Question about Sanyo Xacti DSC-S1 / VPC-S1 Digital Camera
System error I turned on my camera today the lens zoomed out but the screen then said system error and when i switch it of the lens does not go back. i can't take pictures or do anything.
  • PYTTWINS Mar 24, 2008
    I HAVE A SANYO VPC-E760 N IM HAVING LENS TROUBLE WHEN I GO TO TURN THE CAMERA ON THE LENS CAME OUT N NEVER WENT BACK IN N WHEN I GO TO TAKE PICTURES IT SAYS ERROR 12 AND 25 I DONT KNOW WHAT TO DO ITS NIOT LETTING ME TAKE PICTURES PLEASE HELP ME THANKS
    Genius:
  • 2,985 Answers
Take the Battery[s] out and leave overnight. Re insert battery or if rechargeable, charge them up. Then to morrow reinsert- see what happens.
Posted on May 14, 2007
  • Arnold Madayag
    Arnold Madayag Feb 23, 2012
    Lens errors (system errors on Sanyo's) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Zoom Error
Take it to a repair chop.
Jun 21, 2017 | FUJIFILM FinePix J28 Digital Camera
The lens of my camera wont move back in when i switch it off or back out for when i switch it back on. It then appears on the screen system error (zoom) or sometimes it shows system error (focus)
I had a similar problem and is turned out to be a battery that wasn't charging properly, the camera just didn't have the juice to move the lens.
Jun 27, 2010 | Cameras
I have a zoom error alert on the screen of my fuji j37 digital camera. When i turn the camera on the lens comes out and retracts straight away.
I had this problem for the first time yesterday, on my fifth use of the camera from new. The user manual says to turn it on and off a few times which I did but to no avail. I found advice on a different forum that said to hold your finger over the shutter as you turn it on, so that the lens doesn't have time to retract again. Sort of use your finger nail to hold the shutter up while the lens extends. Tried this and it worked, switched it off and back on agiain and it seems to be going fine now.
May 16, 2010 | Cameras
Lens stuck in out position, screen shows zoom error. How can I fix the problem?
just take out the battery ....charge it ...and put it back....switch off and switch on the camera once....should work fine
May 15, 2009 | Fuji FinePix A345 Digital Camera
Lens error with Canon ixus 970 IS
Has anyone responded to you on this yet - I have had the same problem and don't know what to do?>
Apr 07, 2009 | Canon PowerShot SD890 IS / IXUS 970 IS...
Zoom Error
I think a grain of sand was blocking the zoom tubes. This will not work if the camera has been dropped & the zoom apparatus is bent. It is entirely at your own risk & may invalidate any guarantee but they may charge anyway if you have got sand in. I cut a finger of 80gm computer paper 1cm X 5cm. Inserted this first  around outer zoom tube & worked it all around. It goes in quite deep so be gentle. I switched on to open zoom & tipped out batteries before it had time to close & repeated procedure. When I put batteries back in it worked OK. I repeated procedure with lens fully extended. I found a thin bit of plastic packing worked better as it did not kink so easily. It is still working today having failed 100% before.
Chris
Jul 02, 2008 | Cameras
Fuji FinePix S700 Problem
Try to put it on super macro and see if this will reset the zoom function.
Also try to switch between the settings that allow the digital zoom, as compaired to those settings that only allow optical zoom.
If these do not work, you may have a lens that has been dropped, or is stuck, and may need to be serviced. I have the S700, and have never seen this error before> good luck.
Jun 12, 2008 | Fuji FinePix S700 Digital Camera
Zoom will not retract
Dear Grammie,
You have either experienced a lens error or your zoom dial is broken (both usually caused by some sort of impact damage, but which can be spontaneously occuring).
Look for an error message on your camera's LCD screen such as "E18," or "lens error restart camera." If you do not see a lens error but simply cannot retract your zom lens (go into wide angle mode) via the zoom lever then it simply maybe a broken command dial. Either way, however, you will need to have the camera serviced in all likelihood. Call tech support at 1-800-828-4040 M-F from 8 am to 12 midnight EST and Saturdays until 8 pm EST. Hope this helps.
Sincerely,
HeavyDLB
May 22, 2008 | Canon PowerShot A540 Digital Camera
System error
The following blog outlines some repair options for a lens error:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Listed Fix #4 might work for you. Place the camera on its back, and hold the shutter button down while powering on the camera.
Dec 21, 2007 | Nikon Coolpix 3200 Digital Camera
ZOOM ERROR
I used to get that error all the time with a earlier Fuji FinePix with the slide-over lens cover. If the cover wasn't pushed back completely, the lens would extend only so far and then give an error. Make sure that there's nothing (dirt, hair) on any of the lens surfaces and make sure the lens is fully extending when you do turn the zoom on. Don't let anything touch or bump the zoom while it's moving, either.
Not sure if this will help, since you have a different model. This is what worked for me, though.
Nov 16, 2007 | Fuji FinePix F470 Digital Camera
Sanyo Xacti DSC-S1 / VPC-S1 Digital Camera Logo
214 people viewed this question
Top Sanyo Cameras Experts
Tony
teddyboy
Are you a Sanyo Camera Expert? Answer questions, earn points and help others
