There are 2 things in that area that can make a noise, the ice maker,and an evaporator fan,depending on the model.The fan is an easy fix if the blade is just hitting something ,but you have to be abit mechanically inclined to get to it.The icemaker has a little motor that sometimes gets stuck in the ice harvest mode,then you just have to unstick it ,also depending on what kind of fridge you have..everything else is down at the bottom,compressor,condenser,ect. In any case you probably want to call a tech unless its old,because repairs would be more than it is worth.
1. Open the freezer to see if the noise gets louder. If the noise becomes louder with the freezer open, the noise is likely caused by the evaporator fan. If the evaporator fan is the culprit, replace it to get rid of the noise.
2. Take raer panel off inside freezer and check there is no ice build up which is hitting the fan
3. Pull the refrigerator away from the wall, and check the condenser fan at the back of the fridge. A metal panel may cover the fan, which can be unscrewed. Listen to see if the fan is the source of the noise. If it is, the fan may need to be cleaned or replaced.
4. Unplug the refrigerator, and listen to the back side of the fridge. The fans will immediately stop running. If the back of the fridge continues to make a noise after the fans have shut off, the sound is most likely coming from the compressor, which is located at the back of the fridge, near the bottom. If you have a compressor problem, you either have to replace the compressor or the entire refrigerator.
