Question about Insignia Digital-to-Analog Converter for Analog TVs
Insignia digital converter box NS-DXA1 saying no signal
I went to the online manual you posted and began looking up the troubleshooting pages. I passed the "Controllable Brands" page on the way and found Philco listed, but not Philips which is my TV's brand. Both Tandy and RadioShack were listed, so I'm wondering if the box is incompatible with my flat-screen. (turtleboo)
  • 2 more comments
  • turtleboo Jan 10, 2009
    Dear ****,
    You rock! Thank you for the second set of instructions. I made sense out of those and it did work! Even the factory was wrong, but you were right!
    Thank you, thank you, thank you!
    turtleboo
  • Anonymous Jan 15, 2009
    new channel master anitanna and analog box and still no signal
  • cels Jan 15, 2009
    HELP!! I have a similar problem. new "smart" antenna & insignia converter box. Antenna directly to tv works, doesn't work through converter box. seems like converter box doesn't think antenna is connected. always says "no signal" & doesn't find any channels.
  • mairce Feb 03, 2009
    I have a problem, I hooked the converter box up to my TV and had to get a new dig indoor antenna, after doing that, I got about 9 channels much more clear then ever before, the only problem now is that I cant hear them, it sounds like static, with the sound all jumbled. Now I have a picture, but cant hear the sound over the static noise, any suggestions - (I already moved the antenna away from the TV and I have it now taped in a window - that is what the troubleshoot instuctions said to do - and it did not help.
    President:
  • 948 Answers
Connect your Insigna unit to your television video 1 input. Connect your antenna to the Insigna. Turn on the television to video 1 source. Power on the Insignia. Now go through the auto-detect routine to set up your television stations.
Posted on Jan 01, 2009
  • Dick
    Dick Jan 10, 2009
    You're welcome. Thank you for letting me know it worked for you, and for rating the solution.
I own an Insignia flat screen tv, NS-LCD27, & I was given the Insignia converter box, NS-DXA1; how do I program tv remote for the box? Thanks, frances b.
The digital to analog converters did not exist when the TV was built and the remote programmed. Thus you will have more luck programming the converter box's remote to control the TV. (At least with my converter box, the included remote could only turn on and off the TV. It would only change channels on the converter.)
Most universal remotes only have codes for devices released 6 months or more before the TV was programmed. So a new universal remote will probably control both the TV and the converter box. (Program the converter box using a code for LG or Zenith set top boxes if Insignia isn't listed. LG makes Insignia video products for Best Buy.) The remotes that are programmable by a USB connection to a computer are the fastest to set up.
A replacement remote for your TV is available here: http://www.mcmelectronics.com/partfinder.aspx?brand=&mdl=NS-LCD27&mode=part . An exact replacement remote for the converter box can be purchased at: http://www.remotes.com/remotes/servlet/rs?a=gmi&uuid=13055197980390&smodel=NSDXA1&brand_pn=INSIGNIA_NSDXA1 . The manual for the converter box (as a PDF) is here: http://cbsdallas.files.wordpress.com/2011/01/insignia-ns-dxa1-manual.pdf .
I hope this helps.
May 16, 2011 | Insignia Televison & Video
I need to program a universal remote, a ge modal249 my Insignia modal NS-DXA1-APT digital analog converter chgang4895@yahoo.com
Since Insignia and LG share compatible codes for digital-to-analog converters, review your remote control's manual for LG VCR codes as they should work to control our converter.
Apr 19, 2010 | Insignia Digital-to-Analog Converter for...
Programming Insignia Digital Box to Phillips Universal Remote
I have the Phillips Universal Remote (model#SRU4208WM) and I have the Insignia digital converter box (model#NS-DXA1-APT). The code was 0267. The Insignia converter box is the one the government grants work for.
Feb 03, 2009 | Insignia Digital-to-Analog Converter for...
No set-up menu from insignia ns-dxa1 converter box
Set your television to channel 3. Then power on your Insignia unit and run the auto-search function as described in the user manual found here - http://www.insignia-products.com/skins/skin_1/Topics/Documents/07-576_NS-DXA1_WEB.pdf
Dec 29, 2008 | Insignia Digital-to-Analog Converter for...
Insignia NS-DXA1 - Digital to Analog converter box
I have had my converter box 5 days now. I hooked it up to the TV and set it up. No Problem. Except there are no instructions on how to set up the VCR/DVD player with it, which we use more than we do watching TV. Everything worked fine until on the second day we had it I read I could program the remote to turn the TV on and off. I followed the instructions and the TV went off. When I turned it back on, my remote went berserk. If I try to change a channel it will quickly flip through all the channels until I turn the converter box off. Same with the volume, it goes up and down, up and down until I shut off the box. The remote does not work unless you are about 1 foot away from the box. And the remote has never turned the TV on or off except that first time I programed it.
May 19, 2008 | Insignia Digital-to-Analog Converter for...
Insigna ns-dxa1 converter
You might try useing a higher bandpass diplexer
Apr 24, 2008 | Audio Players & Recorders
Insignia Digital-to-Analog Converter for Analog TVs Logo
811 people viewed this question
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
jason
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
