthethejob1
    onthethejob1 Dec 30, 2008
    but its blowing cool..ok just change gas coils,,,defective gas coils
  • onthethejob1
    gas vavle coils,,,
  • onthethejob1
    im still with you...i would have like you to change those coils but..becaue the only part left is the valve itself...please do this 1 more time and let me know what happens,,,a little teh review,,,when the coils are energize they pick up the plungers in the gas vavle itself...now what your listening for is,,the vavles trying to come up,,it will sound like a bunch of click than a clunck.please take your time,,and happy new years,,im here..
Whirlpool dryer heating sporadically?
Remove the lower front panel and turn dryer on. The ignitor should glow bright orange first. After Ignitor glows brightly the next thing will be the flame lighting as the gas valve opens with a click. All this should happen within about a minute or so.
If flame comes on but goes off quickly It's likely one of the Gas valve coils is opening a break in the coil as the coil heats up. This coil will shrink when cool and be able to run again. The coils are purchased as a kit.
If ignitor goes off and no flame comes on the coil kit is likely needed because one coil is fully broken inside its case. If flame goes on but shuts off shortly the problem is as described above and the kit is needed.
There is a flame safety assembly on the can above the burner. If the airflow is poor. the flame tip may activate that safety and turn the flame off. Or the flame switch may be open and not allow the flame to come on at all.
The Flame switch can be tested for continuity with an ohmeter but the valves may ONLY show bad with power applied and can not be tested with a meter as they will test good.. Good Luck
Nov 18, 2015 | Whirlpool Dryer. Gas Dryer. 7.0 cu. ft. in...
Dryer is turning but not getting hot
what's the brand name of the dryer and send the model number,if it's gas does the ignitor glow orange but no flame,also if it's gas when you start it you should hear a click,if you don't most likely the dryer is clogged with lint or the vent line is blocked with lint and the high heat popped the thermal fuse,but let me know what you have
Jan 24, 2014 | Frigidaire 134844410 Fridgidaire Dryer...
Kenmore gas dryer #41793142300 electronic start doesnt heat up
if you first have heat and then like 10 to 20 minutes later no heat you could have bad gas coils,on most gas dryers there's a plastic cap you can pop off on the front panel so you can look in and see the ignitor,if at first the ignitor glows orange and the flame lights then after a few minutes the ignitor glows orange and the flame doesn't light you have bad gas coils,they are located on the top of the gas valve,easy to change.part number 5303931775 go here and look at part 71
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Dryer-Parts/Model-41793142300/0582/0151200/R0310102/00005?blt=06&prst=0&shdMod=41793142300
Mar 25, 2013 | Dryers
Our dryer runs but doesn't heat. I have checked the obvious things but have not got into the ignitor etc. In order to access the burner etc. on this model do you have to access through the top. Older...
dont forget about thermal fuse on back of dryer white plastic with two wires can jump out for testing see if you get heat if so replace thermal fuse and clean venting adn venting flapper for opening and closing .... if no heat tthen open lint screen on top of dryer remove two phillips screws pull lid forward from back corners towards u and lift lid up remove front screws should be two 5/16 screws on in each corner and door switch harness connected lift front upwards and to the right remove drum belt tensioner bottom right side .. release belt remove drum set out of the way ... plug in dryer watch ignitor in burner tube bottom left corner should glow redish orange then a click and then a flame
no glow aslong as thermal fuse has been checked bad ignitor....
if glows and no click replace flame switch black and silver box on left side of burner tube
if glows and clicks and no flame replace two black round coils on top of gas valve
Jan 28, 2011 | Dryers
KELVINATOR GAS DRYER. IGNITORLIGHTS UP THEN TURNS OFF. NO HEAT.
the ignitor needs to be glowing white hot not orange. it is not hot enough to ignite so you need to replace it.
Oct 04, 2009 | Frigidaire FGQ1442ES Gas Dryer
Kenmore Gas Dryer Model 75731 Dryer Won't Heat
The orange glow is the ignitor. If the ignitor is glowing but the gas does not light then the flame sensor may have to be replaced. If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
See also: http://home.howstuffworks.com/how-to-repair-a-dryer.htm
Sep 21, 2009 | Kenmore 63942 Dryer
Gas dryer won't heat up
The ignitor can glow and still be defective.
Take a volt meter and check for power at the gas valve while calling for heat.
If you have voltage, replace the coils again.
No voltage, replace the ignitor and flame sensor.
Mar 08, 2009 | Frigidaire Dryers
Maytag gas dryer model#NDG2330AWW heating problem
your gas coils are bad. they open up for the first cycle but fail to after. Replace your coils and this will solve your problem
Dec 13, 2008 | Maytag Dryers
Dryers Logo
340 people viewed this question
Top Dryers Experts
