Question about Indesit WA 125 Front Load Washer
Ideset front load washer
After i load up my washing machine, it sounds like the water is getting through but it doesnt come into the drum it just makes a winding sound and doesnt wash the clothes what could be the problem please
  • 2 more comments
  • ia_white Dec 31, 2008
    Yeh we have checked all that the belt is still on, just the motor is winding all the time.
    there was only a little bit of water a few clothes were damp, and the belt is ok
    yeh the drum is working it goes through its cyle just the pump keeps going
    thankyou i remember pulling out my washer pushed it back but the water pipe came out letting all the water out, so when i tried to do my wash the problem started dont know if that will have caused the problem
  • Indesit Master
  • 3,463 Answers
If no water is entering the drum, and it is not leaking out anywere, then there can be no water coming in at all, unless the pump is coming on right away and pumping the water out., check the waste outlet pipe as it is filling, and see if water is discharging from hose
One other possibility is that the belt is off and the whining niose is the motor turning on it's own with out turning the drum.
This being the case, u probably wouldn't see any water in the drum, due to the small amount that they take in.
Plz rate my solution.
Thanks.
Posted on Dec 31, 2008
  • 1 more comment
  • Barry Coates
    Barry Coates Dec 31, 2008
    Remove belt and see if drum is free to turn by hand, if it is cud be belt wants replacing.
    U still did not say if u cud see any water anywhere?
  • Barry Coates
    Have u actually seen the drum turning at all, do it with the back off to see what is happening.
  • Barry Coates
    It sounds like there is a programming fault which is bringing the pump on all the time, this being the case, u will have to call an engineer. One last thing to do is to lift the drain outlet hose to a higher level to eliminate any chance of the water syphoning out
    At this point there is nothing more I can suggest to help wiih your prob..
Washer fills and washes clothes but water doesnt drain and go into spin it just sounds like its still pumping out and no error code
Quite possibly there may be something stuck between the pump and the drum which is preventing the water from draining down into the pump. The pump is still working but there is no water to pump out, and the machine can't advance until the water is gone and the pressure on the pressure switch is relieved.
You will have to manually empty the machine and then remove the offending article from the tub to pump hose.
Feb 19, 2014 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire Affinity Glacier Stackable upright washer. Washer will not agitate and makes a buzzing sound from the pump that extracts water from the drum. Water collects and remains in bottom of washer.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 29, 2010 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
Hotpoint wma30. Drum not draining water. Have
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 31, 2010 | Hotpoint WMA30 Front Load Washer
My washer/dryer doesnt spin after going through the wash cycle, during the supposed spin cycle you could hear a humming sound and when it stops there is water in the drum and you can open the door. Is this...
If you can hear a rumbling sound from the drum, then I would say that the main drum bearings have failed.
This is a major repair job, and not one I would recommmend you undertake yourself. as it involves a complete strip down of washer, and the cost is cosiderable.
Probably better to purchase a new washer.
Good luck.
Jan 06, 2010 | Zanussi ZJD1219 Front Load Washer / Dryer
Water in drum
The swish water sound that you hear in the drum is normal. There is some liquid in the drum for balancing. The washer doesnt use that liquid for laundry. The odor smell - you can get rid of it by cleaning your washer. Run empty cycle with bleach and hot water at least once a month. Also use washer cleaner - Tide recommended for a nice cleaner smell. You can get it from any supermarket.
Sep 29, 2009 | Samsung WF203ANW Front Load Washer
Not enough water in the drum during the washing cycle
If its a High efficiency washer it doesn't use much water. Usually the front load washers are HE washers
Aug 30, 2009 | Samsung WF203ANW Front Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Water in drum
thats normal forthins machine they actuall use a water filled front ring for balance, woll always sounds as water is there. desgined that way
Nov 24, 2008 | Maytag Neptune MAH5500B Front Load Washer
Zanussi washing machine wont spin
check the drain hole when you start the machine if the water is coming back out , if yes that means your dump valve is bad.
Apr 23, 2008 | Zanussi ZWF1430W Front Load Washer
Indesit WA 125 Front Load Washer Logo
142 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
