The display says "multi-zone" but no sound coming from zone 2 speakers. I can't seem to set the volume any longer. Any ideas?
Time to reset the microprocessor. See page 87 in manual.
1) switch off the unit using the main unit's power operation (small power button)
2) hold the PURE DIRECT button and DIRECT button at same time and turn the main unit's power operation on.
3) wait for entire display to flash in 1 second intervals
now the speakers need to be set up again but zone 2 will be working. i suspect a power surge causes the microprocesser to be corrupted. i put a power surge protector and have not had problems (lately).
If no sound coming through Zone 2, steps that worked are below. Layout: Denon AVR-988 running in 5.1 mode with patio speakers designated as Zone 2: 1) check that patio speaker wires are connected to Denon's back surround speaker terminals, 2) check "Menu then "Manual Setup" and scroll to check that "Amp Assign function is set to "Zone 2". You won't get Zone 2 sound unless this is chosen in this instance. Also check the volume settings in the "Manual Setup" to ensure you haven't turned sound down by -40 DB or limited it. Now try turing on Zone 2 sound either on front panel or on rear of remote. If you still have no sound, what worked for me is there's a Zone 2/Rec Out pushbutton on front left top panel by round input knob. This must be set to "Zone 2 Source" and not "Rec Out Source".to avoid diverting the signal to the Rec Out jacks. Keep turning the input select button until it reads "Zone 2 Source". Then turn on and this should route the signal to your Zone 2 speakers. srhfish
Can you give any advice on how to program the multizone to just allow you to use addtional speakers? I have speakers in my kitchen: I want to play TV through front mains and CD on Kitchen speakers. How do I set up Zone 2 or 3 to accomplish this? Many thanks, the manual is terrible on this subject.
