Question about Dell E773C 17" CRT Monitor
Menu screen keeps appearing
I've has this monitor for about three years and never had any issues. But in the past few days, the "menu screen" keeps popping up. I hit the exit button but it continues to pop back up. Its more a nuisance than anything and I'm wondering if anyone has any suggestions. Thanks
Why is it Dangerous to open the monitor? I almost did it this morning! because I guessed it WAS a mechanical problem.
Posted on Oct 25, 2008
    Problem Solver:
  • 19 Answers
Hello, My name is Richard; I work for Dell here in Round Rock, Texas. From what you describe, it sounds like the menu button is depressed in such a way that small movement activates its function. I could not suggest any real corrective options as this is most likely a mechanical issue with the button, and would require a technician to open the monitor and inspect that. I am not going to recommend you open the monitor case as it can be dangerous. I would suggest you call our tech support at 1-800-822-8965 ex. 726-8859, and find out if the monitor is still under warranty. Regards, Richard B Dell Online Community Outreach
Posted on May 08, 2007
Menu keeps popping up
Make a hard reset to this set and try.
Oct 05, 2012 | Insignia NS- 27" TV27 TV
I purchased my Norcent computer monitor four years ago. Now, the sub-menu Contrast/Brightness selection keeps popping up on my screen. So, I have to either push the #1 button to Exit or the #2 Adjust...
It seems to be a hardware issue with the buttons. They are stuck or the rubber cushion under the button has gone bad. That's the reason they are getting pressed automatically. You may take to a local store for a small repair.
Regards,
Shrey
Jun 04, 2011 | Norcent Technologies LM-965W 19" LCD...
Stupid padlock/main menu keeps opening and closing DELLe152fp
That is the OSD (On Screen Display) system built-in to your computer monitor. Check that when you hit the ON/OFF button on your monitor, that you do *NOT* hit the 'OSD ON/OFF' button.
Most of the time, the OSD will disappear after 10 seconds of "non-use".
Dec 11, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Monitor Menu
HI,
Looks as if there's a problem with the menu button and it needs to be replaced.
Jun 24, 2009 | HP f2105 21" LCD Monitor
Screen menu auto-adjust ghost
never try to fix crt monitor you need a new one cos thay are so cheep cost you lots for reppers ,bye an lcd ,,,,nice
Apr 05, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
Lock/unlock symbol appears in the middle of the screen
5-22-09 Same problem last month. I had the problem a year ago for a month, then it stopped, reappearing this last month. Last week, I finally called support...I was accidentally transferred to a Dell "internal" technical support department...happily a very diligent technician spent a bit of time with me for free...for same problem, even though he confirmed I was over a year past all warranties. He confirmed this was a monitor problem (not virus, malware, etc.). He also confirmed their standard "guidance"/solution for this monitor issue (if under warrantee) is to replace the monitor (i.e. not attempt to fix it). New monitor needed. But problem again gone for last 10 days. So, when fully irritated, buy new monitor.
Apr 03, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
Config screen keeps popping up
A friend of mine had the exact same same problem. I think I fixed it, because it has been 2 hours, without the menu popping up. You need to open the monitor:
- Place it face-down on a flat surface
- Remove the cover of the hinge by gripping it with both hands and gently squeezing and pulling.
- Undo the 4 screws and remove the stand (base)
- Undo the four screws tha hold the cover down (4 corners)
- Use a flat screwdriver to seperate the 2 halves (I used 2, a small one to lift the back, a bigger one for leverage)
You will see a small PCB, fastened by 3 screws, at the bottom (where your menu+on/off buttons are) with a ribbon connection to the screen. Next:
- Unscrew the PCB, and gently lift it out.
- Clean the microswitches and the ribbon cable connection.
- Reassemble the monitor.
To clean microswitches and the connection, I used Kontakt Video 90 spray. There must be sprays on the market where you are. It's basically an alcohol-based cleaning spray. Good for cleaning video/tape/floppy heads, CD/DVD lenses, memory modules, etc.
Dec 07, 2008 | Acer AL1912 19" LCD Monitor
The Contrast screen pops on all the time
It looks like your UP button contact is demaged.
SOLUTION is to insert a piece from your business card mostly above the button to adjust it down or up. It works fine.
Dec 09, 2007 | ViewSonic VX910 19" LCD Monitor
Never a good idea to clean with any spray cleaner. The cleaner does get down in the button bar and cause corrosion and shorting along ribbon cable. Use screen wipes for computer monitors only on TV's and any type of monitors. You can remove the back of the case. And remove the button board and clean with a cue tip and alcohol along ribbon cable.
Nov 04, 2007 | Acer AL1912 19" LCD Monitor
Viewsonic E70 - Menu Popup
This is a builti n feature on the monitor of course- not PC driven
A repair is not likely
Buy a nice new Flat screen
Oct 25, 2007 | ViewSonic E70 17" CRT Monitor
Dell E773C 17" CRT Monitor Logo
401 people viewed this question
Clive
Clive
Alun Cox
