Question about Hotpoint Ovens
Vintage Hotpoint Customline wall oven needs thermostat, timer
I need to find information and sources for repair parts for this vintage oven. It heats, but the clock and timer do not work, the probe is missing, and the thermostat seems to be off as it appears to get too hot. The rubbery gasket is also missing except for a strip across the top of the opening on the oven side, not on the door. If there was one on the door, there is no sign of it now.
I can read a serial number of 1278447, but the Cat No. is hard to read. My best guess is 102366601 with the first 3 and last one digit the hardest to be sure of.
There is also a push-button switch in the bottom center of the control panel that I am unsure of. The button directly above it turns on the oven light.
Based on the age of an extensive remodel on this house, I am guessing it is from the late 60's to early 70's in age. It is in otherwise excellent condition.
  • 248 Answers
SOURCE: Kenmore 47779 double oven; lower oven doesn't work after self clean
Sounds like a thermal overload has opened up during clean. It may be mounted on the back.
Posted on Nov 04, 2007
  • 2651 Answers
SOURCE: GE Profile -Installed wall oven - won't heat
brand new??? under a year old??? if so you have a warr call for service, but it sounds like an ignitor isssue, brand new , perhapsgot damaged in shipping 1-800-ge-cares
Posted on Mar 30, 2008
  • 114 Answers
SOURCE: Oven digital lighted display is dim
I replaced the C3 capacitor on the circuit board and works fine. This was mentioned in a prior post and took 5 minutes and was under $5.00 for the part.
Posted on Mar 21, 2009
  • 6784 Answers
SOURCE: My clock and temperature display is dim
Hi, this will happen over a period of time and its just heat related. the control panel isn't insulated properly and , there has been a larger than normal transfer of heat to the inside of the control panel where the circuits are housed.
If this is a problem, i recommend replacing the control board. it will fix the dim issue.
Posted on May 22, 2009
  • 7 Answers
Try here:
Posted on Apr 14, 2011
Do you have a thermonstate for a preway wall over - model 501-1
  • Range/Stove/Oven Thermostat Parts In Stock from ... Shop for your Range/Stove/Oven Thermostat from our ... What is a model ... Repair Help. SEARCH. Range/Stove/Oven. Thermostat. Clear All. Range/Stove/Oven Thermostat ...
  • Preway Wall Oven Parts ' Sears PartsDirect > All Brands > Preway Parts Shop the best selection of Preway wall ovens repair parts and accessories at Sears PartsDirect. ... Preway Wall Oven Parts ... Model retention may be affected by your ...
  • Preway Oven - Network54 Preway Oven February 27 2005 at ... I like you was searching for information on parts for a Preway wall oven we have in our ... I have the manual on the oven. The ...
  • Mar 24, 2016 | Ovens
    I have a used wall oven. How can I test it before installing to make sure it works?
    call an electrician to wire it on an extension cord .
    Nov 23, 2015 | GE Ovens
    The top oven is over-heating with no change in temp display. A red-hot heating element on the left side of the oven (facing it) shows through the floor of the oven.
    Good Morning Eileen, thank you for your inquiry!
    I understand that your Electrolux double wall oven is having over heating issues. It is possible that this could be a faulty thermostat, control panel, or element. Since it could be anyone of these underlying having a technician out would help avoid any unnecessary part purchases. If you need help locating a technician you can visit your manufacturer's website for additional assistance with locating a technician. I hope this information is helpful to you. -Matt
    Aug 09, 2015 | Electrolux 27" Built-In Double Electric...
    Early 1960's Frigidaire 24" Double wall oven not heating
    Hello Chris Hammond, thanks for your post!
    Based off the information you have provided it sounds like a potential problem with your connector for your element within your Frigidaire wall oven. I would recommend reaching out to a professional technician for proper diagnosis repair to help avoid any unnecessary part purchases. Best of luck! -Matt
    Nov 07, 2014 | Ovens
    Hotpoint 24in double electric wall oven 20RJ83D not heating, element is working
    The thermostat for the upper element has gone bad. Needs to be replaced.
    Apr 15, 2017 | Ovens
    Trying to find a bake element for the small side oven on an older westinghouse model #KF745MXW1 or KF745MYW1...serial number KNC21616
    I have found the part # for it it's 5300207851 however searching all my parts supply houses that i normally use they say it's no longer available. Perhaps it may take some searching on your part but having the part number will possibly help you find it. Their is some places that restore vintage appliance and info on them could be found by a google search for vintage appliances and perhaps they may have one they need to knock a ton of dust off of and ship to you.
    Good luck,
    Aug 12, 2011 | Ovens
    278.4088891 Kenmore wall oven. The display goes black
    Sounds like the "display" part of the timer is faulty or has a bad connection. As the cooker still heats up then the "relay" is working ok.
    A replacement timer will be roughly £70 - £80
    Hope this helps
    Aardvark Repairs
    Nov 15, 2009 | Hotpoint UY46 Style Line Stainless Steel...
    Oven not working
    You need to detrmine if you are getting a supply to the oven element, if you are , then the new element is faulty, if no supply, then you are going to have to work back from source.
    Please rate my solution.
    Jul 21, 2009 | Hotpoint DY46 Style Line Stainless Steel...
    I have a F0 on the display of my double oven JTP45 model
    Giggles01: I wish I had an answer other than calling GE. We are about to install a used oven of the same model/same vintage. I've been unable to locate a manual and need some information from it. Would you be willing to tell me the cut-out size the manual calls for regarding the installation of the oven? Most 30" ovens require a 28.5" cut-out, and I need to confirm that for the JTP45. Thank you!
    Mar 09, 2009 | GE JTP45 Electric Double Oven
    Ovens Logo
    1,143 people viewed this question
    Top Hotpoint Ovens Experts
    Jason Harris
    Jason Harris
    Colin Stickland
    Colin Stickland
    Are you a Hotpoint Oven Expert? Answer questions, earn points and help others
