Computers & Internet Logo
Anonymous Posted on Oct 04, 2012
Primopdf -20 Trying to print just one page out of a .pdf, getting "PDF creation failed: -20" error. Can't tell what's wrong.
Inconsistent printing
In the printer's dialogue find the print pages number. Print page from/to and select 20 pages chunks. In effect print only part of the document at a time. Add all chunks together in one pile. Work around I know, but it works.
tip
PDF Converter
PDF Download converts the page all while retaining the page layout, fonts, images and hyperlinks on the page. Its support for HTML, XHTML and CSS-based pages ensures the creation of high-quality PDF files, which are ideal for archiving, printing, sharing and emailing like <a href="http://www.anypdftools.com/pdf-converter-for-mac.html">PDF converter Mac</a>. <br /> <b>1. Easy PDF</b> <br />This Converter is used to convert from PDF file to Doc file. It is independent application software that does not require the MS Word or the Acrobat Reader. This program allows you to convert PDF file into Word document with a high speed. You can convert batches of PDFs to Doc format at one time. It has user friendly interface that makes it easy for use. <br />Easy PDF has some salient features as follows: <br />a. It compresses the pdf file as per your requirement without making changes in content and layout. <br />b. You can either add or delete text or images from the resultant Word document. <br />c. It works well on all the platforms like Win98, Win 2000, Win XP and Windows 7. <br /> <b>2. ISTS Office PDF Converter</b> <br />This Converter can convert word file, excel sheet and image to PDF and can also create images from your existing PDF file without affecting the privacy and security of PDF files. <br /> <b>3. PDF Converter Elite</b> <br />If you want to get best result with low cost and high speed, then you can opt the PDF Converter Elite. Using this tool, you will able to convert and edit the existing PDF. Not only this, you can even create new PDF from the older one. It is different from others in some aspects like it helps in creating new PDF and edit them as well. You can extract the pictures and text from the PDF files and export to your desired file format like Word document, Excel sheet or Power point presentation. Moreover, you can create compatible PDF files that can be easily viewed. <br /> <b>4. PrimoPDF</b> <br />This Converter by Nitro PDF Software is a freeware and you can download it from the Nitro Pro Website and install in your computer system. With this, you can even create PDFs from any file format which you can use for printing, screening, use in ebook etc. <br /> <b>5. Cute PDF</b> <br />It is also a freeware that can supports both for 64-bit Windows XP ,and 32-bit and 64-bit Windows Vista. <br />
on Jun 23, 2011 • Computers & Internet
tip
PDF - How To Create One
To create a PDF all you have to do is simply download a PDF printer add on. <br />When you create a document or image etc.. click the print button and select the PDF software (It will display as a print).<br /><br />I would advise PrimoPDF i have been using it for many years now and creates incredible PDF's with many options such as passwords, text PDF, hign resolution PDF ect. <br />Once you have download the software, open the file you wish to have as a PDF (This will be a new file and not overwrite the original file) click print and chose PrimoPDF from the printer drop down menu. <br />PrimoPDF will then lunch it conrol panel where you select options such as the once stated above including where you would like to save the PDF<br /><br /><a href="http://www.primopdf.com/index.aspx" style="font-weight: bold;">PRIMOPDF</a>
on May 10, 2011 • Computers & Internet
1helpful
Can suretrak print directly to a pdf
If the program can print to a normal printer, then all you need is to download and install a 'pdf' printer such as PrimoPDF. Then when you print from within SureTrak, just choose the PrimoPDF printer instead of your normal printer and it will send the output to a PDF file. :-)
Duplex Error When Trying to Print PDF
I found that one of the papers i was trying to print was set for double sided printing, well i don't have the duplex part of it. So I kept getting the error. You have to cancel all the print jobs thru the buttons on the printer. Doing it in your computer did not help and turning off the printer did not help me. So after I cancelled all docs from printing and turned off double sided printing it was fixed.
I am trying to install the grease tray on me grill. I had Home Depot put it together. I can't find the tracks to slide it in on. Seems kind of basic, but I'm not getting it. I'm sure...
Cy, Home Depot must have given you a good deal on this model, as it has been discontinued by Brinkmann. Never the less, Brinkmann still supports it.
In case Home Depot failed to include the Owner's Manual when they delivered it. I have included a link to it, that you can download & print for future reference. Starting on Page # 20, you will see how to install the drip pan.
http://images.brinkmann.net/docs/pdf/810-6805-1.pdf
I hope this helps you and thanks for choosing FixYa.
How can i convert the scan file to pdf file ?
try to use PrimoPDF ( freeware) to convert your scanned file into pdf file.
- download primopdf and install it, this will be installed as printer ( check printer and faxes it should be there after installing)
- print your scanned file using PrimoPDF and it will ask you to create and save the file in PDF.
- its free.
2answers
My canom laserbase mf3110 print only one page
Well, when it comes to PDF files i found a solution. When u click the "print" icon, u get the "print" window. If u leave it as is, u will get a format/paper size error when trying to type several pages, as described by u. However, if u unmark the "Choose paper source by PDF page size", it will print as many pages as u want.
So...If u have trouble printing pages, it may work if u turn your pages into PDF format and follow the instruction above :)
2answers
Scanning from Canon image runner 2200
You may have to upgrade your adobe
Top Nitro PDF Software Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Nitro PDF Software Computer and Internet Expert? Answer questions, earn points and help others
