Question about Sony DAV-DX255 System
What would be the best,correct sequence to wire these three sony products together. sony home theater system ht-ss2300 and a sony blue ray dvd player and a sony 46" flat screen
Hook the tv with rca cables that says audio out and then into the back of the reciever that says audio in. then put the blue-ray player(audio out) into the tv in aux. inputs. Then u r ready 2 go.
Posted on Apr 08, 2009
How do I connect my Sony soundbar ht-ct 260h to my blu ray player etc, I have no optical port or arc hdmi port,at the moment connected through the audio lead to soundbar & tv ?
hook your dvd player up to the tv via hdmi, then take the optical audio output from you tv to the soundbar. Make sure to enable to audio output jack in the tv setup menu as some manufacturers disable this jack by default.
Mar 30, 2015 | Sony HT-CT260H Soundbar and Wireless...
No blue ray
If I remeber correctly, the Samsung HT-Z310 is a dvd system.....not blu-ray. Won't play blu-rays - never has, never will.
Jan 01, 2014 | Samsung HT-Z310T Theater System
I have a panasonic viera flat panel plasma tv and a samsung 5.1 ch blue ray home theater system and the speakers work fine on the home theater system while playing a dvd, but does not work when watching...
1. The easiest solution would be to connect a stereo RCA (red and white) cable to the audio output on the back of your TV.
2. Then connect the other end to the input on your home theater system.
3. Change the home theater system to the correct input.
Feb 12, 2011 | Samsung HTC550 Theater System
I have HT-SS2300 Home Theater. I have to set the sound on MAX just to hear it at normal level. It is hooked up with digital sound cable.
Using its internal FM how does it sound? (No cables involved). What about speaker calibration, testing and setup?
Is MUTING ON? Turn it OFF.
Never use MAX volume for anything. If you finally move the control or otherwise resolve the problem you'll damage the speakers.
Operating instructions here:
Jan 17, 2011 | Sony HT-SS2300 Blu-ray Disc? Matching...
Is it possible to add a Sony Blue Ray DVD player (model BDP-BX57) to this Samsung Home Theater system?
Yes it is. What you need to do is connect your blu-ray video output either HDMI or Component directly to your tv, and the audio output of your blu-ray should be connected to the digital coaxial input on the samsung system
Jan 03, 2011 | Samsung HT-TX72 Theater System
I have just installed a HT-S6100 at home and works perfectly with a Blue Ray Samsung player (via HDMI). I also have a Sony DVD player with component cables I want to connect to my HT-S6100. I followed the...
There seems to be a lot of this type of lack of signal (video, audio or both) with this system. I have the same system and the same problem. Mine is working now. I'm using all HDMI connections. I think the other important thing to do is "delete" all Input Assignments that are not being used. By "delete" I mean set the Input Assignments to "----". Let me know if this helps.
Dec 14, 2009 | Onkyo HT-S5100 Theater System
No sound from speakers when tv is on
It is likely that you do not have an HDMI cable connecting your cable/satelite set top box to the reciever. If you you run coxial striaght to your TV you will need a digital tuner and run the audio componet cable to the receiver and picture cable to the TV. Also be sure that TV out is perferably with optical audio. Hope this helps. If not its all listed simply in the owners manual. Try Sony's website if you lost it.
Apr 05, 2009 | Sony HT-SS2000 Theater System
Wiring problems
Not certain if HDMI can be used in a setup like this. I'd try it from the home theater (HT) to the TV, and other wiring for the other components.
For video:
All of these should have component connections (Y/Pr/Pb). You'll only need the video cables for each device:
  • Video out from cable, HT, and combo player.
  • Video in to TV. Your choice of inputs.
For audio:
Hopefully, the two output devices (the combo player and the cable box) have digital audio (fiber optic, or RCA coaxial). Otherwise, you'll only get stereo sound. VHS is stereo only anyway.
  • Audio out from cable box and combo player.
  • Audio in to HT.
The TV won't have anything to do with audio in this setup. Alternatively, you could try hooking up all inputs to the TV, and connecting audio out from the TV to the HT. Works best if this connection is digital, for surround.
Jan 01, 2009 | Sony BRAVIA DAVHDX275 Theater System
Sony DAV-DX255 System Logo
130 people viewed this question
Top Sony Audio Players & Recorders Experts
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
