Question about Poulan Garden
Poulan pro series chain saw 20" bearings seizing up on bar
The bar on my chain saw keeps breaking. I have to keep replacing it. why?
thanks
  • 2 more comments
  • cjdk Dec 30, 2008
    The chain is fine. The bar bearing has seized.
    thanks
  • cjdk Jan 10, 2009
    Thank you so much. I appreciate your help.
  • Jerry Cassel May 11, 2010
    The bar or the chain?
  • Anonymous Mar 12, 2014
    14in poulan chain saw will not stay on
There's a tiny hole on the front of the bar near the bar sprocket. This is used to grease the sprocket. If you go somewhere like Lowe's look in the chainsaw section and you'll find a grease tube that is specially designed to lube the front sprocket. Before lubing use a small wire to clean out any debris from the whole. Press the lube tube against the hole and push repeatedly until grease comes out from the outside of the bar. This should greatly extend the life of the bar.
Posted on Jan 09, 2009
  • 17 Answers
Check sprocket isn't worn it may be pulling on chain than over heating bearing. check pitch of chain ,bar , sprocket are the same.
Posted on Jan 03, 2009
Poulan pro troubleshooting
CHAIN STRETCHS AS IT HEATS - KEEP CHAIN TIGHTENED CORRECTLY AND ALWAYS KEEP OIL IN OILER AND MAKE SURE IT OILS THE CHAIN. IF THIS DOESN'T FIX - REPLACE THE CHAIN. IF IT STILL HAPPENS THEN REPLACE BAR. WILL FAIL AGAIN WITHOUT OIL. POULAN WILL NOT HOLD UP WITHOUT CHAIN LUBRICATION. WORSE THAN OTHERS. IF CHAIN OR BAR OVERHEATED YOU'LL WORK ON IT MORE THAN YOU CUT. OIL IS THE KEY TO CUT WITH A POULAN!
Aug 10, 2014 | Poulan Pro PP4620AVX 46cc Gas Chainsaw...
Chainsaw rattles when it stops
personally too much hassle prefer Stihl Chainsaw more reliable Seizing is caused by lack of lubrication, First check all level has oil pump seized or is it sump type when running oil circulates all way round, Still there has to be a oil reservoir if this is bone dry theres your problem the rattling is metal on metal with no protection and the damage is seizing caused by lack of oil I have two chainsaws both have oil sumps and are kept full, please check hope this helps
Feb 15, 2014 | Poulan Pro PP5020AV 50 cc Gas Powered...
I would like to see part digram? for poulan PRO 20"
Poulan currently offers 2 46cc 20" bar chain saws which are virtually identical
model PP4620AV, and PP4620AVX
http://weborder.husqvarna.com/order_static/doc/NIUS/NIUS2009/NIUS2009-PP4620AV-545014314-952802075.pdf
if you are looking for a different diagram please include the model number you need in the post.
Thanks
Dec 28, 2010 | Poulan Pro Chain Saw 46cc 20"
Chain wont tighten up for Poulan 295 Pro chain saw
hi after awhile chains stretch, make sure they get oiled good. nut that holds bar must be lose, like a 1/2 turn then you can tighten screw . don't over tighten ether of these. it takes time to find your saws happy spot , so be patient and keep trying to tweak it tell ya find it..vote if'n i was of help.. remember BUY USA MADE PRODUCTS.. Jay
Jul 18, 2010 | Poulan Pro Chain Saw 46cc 20"
Carb. connector hose to air filter keeps melting.
There should be only two small diameter hoses (lines) that connect to the carburetor--one comes from the fuel filter in the tank and the other connects to the primer bulb. If either of these is melting/breaking from heat, someone has replaced them with inferior rubber/plastic tubing or you have some serious engine heat problems! Buy the correct lines from a Poulan saw dealer and replace the junk. If you had that much heat, it would have seized the piston in the engine. After the lines have been replaced, check the fuel filter, air filter, and muffler for plugging. Start the engine and after warm up, open the throttle fully. It should 4-stroke but immediately 2-stroke when cutting. If it 2-strokes at all times, then the 'H' jet needle may need to be adjusted. Don't ignore this as it causes overheating, low power, and possible engine damage. Hope this helps!
Jun 05, 2010 | Poulan Pro Chain Saw 46cc 20"
Chain keeps falling off
Have you stripped the studs that hold the guide bar in position? It is the only thing I can think of unless the guide bar has worn down so much there isn't a deep enough groove to guide the chain
Jun 01, 2010 | Poulan Pro Chain Saw 46cc 20"
Chain damage
The chain could be stretching. Are you using a good quality bar and chain lube? Never use old motor oil. Once the chain has jumped several times it may be bent.
Properly adjust the chain and keep an eye on it while using. start with a new bar and chain and watch the tension. You can also replace the tool less cover with a standard cover for about $25
Jul 01, 2017 | Poulan Pro Chain Saw 46cc 20"
Poulan prochain saw I need the wheel for the chain tensioner
Following is a link to a Poulan Parts Dealer that has the adjusting wheel. I also included a pdf of break down parts list for your model. Please rate the answer on its value of help. Good Luck have a great weekend.
Order Part
Parts List PDF
Apr 04, 2010 | Poulan Pro Chain Saw 46cc 20"
I have a Poulan Pro PP3516AVX chain saw. I used it
Their not the best saws but make sure the nuts holding the bar and cover on are tight after adjusting chain sometimes improper cutting will continue to kick chain off bar.
Mar 15, 2009 | Poulan Pro Chain Saw 46cc 20"
Garden Logo
357 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
