Question about KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher
Kitchenaid dishwasher heater element circuit error
I have reset but error msg cont. I have replaced control panel. Still error msg. Temperature sensor needs replacing?
  • Anonymous Jan 03, 2009
    How did you reset the dishwasher
  • i2_nj Jan 03, 2009
    How did you do the reset
5 Suggested Answers
SOURCE: KitchenAid kuds24se dishwasher DOA
We had same problem - took dishwasher out from counter and found it to be unplugged way way in the back 1
Posted on Sep 22, 2007
SOURCE: Kitchenaid Dishwasher Control Panel lights - some don't light up
control panel light all of a sudden do not come on and my unit wont start model kud101fl
Posted on Mar 25, 2008
SOURCE: Dishwasher Heating element not working
my wife shut the water off to the dishwasher and forgot to turn it back on and then used the dishwasher.
the heating element went on but there was nop water.
when we turned the water back on,the drying cycle does not work.i would think that the element needs to be changed or is there a relay on the computer board?
this is a two year old Jennair unit.
any suggestions?
Posted on Apr 29, 2008
SOURCE: Dishwasher Reset / Diagnostics
Unscrew and remove the kickplate at the very bottom of the dishwasher. The tech sheet with the diagnostic code should be attached to the back of it.  If not, due a websearch and you should be able to find the info on yahoo or google.
Posted on Jan 30, 2009
  • 246 Answers
SOURCE: KITCHENAID DISHWASHER DOOR PANEL
www.applianceart.com has many options for you to choose from. They sell many different panels to put on your dishwasher. If you call them (678-727-4747 x32) they can also send you a metal stainless plate that is easily installed. I think the metal ones are around $99.99 and the other options are $39.99
Posted on Aug 21, 2009
Whirlpool adp 6515ix dishwasher start button is flashing in 4 time cycles-what does this tell me please. None of the manuals indicate what the flashing could be signalling.
Error CodeConditionCheck/RepairShop PartsClean light blinks 7 timesHeater circuit failure. Control didn't detect the expected rise in water temperature.Check the heating element and related components (wiring and control board) in that circuit.
Heating element, Electronic control board, Thermistor, Circuit wiring
Console light blinks rapidlyThe control detects a stuck button on the control panel.A failed control panel or a malfunctioning electronic control board can cause this code. Check the buttons on the control panel using a volt/ohm meter. In most cases, the control panel must be replaced. If that doesn't solve the problem, the electronic control board might be at fault.
Control panel, Electronic control board
Start/Resume light blinks slowlyIf the dishwasher door is opened or power is interrupted during the cycle, the dishwasher won't start again until the door is detected as closed and the Start/Resume button is pressed.Check the door latch and switch assembly. A failure in the Start/Resume button also can cause this problem.
Door switch assembly, Control panel, Electronic control board
Clean light stays onThe dishwasher won't start a new cycle unless it detects that the door opened after the previous cycle.Turn off power to the dishwasher by shutting off the breaker and restarting. If that does not work, the door switch assembly is stuck and must be replaced.
Control lock LED is on but not accepting key pressesAccidentally turned on or control detected keypad problem.Press the Heated Dry key for 5 seconds to turn off control lock feature. If that doesn't work, replace keypad.
Keypad
Sanitized LED blinks at end of cycleControl couldn't confirm that the dishes were sanitized.Check voltage to the dishwasher and the temperature of incoming water. Check the diverter motor, the heater and the OWI/thermistor.
Diverter motor, Heater, Thermistor
May 23, 2015 | Whirlpool Dishwashers
Cancel Light Flashing on Kitchen Aid Dishwasher
I found this post elsewhere. It seems to have worked for me: Our KitchenAid KUDP series dishwasher went into a mode where it would not start and would only respond to the cancel/drain button. The clean light would flash 7 times in a row, stop, and then repeat. I read that the 7 flashes indicates an error code and that the dishwasher has detected a problem in the heater element circuit. I tried to reset the error mode by turning off power for 15 minutes, however, that did not work.
We called for a repair. The service person found that the dishwasher was completely fine except that it had gone into an error mode. The technician reset the error mode and charge us $115.00.
The reset sequence used was reported to be the following:
1) Crack the door open.
2) Within 3 seconds press the following sequence - Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry
3) Close and latch the door
4) Press the cancel button (the circle with the triangle in it)
We were told the dishwasher expects to see the dish water temperature rise in a certain way. If the water does not heat in this way, the dishwasher becomes confused and thinks the heater element has failed. In deed, this happened just following and extended power failure and our hot water tank was cool. I am curious if this code will work for anybody else with the same problem and save a service call and 115 bucks. Overall, this seems to be a serious logic flaw in the design.
Sep 21, 2008 | KitchenAid 24 in. KUDI01FLSS Stainless...
Replace circuit board
If you have not already done so, it might be best to run the controller and circuit diagnostic tests before you replace the parts.
Refer to the instructions from this site.
http://applianceguru.com/forum19/24856.html
It is possible the Thermistor may be faulty causing the controller to believe the water is not heating. This will be much cheaper to replace than the controller.
Feb 15, 2014 | KitchenAid Dishwashers
L65X Dishwasher problem
has there been a soultion mine is doing the same?
Jan 10, 2012 | Dishwashers
I get a te code all the time and a he code from time to time.
from Lg this is the meaning of the codes.
  • The heater circuit has failed if "HE" is displayed. Discontinue use and contact a service technician. The dishwasher requires servicing.
TE
  • "TE" means the thermistor has failed or the temperature of the water entering the dishwasher is over 194 degrees Fahrenheit. Turn the temperature down on the hot water heater in the home. If the error code reappears, replace the thermistor.
    By the sound of this your heating system is malfunctioning and needs service.
    If you need more on this let me know, but it is either your temperature sensor or your heating element or control board.
Oct 02, 2011 | LG 24 in. LD-12BW5 Free-standing...
Green light on control panel constenly blinks
This condition can also apply to a dishwasher that has had the electronic control replaced.
A heater fault detection program has been added to the
electronic control to check for temperature rise and shut
down the dishwasher if a temperature rise is not detected.
The cycles have been modified to add 8 minutes 45
seconds of fixed heat at the beginning of the main wash.
If the temperature rise is less than the criteria, then
the unit will drain and blink the clean light 7 times. The
detection will be ignored if the temperature is out of its
normal range, 64° - 160° F, or the door is opened during
the fixed heat.
Once a heater fault is detected and the condition resolved
the electronic control must be reset by initiating a service
diagnostic cycle.
Sep 17, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
My dishwasher seems to be locked up and needs to be reset. the clean led is constantly flashing. i had this trouble in the past, and the serviceman reset the dishwasher by using the touchpad on the front...
Control is programmed to
stop the current cycle and
not allow any further
cycles if it suspects a
faulty heater (no
temperature increase
detected in heated
intervals). Control blinks
the Clean LED 7 times in
repetitive fashion and
disables the Start/Resume
key until cleared.
Heater circuit problem:
■ Open in heater.
■ Open connection or
component in heater
circuit.
■ Faulty heater drive
circuit on control.
Running Diagnostics clears the control and
allows it to operate again. If heating problem
is not corrected though, the control will stop
running again on next cycle. See below.
1. Unplug dishwasher or disconnect power.
2. Check all components and connections in
the water heating circuit or heat dry circuit.
■ Check resistance of heater.
■ Check resistances of all connections and
components between the control and
heater.
■ Check operation of heater and temperature
sensor in Diagnostics cycle.
Aug 26, 2010 | Whirlpool 24 in. GU3200XTP Built-in...
Does not dry dishes..still wet and spotty after cycle ..already have replaced control panel..now it reads HE
The reason it would not be drying is because either the rinse aid is low or the heater element is faulty. Not sure why you replaced control panel.
HE means the heater circuit is tripping. if you are using hot water direct from the tap then the water temperature could be too hot. If using cold water then the heater element could be faulty.
You can try some diagnostics if you are confident to do so. The details are in the service manual
http://136.166.4.200/contents/Dishwasher/LDS5811/LDS5811_Service_Manual.pdf
Jan 20, 2010 | LG 24 in. LDS 5811ST Stainless Steel...
How do you fix a heater circuit in a kitchenaid diswasher?
IF YOU NEED TO ASK THEN YOU SHOULD NOT BE DOING IT
1 DISCONNECT WATER AND ELECTRICITY.
2 REMOVE MACHINE. TURN UPSIDE DOWN (DO THIS ON A COUPLE OF TOWELS AS THERE WILL STILL BE WATER IN THE MACHINE.
3.REMOVE BASE PANEL
4 YOUR LOOKING FOR THE OVER TEMPERATURE SWITCH (LOOKS LIKE THE BACK OF A STAINLESS STEEL WATCH) REMOVE FLY LEADS & TEST THIS FIRST IT SHOULD BE CLOSED CERCUIT. IF IT IS CLOSED CERCUIT ATTACH LEADS AGAIN.
5 AFTER THE ABOVE REMOVE THE FLY LEADS FROM THE HEATER ELEMENT AND TEST (IF ITS CLOSED CERCUIT YOUR PROBLEM IS NOT THE HEATER ELEMENT, IT PROBABLY THE CONTROLLER, IF ITS OPEN CERCUIT NEW ELEMENT REQUIRED, TAKE CARE TO ENSURE THAT THE SEALING RING BETWEEN THE ELEMENT HOUSING AND THE INSIDE OF THE DISHWASHER IS SPOTLESS BEFORE YOU PUT THE NEW ELEMENT IN ( A LEAK HERE IS A NIGHTMARE TO CORRECT ONCE YOU HAVE PUT THE WHOLE THING TOGETHER AND CONNECTED THE SERVICES.
Nov 05, 2009 | KitchenAid 24 in. KUDP01DL Built-in...
Clean Light Flashes
Oct 07, 2006 | KitchenAid 24 in. KUDI01FLSS Stainless...
KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher Logo
141 people viewed this question
Top KitchenAid Dishwashers Experts
Mike Cairns
Mike Cairns
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
