Question about Whirlpool Duet GHW9150P Front Load Washer
Error Code of F-30
My Whirlpool front loading washer will not fill with water; howver, I can hear a pump "clicking" while it is trying to fill. This happened after I ran a rather large load of laundry.
  • 15,935 Answers
The F30 error code will flash when the dispenser motor cannot be driven to its proper position.
* It could have a mechanical failure in the linkage between the dispenser motor and the top of the dispenser.
* Loose wire connection between the machine control board and the dispenser motor
* Failed dispenser motor
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 21, 2010
Duet. What does F8E1 code indicate needs to be done to restore operation?
Check out the Link and the info below.
Question: Front Load Washer - Error Code - F8 E1 or LO FL Answer Product Symptom:
F8 E1 or LO FL Code in display:
No water detected entering washer after 13 minutes, the pressure switch input has not been detected.
If the washer has an F8 E1 error or LO FL error, the door will be locked, and the control will be unresponsive. The washer will start a drain routine which takes approximately 8 to 10 minutes, during which time the pump will run continuously. The control will not accept any input during this time. Please wait 10 minutes before trying to perform any functions.
Check the water supply:
Turn on the water. Check the household water supply to see if the hot and cold water faucets are turned on. Make sure to open both faucets completely for proper fill.
NOTE: Both Hot and Cold water must be supplied to the washer.
Whirlpool recommends that appliances be direct connected to the water supply for optimum machine performance.
If a "flood saver" device is being considered:
  • Check with the manufacturer of the device to ensure it will not affect the performance of the appliance.
  • Whirlpool has experienced that "flood safety" devices can interfere with the performance of the appliance. Whirlpool typically does not recommend these devices.
Two types of "flood-saver" devices, hoses and valves are illustrated below. anti%20flood%20hose%202.jpeg floodsafe%203.jpeg Whirlpool Duet Washer F8 Code Appliance Repair Forum
Jan 19, 2016 | Whirlpool Washing Machines
GHW9150P Duet washer will not finish cycle
Just click below for code error;
WHAT IS WRONG WITH YOUR WASHING MACHINE?
small_11_21.jpg For a detailed Washing Machine illustration, click below.
Top Load Maytag Style
redarrow.gif Top Load Whirlpool Style
redarrow.gif Top Load GE Style
redarrow.gif Front Load Maytag Style
redarrow.gif Front Load Frigidaire/GE/Kenmore Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Some problems that can occur with your top-loading washing machine are:
There's an error code on the digital display
It doesn't work at all
It won't drain
It doesn't spin
It doesn't agitate
It's noisy
It leaks
It's off balance
There's no hot water
There's no cold water
It's slow to fill
There's no water at all
The clothes are wet after spinning
The cycle doesn't advance
There's no delicate or regular spin or agitate
It's overfilling
It's underfilling
The water temperature is incorrect
Hope it may help you;
Regards,
VOTIT
Sep 24, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Fh error code wirpool duet washer
Display shows F20 or FH - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...fh-front-load-...
Whirlpool Home AppliancesQuestion: Display shows F20 or FH - Front-load washer. Answer. Image. or. Image. or. Image. This error code indicates a water supply problem. Are both the hot ...
whirlpool duet error code FH - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Jan 5, 2009 - 10 posts - ‎1 author
... Repair Help > Washer Repair » whirlpool duet error code FH .... FH No water detected entering machine or Pressure switch trip not detected. Whirlpool Duet diagnostic code C:03 error code FH
1 post
Dec 5, 2014
Whirlpool Duet Washer HF Error Code
Jun 10, 2013
FH Error Code on Whirlpool Duet Washer
Mar 11, 2013
FH error code
Sep 13, 2008
More results from forum.appliancepartspros.com
Stumped on error code FH for Whirlpool Duet front load washer .
Jan 08, 2016 | Washing Machines
I have the maytag series 4000 and got the f2 code. I have cleaned the.hoses and wven replaced the drain pump. Is thete a rest button? It is still not working and.shows the same code
F2 code is water level to high
Washer Error Codes
Below is a list of washer error codes for HE & conventional top load washers and front load washers. As more error codes are found or published, we will add to the list. Right now you will find error codes for Asko, Fisher & Paykel, Frigidaire, GE, Kenmore, LG, Maytag, Samsung, and Whirlpool. This list might not be complete and should be used for reference only.
Asko Washer Error Codes
• F1--Water supply/low water fill.
o 1. Check water supply to machine.
o 2. Replace water inlet valve.
• F2--Water level too high.
o 1. Plugged/Bad water pump.
o 2. Faulty water valve.
Sep 19, 2014 | Washing Machines
My Whirlpool washer flashed F30. Not filling up with water.
"F30" indicates "DISPENSER SYSTEM ERROR" When the dispenser motor cannot be driven to its proper position this error appears in your washer. To fix this problem follow these procedures.
1. Unplug washer or disconnect power. 2. Check mechanical linkage from dispenser motor to the top of the dispenser. 3. Check wire harness connections to the dispenser motor and Central Control Unit (CCU). 4. Check dispenser motor for powered rotations.
Thank you !!
Jun 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Washer GHW9150PW0
The following link explains the "FH" error and recommendations you should take:
http://www.fixya.com/support/r615354-fh_error_code_whirlpool_duet_kenmore
Eliminate the easy possibilites, first. Make sure you don't have a siphoning issue and make sure the drain pump is not clogged. Listen carefully, when the washer fills and make sure you have sufficient water entering the wash tub. These washer only use about 5 to 7 gallons of water per load, but you should still be able to see and hear water entering the tub. If you have an insufficient amount of water, you may want to inspect the water inlet valve for sediment build up. If you live in an area that has hard water and/or use well water, you could likely have sediment or rust deposits clogging your water inlet valve. A good cleaning with distilled vinegar does a good job at getting rid of deposits.
If these preliminary checks don't do the job, unplug the washer for at least 30 minutes. This is recommended by the manufacturer to reset the main computer. In many cases, this procedure will clear common glitches and error codes.
I hope you find this information helpful. Let me know if you are still experiencing problems and I will assist you further.
Sep 07, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet sport wfw8300sw00 f-21 error
Unplug the machine. Unscrew the 3 screws under the front edge of the washer. The service technician manual is attached to the panel that slides down and off. Find F21 code. See suggested procedures. Note: My drain pump filter had a baby wash cloth in it along with some change that was disrupting the flow. It is exceptionally easy to remove, clean, and reinstall. Just line up installation notches when reinstalling. Whirlpool should have mentioned this filter in the User & Care Guide, but I could not find it anywhere in there.
Mar 24, 2008 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Error codes
f dl refers to a bad door lock. do you hear a faint clicking noise when you try start the machine and after maybe 30 secs of clicking the" fdl "comes up???or perhaps the door makes the noise to lock but never does lock,in which case sounds like a bad latch assy.. although the fault for the door latch it could also be the CCU not energizing the door lock. try taking off the top of the unit by removing the 3 screws along the back of the top assy (they are torx 20 screws) form there youll see the main control board mounted to rear wall and if you look straight down the right front side youll see the wiring for the door lock itself. disconnect power to unit!!!!! first unplug and replug all the wire harness on the door latch and then also the pink wires on the module itself, maybe just a loose connection. try it now see what happens
Mar 17, 2008 | Whirlpool GHW9100L Front Load Washer
Error H F
this code will set for two reasons if the washer doesent start filling after 30 seconds or fills to10.5 gallons in eight minutes and the pressure sensor hasnt triped so time it and post a reply to your message letting me know which condition exist make sure your drain hose isnt too deep in your drain pipe as this will siphon water out as it fills and mke the washer think the second condition exists consult your owners manual for proper drain hose instalation
Dec 22, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
188 people viewed this question
Dan Webster
Dan Webster
Sal De
