Question about Panasonic DVD-S35 DVD Player
How to clear positioned memory
I have position memory set and can't remember what DVD it was for. how can I clear these without going through all my dvds
  • 6 more comments
  • j_evans29 Dec 31, 2008
    no good - have left it unplugged overnight and 4 of the 5 memory positions are memorised
    Hi
    I've tried unplugging and leaving overnight but it still 4 out of the 5 memory positions are memoried so it only leaves us 1 to use
    Have just tried that and nothing happens. Have tried with a disc in and no disc in.
    have tried disconnecting the ac power and reconnecting but memory position are still remembered
    Hi
    Sorry there is not s (D) or (;) or hold button. Did you mean pause button ? The unit has on/off switch, stop, play, pause, fast forward, rewind, eject & Zoom mode up and down button
    Hi
    I have looked at page 9 of the user guide but it only states how to set the memory position and then how to unset it with the original DVD you had set it with. My problem is that I have hundreds of DVD's and can't remenber whcih ones were set. If I knew I could clear them easily
    Hi
    thought I would mention I am in the UK. will the unit be any different ?
    Thanks
    Genius:
  • 1,011 Answers
Sir,
The position is memorized when
“!” flashes on the display.
≥Press [1] (PLAY) to resume.
[DVD-V] To review the previous
chapters (page 9, Position
memory).
≥Press [∫] to clear the position
click this link and read the manual 9th page
Posted on Dec 31, 2008
    President:
  • 948 Answers
"so it only leaves us 1 to use"
You realize that you still have all five to use, the unit simply overwrites the oldest one when you save a new one? You could open the unit and either remove the battery or short out the memory chip but you would gain nothing by doing so. Your unit is still fully functional and you can continue to use your position memory as normal.
    Sergeant:
  • 250 Answers
While stopped, press and hold [D] and [;] on the unit and then also press and hold [<] on the unit until “Initialized” disappears from the television. Turn the unit off and on again. All settings will return to the default values.
  • Sean Cole
    Sean Cole Dec 31, 2008
    Sorry, you need to refer to this for the button codes:
    http://www.fixya.com/support/p232130-pan...
    All the best,
    Sean
    PiDigital.co.uk
  • 6,487 Answers
Try doing this steps in resetting the unit:
Press [POWER í/I] to switch the unit to the standby mode and then back to ON.
Alternatively, press [POWER í/I] to switch the unit to the standby mode, disconnect the AC power supply cord, and then reconnect it.
    Genius:
  • 3,422 Answers
Try this to reset unit. Hold "STOP" button on the player and then press "10" on the remote.
  • 1 more comment
  • Priya darshan Dec 31, 2008
    I'll let you know if there is a user manual available for this model.
    You can download the manual here:
    http://service.us.panasonic.com/oper...x...
    Go to page 9 of the manual where it reads:
    "Memorize positions on up to five discs to restart play after switching
    the unit to standby or changing discs."
    "When you memorize the sixth position, the earliest position is
    replaced."
    Brigadier General:
  • 5,158 Answers
Unplug it for about ten minutes... should reset it
    Top Expert:
  • Panasonic Master
  • 78,289 Answers
Go to page 9 of the user guide from the link below, the position memory function is there, also how to reset it.
http://service.us.panasonic.com/OPERMANPDF/DVDS35.PDF
How clear memory royal 1000ml cashier
In order to clear the memory of a Royal 1000ml cash register, you would do the following:
1. First turn off the cash register without unplugging it and slide the control switch to the "off" position.
2. Open and remove the printer cover and put it to the side. Take out the paper roll and put it to the side as well. Open and remove the battery compartment cover and set it to the side.
3. Notice where the batteries are in the slots and note the orientation of the batteries, such as the positive and negative marks and then pull out the batteries.
4. Now unplug the cash register and wait at least 20 minutes to plug it in again. Slide the control switch to either the R1 or R2 position.
5. Put the batteries back as they were before and put back the battery cover, along with the paper roll and printer cover.
6. Select a mode using the control switch and then reprogram the register as needed with your settings.
May 23, 2015 | Retail Supplies
Cannot format cleared memory card when replaced back into camera.-- then it says "CHECK SD CARD" - take out the card and rplace it - go through the same procedure to ""FORMAT" and the same thing
Did you check your lock switch on the memory card is in the unlock position?
It should be in the up position like on the left card.
Apr 28, 2014 | Cameras
I have codes: po455, po123. po406 po606.p2104, po2106, p2110, & p2135 help please!
(so i cleared the code..all was fine.) No it wasn't ,you don't just clear code's without doing the diagnostic's for that code . It's just a matter of time ,when the PCM/ECM - engine computer runs that test again, that light will come back on. P0455 is a large leak in the evaporative emission system .Sorry dude but you don't stand a snow ball's chance in guam of fixing this .
Do you know what electronic throttle control is ?
P2135 - ETC Throttle Position (TP) Sensor A/B Voltage Correlation Description: The powertrain control module (PCM) flagged a fault indicating that TP1 and TP2 disagree, or that TP1 should not be in the present position given the position of TP2 unless a concern is present. Possible Causes:
  • TP sensor shorted internally to VREF.
  • TP sensor harness is shorted to power.
  • TP sensor signal wires are shorted together.
  • Damaged TP sensor.
Diagnostic Aids: Compare the TP1 and TP2 PID values for a full sweep and correlation. Refer to the chart in pinpoint test DV. GO to Pinpoint Test DV .
Compare TP1 and TP2 PID values to the typical reference values in Section 6 . Application Key On Engine Off Key On Engine Running Continuous Memory All GO to DV4
P2110 - Throttle Actuator Control (TAC) System - Forced Limited RPM Description: The TAC system is in the failure mode effects management (FMEM) mode of forced limited RPM. Possible Causes:
  • Cross-wired TAC motor.
  • Damaged powertrain control module (PCM).
Diagnostic Aids: This DTC indicates only that the FMEM condition exists, and can be set in combination with DTCs P2100, P2101, or P2107, meaning the electronic throttle body (ETB) faults should be diagnosed first. Application Key On Engine Off Key On Engine Running Continuous Memory All GO to QE1
Do yourself a favor an take it to a qualified repair shop.
Nov 08, 2017 | 2005 Mercury Mountaineer
I tried changing keyboards,nothing. when I pluged it back in totaly dead, had to plull off jumper, now its running ( fans) that is and performing automatic IDE configuration. [Invalid configuration info...
Many motherboards have a "clear CMOS jumper" capability. There are 3 pins on the Mobo and the jumper is put on pins 1 - 2 for normal operation and moved to position 2 - 3 to clear CMOS memory. (It may be the other way around on some Mobo's). Your PC will oly work with the jumper in the normal position. If you temoraily moved it to the clear position (and then put it back to normal) you erased your cmos memory which remembers the date & time, hard drive cofiguration and many other importnt parameters which need to be set correctly in order for your PC to run properly. If you have the manual that came with your motherboard, it explains how to go into cmos setup and set these parameters. If you do not have this manul, navigate through the menus and choose "default (or optimal) bios settings" Then set your date and time, choose save bios settings and exit bios setup. Hopefuly your computer will start up OK now. If not, you should find a PC technician to help you.
If you have any additional questions contact me by clicking on the "Add a comment" link located under your problem description on FixYa. Also, if you believe that this information was helpful to you, please rate my solution using FixYa's "Solution Helpful" rating scale.
Best regards,
Yavacotech
Jun 25, 2011 | Computers & Internet
Can't connect charger's cables to battery without sparks
NEVER connect positive to negative. You'll damage your electrical system in the car or fry the charger.
It is best to put the positive on first, and then the negative. Remember, it doesn't always have to be the negative post of the battery, it can be a really good ground on the bare metal of your car.
But sparks just go along with it - don't let them scare you. But I always connect the clamps first, then turn on the charger, with the dial on "off". Then make sure of the 6/12 volt settings, and the amp charge you want to put on. A long slow charge overnight fo 12 volt can be 10 amps. A relatively fast is 50. And then to jump it off, go to the setting.
Make sure the battery being charged is sitting in wood, not concrete. If you have the old fashioned battery with removeble water caps, don't breathe the vapors.
May 28, 2009 | Schumacher & Fast Charge Starter Charger
Go video #VR5940 DVD Recoder + VCR
It is actually a menu setting that is intended to allow you to leave for a short time (like to go to the grocery store), and view the remainder of a movie without having to find where you left off.
With your remote control, enter the menu and look for a setting related to "Remember Last Position".
(I would be more specific, but the company's website has been taken down and there is nowhere to research the exact wording from the menu)
Nov 06, 2008 | GoVideo VR5940 DVD Recorder/VCR
Jsi js4110
The only operations available on the JSI JS4110 without a remote are play, pause, stop, and eject. Since this DVD player "remembers" position of the movie, a different DVD would have to be inserted and played to start that movie over from the beginning. As for fast-forward, this is only available with the remote.
May 13, 2008 | Philips PM3S Remote Control
Breaking of Bios Password
How can i break my laptop's bios password without reset motherbord.laptop moel is wipro WIVNB7710
Feb 11, 2008 | Computers & Internet
SHARP ER-A440
2. Master reset (All memory clear)
There are two possible methods to perform a master reset.
· MRS-1
Used to clear all memory contents and return machine back to its
initial settings and return keyboard back to default keyboard layout.
Procedure
1) Unplug the AC cord from the wall outlet.
2) Set the MODE switch to the (SRV¢) position.
3) Plug in the AC cord to the wall outlet.
4) While holding down JOURNAL FEED key, turn to (SRV) position
from (SRV¢) position.
· MRS-2
Used to clear all memory and keyboard contents.
This reset returns all programming back to defaults. The keyboard
must be entered by hand.
This reset is used if an application needs different keyboard layout
other than that supplied by a normal MRS-1.
Procedure
4) While holding down JOURNAL FEED key and RECEIPT FEED
key, turn to (SRV) position from (SRV¢) position.
5) Key position assignment:
After the execution of MRS-2, only the RECEIPT FEED and
JOURNAL FEED keys can remain effective on key assignment.
Any key can be assigned on any key position on the main keyboard
i found this on the manual at this site...
http://www.skan.com/Manuals/A440/ERA440-SRV.pdf
Jan 26, 2008 | Casio Parts Cash Register PC Desktop
Position Memory.....
Sep 29, 2007 | Panasonic SC-HT670 System
Panasonic DVD-S35 DVD Player Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
