Question about Philips 19PFL5622D/37 19 in. LCD Television
Just wondering if you could tell me the best way to set up the TH42PZ70BA LCD Television to get the best results from the PS3
This is very easy. Just hook up your PS3 to your TV via HDMI cable and set your TV and PS3 to 1080p resolution. On the PS3 all you have to do is click "Display settings" and then go to HDMI output AFTER you have hooked it up. Just click on 1080p and 720p because some games do not support 1080p resolution. Hope this helps!
Posted on Jan 07, 2009
How to fix issues whith component outputs on haier hlh26atbb 26 in. lcd ?
When you make the connection with HDMI are you changing the source or input key on the television to activate HDMI port? If you don't activate the corresponding source you connect to and leave the TV in the TV mode, you won't actually see the device you are connecting. It's possible the TV does not support the 1080P from your PS3.
Apr 17, 2015 | Haier HLH26ATBB 26 in. LCD Television
Ilo won't work with ps3
The set receive no signal at all. It will be best get it repaired by any experienced service technician.
Apr 22, 2012 | iLO 3200 32 in. LCD Television
I have my olevia 232-s12 hooked up to my ps3 it has worked fine for years now for some reason when i had to reboot my ps3 i let it attempt to set the display settings and when i try 1080i or 720p it tells...
this could be a PS3 software issue, if you can let it auto update, if the problem isnt resolved try a 720i setting or a 1080p, if still no joy your display may be on the way out
Mar 05, 2011 | Syntax Olevia 226T 26 in. LCD Television
Best way to hook up ps3 to hitachi 50v500 for best quality picture and audio
The HDMI output on the PS3 to the DVI input on the 50V is the best video option. Be sure to set the PS3 to the matching output. If you need instructions for this, go to:
http://manuals.playstation.net/document/en/ps3/current/settings/videooutput.html
The best audio option I have used is is the digital optical out on the PS3 to a surround sound reciever that has an optical input. We have a Denon reciever. The sound is excellent for a game, very good for movies, and music sounds good too. Unless you are an audiophile, this should give you impressive results.
Merry Christmas and Happy Holidays!
Dec 14, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
I tried to hook up my ps3 to my hannspree monitor
did you hook the dvd player or xbox 360 to see it if still works after ps3? if still no result, it's most likely that the motherboard in the lcd shorted out.
Oct 16, 2009 | Hannspree 19" Widescreen LCD Flat Panel...
HELP?
Restore PS3 to factory settings and change your network settings:
Best Results: Reset your router, then give your PS3 a static IP address and go into your router interface, find the DMZ feature and put in the IP address that you gave the PS3, just make sure the IP you give it is within the DHCP pool of IP addresses.
The PS3 will now be sat outside the routers firewall giving you FULL access to internet content and gaming online.
Now test connection settings and you will notice you will now have an open connection to the internet.
Also check your cable connections.
Thanks
Sep 01, 2009 | Sony Playstation 3 (PS3) Console
No picture or response - LG LCD TV
Hi, I have the exact same problem. I was wondering if you could tell me how you fixed it? Mine is only 2 hours old from the box
Jun 03, 2009 | LG 42LG30 42 in. LCD HDTV
Is the playstation burned out?
Did your cousin ever connect it to an HD tv? If he did, this is a common problem with it. If you operate the PS3 with a normal television set, the ps3 will work fine. But when you connect it to an HD tv and hook up the HDMI cables, the ps3 sets itself to work with HD tv's only. There is a simple fix. a Hard Reset. Call sony customer suuport and tell them that your ps3 doesn't have a menu screen. They will walk you through the steps to restore your system. I would tell what to do myself if I remembered what to do. But regardless, remember this, every time you connect it to an HD tv and want to switch back to a normal tv set, you will have to hard reset the system. Try to remember the sequence the first time so that any other time this happens you'll know what to do.
Best regards,
Gavin93
Aug 18, 2008 | Sony Playstation 3 (PS3) Console
Samsung lcd ln46a550pf3 no sound from hdtv reciever
ok your tv does not come with the very best sound, you have to get a receiver 7.1 or you can use the optical wire , that's if the system you are using has that option.
Apr 10, 2008 | Samsung LN-T4665F 46 in. LCD Television
Jumpy screen as a monitor
There are a number of things that can cause the problem:
The frame and scan rate from your computer is not matched to the specs of the monitor. The monitor may have a sync lock fault.
LCD monitors must be operated in their native mode for best results. Some models are very critical for the frame and scan rate especialy when using a composite video source.
If you take the monitor to the service rep for it, the should be equiped to diagnose it and tell you the exact answer.
Jerry G.
Apr 07, 2008 | iLO 3200 32 in. LCD Television
Philips 19PFL5622D/37 19 in. LCD Television Logo
165 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
