Question about Pioneer DEH-P6800MP CD Player
How do i get to the AUX setting
Need to play ipod through it don't know how to get to the AUX setting
  • 328 Answers
This works on some other pioneer head units i encountered it may work on yours.
Shut it off and hold the function button until the options appear then you can scroll through and change a bunch of settings including the aux input
Posted on Dec 31, 2008
Does using an ipod/AUX adapter through the CD changer input stop a real CD from working?
you have to change it from the Aux setting to CD when you want to play cd, some cd players switch to aux. automatically when you plug inthe aux. cable. and may have to be unplugged when playing cd.
Nov 28, 2014 | Car Audio & Video
I was wondering how do I play music through my iPhone with this cd player. I have a direct cable but I'm not sure what to press to make it play through my cd player. Thank you.
Once you plug in your iphone and set it to play your song(s). Set your car player for AUX this will then pick up the device playing into the direct port. Hope this helps Fix ya up.
May 12, 2011 | Power Acoustik PTID7002NR Car DVD Player
Hi do you know if the wharfedale ics 182 can play an ipod
You need to plug the iPod into the Aux socket, its on the front bottom right corner. Then you can switch by pressing "Mode" between playing either the CS - USB - SD - AUX.
To play iPod, select the "AUX" option.
Nov 03, 2009 | Bang and Olufsen BeoSound 2 Companion MP3...
Only 3 speakers play with ipod all other is ok
Are you playing your ipod through the stereo with a cable in aux mode? If so check your fader and balance settings when in aux.
there would be no other reason except for speaker wiring check and make sure there is no auxiliary wiring that may not be hooked up.
if it's not settings, then it's wiring, unless your stereo has an internal problem in the auxiliary circuit.
May 27, 2009 | Apple iPod MA446LL/A MP3 Player
Trying to play Ipod through my Alpine cda-9811
you need to set up your system to accept aux. this means you will need to set the 'aux on', as the default setting is 'off'. use the manual and refer to page 23 & 24. please read the instructions carefully, as they are slightly confusing.
Mar 15, 2009 | Alpine CDA-9811 CD Player
I have a CDE-9872 and it wont pick up my ipod touch
Add Alpine's optional "Full Speed" connection cable and you'll be able to use the CDE-9872 to control your iPod. -Crutchfields website
This is compatible with first and second generation iPods touch.
fyi- if you have a mini-stereo aux in jack on the deck you can connect a ipod touch compatible mini stereo cable to the earphone jack of your ipod.
Dec 28, 2008 | Alpine CDE-9872 Car CD/ MP3 Player
Playing my ipod on AUX mode????!?!?!?!?!!!!??
HELLO, ON THE IPOD BOX ARE SEVERAL NUMBER CODES. THEY HAVE TO BE SET TO THE RIGHT NUMBERS ON OR OFF BEFORE THE FACTORY RADIO WILL READ THE BOX. ONCE THE CORRECT NUMBERS ARE SET FOR YOUR VEHICLE THE AUX BUTTON WILL WORK JUST FINE. IF YOU DON'T HAVE THE BOOK WITH THE CODES IN IT. JUST COUNT THE WIRES ON THE ADAPTOR AND THE LOCATION OF THE PINS THEY CONNECT TO. THEN PUSH ONLY THOSE PINS UP IN THE ON POSTION. GOOD LUCK!
Jun 07, 2008 | 2003 Chevrolet Avalanche
Playing an Ipod
ya press src until it gets to standby then hold the menu button until it says menu. then press the toggle button down until you see aux and press the toggle to the right to turn it on and be sure to press menu again to set it.
Jan 23, 2008 | Kenwood KDC-MP2035 CD Player
Hooking up an Ipod to my stereo
I'm having the same problem. I pressed the "function" button about 50 times and AUX never showed up.
Jan 06, 2008 | Pioneer DEH-P3700MP CD Player
Got an aux cord to plug my ipod in, doesnt switch to "aux in" mode
According to the manual, you need to "enable" the AUX 1 or 2 thru the initial settings menu.
Press and hold the SRC until the unit turns off. Then press and hold the MULTI CONTROL (knob) until the Language appears. Turn the knob to cycle thru the options, select AUX 1 or 2 and press the knob again to select ON.
After selecting them to on, power the unit on and press the SRC to cycle thru the sources to find AUX 1 or 2.
The owners manual is here if you need it;
http://www.pioneerelectronics.com/pna/v3/pg/support/details/0,,2076_310070337_338818745,00.html
Best of Luck.
Nov 18, 2007 | Pioneer DEH-P6900UB CD Player
Pioneer DEH-P6800MP CD Player Logo
263 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
