Question about LG Studioworks 700S 17" CRT Monitor
Screen does not maximise automatically
For the past 4 months the image on my monitor does not maximise. Everytime I start up my computer, the image size on the 17" screen is about the size of a 12". I have to use the resize buttons on the monitor to resize the image to fit the screen. This does not only happen on restarting but also when comming out of a game, after maximising the windows media player screen or any other 'intensive' graphics program. I have tried the monitor on various other computers and the same thing happens with exactly the same screen size. If I plug in another monitor into my computer it works fine. Sometimes on startup the monitor is totally blank. I then have to connect the monitor to another computer. It starts to work (screen image smaller ofcourse), and then when I reconnect to my present computer it starts to work, again with the smaller screen image size. The problem started when I sent in my computer to a dealer who installed a new modem for me. I only sent the motherboard case and not the monitor. Please help.
  • Missy_2511 Apr 10, 2009
    on 2 stations the screen is to small but is OK on other stations (al free to air stations)
    Please suggest resultion as I don' t have the manual
    Thanks
    Denise
  • 65 Answers
Reinstall the driver for your monitor or adjust the resolution in the desktop properties
Posted on Jul 07, 2007
  • kbza loka Jul 10, 2007
    obviously the problem is in the monitor,but the cuestion is ¿can you adjust the width or not? if you can't you have an electronic problem (EP),if you can the monitor can't memorize this "New Value"(another EP).in the first case will be an open cap,or transistor.but in the second case maybe micro, eeprom. good luck
SOURCE:
Why does my Sony Google TV NSX-46GT1 46 in. HDTV LCD TV powers up, displays application screen on bottom, makes a computer chime and shuts off completely, and starts the same process over and over aga
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 25, 2014 | Sony Google TV NSX-46GT1 46 in. HDTV LCD...
BenQ Change language after i shutdown the computer ?
Using it since 2011 and the same problem started in few months. send back to claim warranty. they change internal board. was ok for few week until the problem back. never send back for warrranty as it took nearly two months to them to replace the piece. never going to get another benq product after this!
Sep 16, 2012 | BenQ V2420H 24" W Extra Slim LED Backlight...
HCL Monitor Screen Display Problem with Contrast menu showing up.
my hcl 17inches monitor is displaying contrast,brightness etc automatically
in the middle of the screen.even if i press the menu buttons it
disappears for a sec and comes again and again.what should i do to
solve this?
Sep 13, 2009 | Computers & Internet
Today I noticed that when turning on computer, after 1-2 mins the screen goe black and I cant see anything. I noticed in the past month that occasionaly I get lightening flashes in the background. this...
To determine if the LCD screen is faulty ot the video card, connect an external monitor to the laptop's video port. Power up the external monitor first and the boot up the laptop. The video image should automatically switch to the external monitor. If you don't get flashes on the monitor then the video card is OK and the fault lies with the LCD screen. Flashes coud be caused by a faulty inverter or a faulty CCFL lamp. A fault is usually easier to diagnose when it is not intermitten.
Jun 08, 2009 | Dell Inspiron 6000 Notebook
Appian Gemini - full screen within one monitor in dual screen
TRY CTRL + B KEY
OR CHECK OUT THIS WEB SITE:
www.marctalkstech.com/guides.html
Feb 01, 2009 | Appian Graphics Gemini (16 MB) PCI Graphic...
My new hp officejet pro L7590 printer tells me that "no scan options" are available. I bought this as a all-in-one printer. help, I need to scan
Hi Kate,
This error occurs if HP drive services are not functioning properly, so try my solution
Solution
Follow these steps in the order presented to resolve the issue.
Step one: Verify that the Digital Imaging Monitor is ready
The Digital Imaging Monitor must be running in order for the Scan To function to work. The Digital Imaging Monitor icon normally appears in the system tray at the lower-right corner of the computer screen, and the monitor is ready when a check mark appears on the icon after Startup is complete.
If the Digital Imaging Monitor is in the system tray, proceed to Step two.
If the Digital Imaging Monitor does not appear in the system tray, follow these steps.
Windows 98, Me, and XP
1.Click Start , and then click Run .
2.In the Open text box, type msconfig .
3.Click OK .
4.In the System Configuration Utility window, click the Startup tab.
5.Search the list for HP Digital Imaging Monitor .
6.If HP Digital Imaging Monitor is not on the list, the driver was not correctly installed or a custom install was used. 7.Proceed to step three to uninstall and reinstall the software.
8.Select the HP Digital Imaging Monitor check box.
9.Click Apply , and then click Close .
10.Click Yes to restart.
Windows Vista
1.Click Start .
2.In the Start Search text box, type msconfig and press Enter .
3.On the User Account Control window, click Continue . The System Configuration Utility window displays.
4.Click the Startup tab.
Step two: Populate the destination list
1.The destination list must be populated in order for the Scan To function to work. Follow these steps to populate the destination list.
2.Open the HP Solution Center. Use one of the following methods to open the HP Solution Center.
3.On the Windows desktop, double-click the HP Solution Center icon.
4.On the taskbar, click Start , Programs , or All Programs , click HP , and then click HP Solution Center .
5.If more than one HP device is installed, click the tab for the All-in-One product. The HP Solution Center shows only the functions, settings, and support options that are appropriate for the selected HP product.
6.Click Settings .
7.Click Scan Settings and Preferences .
8.Click Scan to... Setup .
9.Click the Destination List tab.
NOTE: Depending on the computer performance, it can take several minutes for the Front Panel Destination List to populate after the printer or computer is turned on.
10.If the Front Panel Destination List is empty, continue with this procedure.
11.If the Front Panel Destination List contains valid scan destinations, proceed to step three to uninstall and reinstall the software.
12.Click each program to include on the Scan To list.
13.Click the Add arrow.
14.Click OK .
15.Scan a document using the Scan To button on the front panel.
16.If the scan fails, try to scan using the HP Solution Center Scan button.
17.If the scan still fails, proceed to Step three to uninstall and reinstall the software.
Step three: Uninstall and reinstall the software
1.Insert the software CD into the CD-ROM drive of the computer. The software installer should automatically start.
2.If the software installer does not automatically start, complete the following steps.
3.Click Start , and then click Run .
4.In the Open text box, type X:\setup , where X is the letter of the CD-ROM drive.
5.Click OK .
6.On the installer screen, click Uninstall . If there is no Uninstall option, the software installation is incomplete.
7.Insert the software CD into the CD-ROM drive of the computer. The software installer should automatically start.
8.If the model supports custom install, install HP Imaging Device Functions to scan from the printer. The recommended install will install this feature automatically. It must be manually selected during a custom install.
9.Follow the onscreen instructions until the printer software is completely installed.
10.After successful installation, scan a document.
Step four: Service the product
If you have completed all the steps listed above and are still experiencing a problem, service the product.
Thanks
Riz
Jan 13, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
When I hit scan it says "no scan options"
Hi just follow the below steps and the problem will be resolved.
Solution:
3.Click OK .
Windows Vista
1.Click Start .
6.Click Settings .
14.Click OK .
5.Click OK .
Thanks
Riz
Dec 28, 2008 | HP Officejet J5780 All-In-One InkJet...
Monitor Screen problem
no this is not the problem of your monitor. sometimes it cames while loading operating system. it useually cames when you hybernet your computer.if you dont shutdown and make hybernate then this will appears in next time while you on your system.
Jun 18, 2008 | Computers & Internet
Monitor randomly shuts off and computer restarts
After you turned it on and the screen shut off, check the image on the screen by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. This is because of the lamps inside screen. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. If the computer shut down immediately after the monitor shut off, it might be because of fault operating system. Check with another monitor.
Thank you,
Mar 08, 2008 | HP Compaq FS7600 17" CRT Monitor
Screen Flickering on Acer 3680-2682
Ok we must remember when we setup any device on our PC, one of the many non PnP devices is and LCD Monitor, your PC should always be shutdown before installing a new Monitor. If you did not do this you could have damaged the I/O port on your PC. Not a definite, but possible! When you plug up a monitor or any serial cable while the PC is still on, it is of a low voltage which can casue some issues for you! Sounds like this one is yours!
Nov 21, 2007 | Acer Aspire 3680 Laptop
LG Studioworks 700S 17" CRT Monitor Logo
355 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
k24674
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
