Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Refrigerator making noise at bottom rear when shutting down.
My Kenmore refrigerator Mod#106.77292790 Serial #EH2215813 makes a rattle noise when shutting down. Is this a broken spring in the compressor housing? How do I diagnose this? How do I buy the correct replacement part and get instructions for installing the new part? I am handy and can make most repairs myself. If I could spend $100 or so and make this repair I would rather do that than buy a new refrigerator at this time.
  • jimmy753 Feb 23, 2009
    As the compressor turns off, I hear a loud thud sound. I had the repair technician diagnose this as the compressor proble. He said it would cost $600. I told him that I will wait until the fridge quits and buy a new one.
  • 3 Answers
This sounds like a compressor motor mount problem. Unfortunately, the only way to fix this is to change the entire compressor, which is something that only a trained technician can do- they will need to drain and recharge the freon. It can cause upward of $400 or more. Fortunately, your refrig will still work if you don't mind living with that sound.
Posted on Dec 29, 2008
Kenmore refrigerator 106.7200 makes rattling noise
i WOULD CHECK THE COMPRESSOR RUBBER GROUMETS AT BOTTOM OR CHECK FOR LOW FREON LEVEL NEXT CHECK FOR CONDENSER FAN NOISE OR BLOCKAGE.
ARE U SURE ITS NOT A CLICKING SOUND OTHER WISE IT COULD BE BAD START RELAY OR CAPACITOR/
Nov 04, 2016 | Kenmore Washing Machines
Kenmore 65234 bottom refrigerator has a hum/rattle for about 30 seconds then quiet, then after a couple minutes, it does it again. Sometimes for an hour this repeats and sometimes does it for a few cycles...
Might be the compressor relay is fixin to depart this life. themobilian_1937.jpg
If this relay starts sticking all the windings will remain active and overheat the compressor. The overload will tae notice and shut the whole shebang down. Once it cools and makes contact the circus continues until the relay finally disintegrates. The last death throws will be a constant clicking followed by noticeable cooling loss in the ice box.
Amana bottom mount service Manual
Mar 16, 2011 | Kenmore 65234 Bottom Freezer Refrigerator
Refridgerator make a noise every 3 minutes
Noise can come from these areas:
The inside of the freezer Self-defrosting refrigerators use a circulating fan to move the air through the freezer and refrigerator compartments. This fan runs whenever the unit is cooling. The fan is located in the freezer, as follows: If the freezer is on top, the fan is on the back wall, near the top or bottom, in the center of the freezer. If the freezer is on the bottom, the fan is on the back wall, near the top of the freezer. If the freezer is on the left, the fan is on the back wall, halfway up or near the top. Over time, the fan may become noisy--usually making a chirping or squealing sound, though it may make a loud groaning noise instead. To find out if the fan is causing the noise, just open the freezer door and push in any fan/light switches. If the noise is louder when the door is open, the evaporator fan motor is the cause. You can't lubricate or repair this motor. You must replace it.
The outside back of the refrigerator There are three components on the outside back of the refrigerator that may become noisy: the compressor, the condenser fan motor (if self-defrosting), or the defrost timer (if self-defrosting). The compressor is a football-sized case with no apparent moving parts. You can see it on the outside of the refrigerator at the back near the bottom. It is usually black and has black or copper-colored tubes and various colored wires attached to it. If the compressor is the device making noise, there is probably no repair that will reduce the noise. You will have to replace it--which can be quite costly. If the condenser fan is making noise, there may be a build-up of lint or other debris on the fan blade. The fan is located near the back of the machine, sometimes behind a thin panel. To clean it, first unplug the refrigerator, remove the thin panel, and use a soft bristle brush to clean it. If there is no lint build-up or debris on the blade, you will have to replace the motor. The defrost timer is often located at the bottom of the refrigerator, near the front and behind the kick plate. Occasionally the electric motor inside the timer may become noisy. The timer must be replaced to solve this problem.
The bottom of the refrigerator Noises detected at the bottom of the refrigerator almost always originate from the back of the refrigerator. However, sometimes the drain pan under the refrigerator will rattle. You may need to tape the pan in place to stop a rattle. Also see the “Outside back of the refrigerator.”
Mar 29, 2010 | Kenmore 56539 / 56532 / 5653 / 656534 Side...
Constant loud noise when frig turns on/comes from bottom
when the compressor is running unplug the ref. and if you hear the noise coming from the compressor then
a ballance spring may be broken inside the compressor.
The compressor will run normally with a broken spring it will just be annoying when it shuts down.
Jan 16, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
Kenmore Coldspot 69182990 - knocking noise
check te rubber mounts at the bottom of the compressor
the rubber rots after some time and the compressor moves on shutting down as the knocking could be that noise
May 20, 2017 | Kenmore Refrigerators
Noisy Kenmore Fridge
remove rear panel. make sure compressor is not loose. is noise inside refrigerator or outside at bottom rear?
Jun 24, 2009 | Kenmore 57029 Side by Side Refrigerator
Making lots of noise when running help? please kenmore refridgerator model 25368821790
Hi
  • If the freezer is on top, the fan is on the back wall, near the top or bottom, in the center of the freezer.
  • If the freezer is on the bottom, the fan is on the back wall, near the top of the freezer.
  • If the freezer is on the left, the fan is on the back wall, halfway up or near the top.
  • The compressor is a football-sized case with no apparent moving parts. You can see it on the outside of the refrigerator at the back near the bottom. It is usually black and has black or copper-colored tubes and various colored wires attached to it. If the compressor is the device making noise, there is probably no repair that will reduce the noise. You will have to replace it--which can be quite costly.
  • If the condenser fan is making noise, there may be a build-up of lint or other debris on the fan blade. The fan is located near the back of the machine, sometimes behind a thin panel. To clean it, first unplug the refrigerator, remove the thin panel, and use a soft bristle brush to clean it. If there is no lint build-up or debris on the blade, you will have to replace the motor.
  • The defrost timer is often located at the bottom of the refrigerator, near the front and behind the kick plate. Occasionally the electric motor inside the timer may become noisy. The timer must be replaced to solve this problem.
Please revert for further assistance and Do accept the solution if found useful.
Thanks
Rylee
Mar 18, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Makes a shuddering noise when compressor turns off
It sounds like the suspension spring has broken inside the compressor so when it shuts off it rattles against the case. If the refrigerator is still operating normally I would recommend not repairing it. It could run for years like this without any further problems and a compressor change would be very costly.
Feb 24, 2009 | Kenmore 64254 / 64252 / 64259 Top Freezer...
Frig makes a very loud booming noise/ratteling what is the cause?
The noise is coming from the compressor and is a result of a broken support spring inside the compressor. When the unit shuts down, the inner casing rattles against the outer casing because the spring is not there to keep them apart. The only fix is to replace the compressor but otherwise it is just bothersome.
http://tclaundryrepair.com/home
Feb 19, 2009 | Kenmore Refrigerators
Rattling compressor on Kenmoore bottom freezer refrigerator
IF IS NOT 5 YEARS OLD YET CALL A TECH ASAP THIS MODELS HAVE A COMPRESSOR THAT ARE FAMOUS FOR LOCKING UP AND THE ONLY FIX IS TO REPLACE IT BUT FIRST DISCONNECT AND REMOVE BACK COVER AND RIGHT BY THE COMPRESSOR THERE IS A SMALL BOX ATTACHED TO IT CALL A OVERLOAD REMOVE IT AND SHAKE IT IS IF RATTLES THEN JUST REPLACE THAT PART IF IT DOESNT RATTLE CALL A TECH
Nov 10, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
180 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
