Question about Scanport 821S 17" LCD Display Monitor
Hercules ProphetView 720 Power Adaptor Polarity
I have lost my LCD screen power adaptor in a move and need to replace it with another one. I have a power adaptor from HP which has the same specs, 220V AC to 12V, but am not sure of the polarity.
Is the (+) on the outside of the connector and (-) on the inside or vice versa?
I have surf the web to find this info but did not managed.
Thanks for your support,
Theo.
  • thacasba Jan 03, 2009
    For anyone else's potential interest, I finally found the polarity of my Hercules ProphetView 720 Power Adaptor.
    The Inner pin of the connector that fits into the bottom of the LCD screen is the Positive ( + ).
    As such, the outer part of the connector has to be the negative ( - ).
    In case you have to buy a replacement power adaptor for such a ProphetView LCD screen from Hercules, now discontinued by the manufacturer, output has to be 12V and above polarity respected.
  • 3 Answers
Yes the adapter must have an output of 12vdc AND rated for a least 4.0A output!
Posted on Jul 07, 2009
    Genius:
  • 2,120 Answers
Try eBay?
Posted on Dec 29, 2008
Got a used CTK 720 and it has no power. sugestions
try plugging in without the bateries...Also check your adaptor as well as your ac requirements on your keyboard..It specifically calls for a Casio AD-5 Adaptor.
  • 9V power supply; 850mA
  • Positive sleeve/negative tip This needs to match your adaptor Good Luck
http://support.casio.com/pdf/008/ctk_720_01_e.pdf
Feb 15, 2015 | Casio CTK-720 Electronic Keyboard with...
Power falier
Power failure?
First check the power supply / adaptor to ensure this is working correctly. Measure the voltage using a multimeter - if this is correct move on ( if not replace power supply )
Does the keyboard work if you hold the plug in the socket or move it slightly ? If so this is a common problem as the power socket on the pcb fails at the solder joint and will need to be repaired / replaced.
If this appears to be solid then you may have done some internal damage by either plugging in a power adaptor with a too high voltage or wrong polarity. If this is the case you may have blown some circuitry inside which controls voltage regulation.
Please report more if you have more information.
Jan 22, 2014 | Yamaha PSR-E223 keyboard
I have a Yamaha PSRE413. on/off does not work with adaptor, but works with batteries
If you are using the correct adaptor then the most likely reason is that the socket where the adaptor plugs in has broken away from the circuit board and will need to replaced/resoldered.
if you need a socket Google : Yamaha PSR power socket ( KPA3 / PA130UK / EPA3 ) (LB30226R)
OR if you have used the wrong mains adaptor and the polarity was reversed you may have damaged the diodes / voltage regulator on the power input.
Jan 24, 2013 | Yamaha Music
Power adaptor burned out, how to replace it?
if you know power output and polarity you can purchase generic from an electronics store.
test with voltmeter first.
Apr 09, 2012 | Computers & Internet
Power light comes on but nothing else works.
There is a possibility that your plug on the adapter is the wrong polarity. See if the polarity is marked on your mixer by the power adapter jack.
Feb 03, 2010 | Vestax Pmc 280 DJ Mixer
Missing power cord/adaptor
You just need to go to Radio shack, and get a DC9V Adapter at 500mA and the correct polarity of (-) on the outside and (+) in the center. Original was a AHEAD AC Adapter Model ADB-0900500
Good Luck
Mar 14, 2009 | Cycling
TV will not power up
The original power supply is no longer available but you can get a replacment at Geeks.com part # 60w-12. You will have to change the plug that goes into the tv. The original plug has 2 wires. White(+) and Black(-). Be sure to observe polarity.
Feb 18, 2008 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
Car Adaptor
here is an free 800 number you can call and ask the techs to make positive friend
Polaroid electronics
1-866-400-5168
Hope that fixya up there
Nov 19, 2007 | Polaroid PDV-0700 Portable DVD Player
Power problem
probably "+" you need to check the polarity of the speakers, there should be something like this near where you plug in the power adapter: http://www.accesscomms.com.au/images/reference/powerplug-positive.jpg the above symbol would mean "+".
Feb 01, 2007 | Logitech R-20 Computer Speakers
Scanport 821S 17" LCD Display Monitor Logo
258 people viewed this question
Top Scanport Computers & Internet Experts
William Miller
William Miller
Jerry Umali
richie46
Are you a Scanport Computer and Internet Expert? Answer questions, earn points and help others
