Question about Samsung DVD-VR345 Super Multi VCR and DVD Recorder
Samsung dvd vr345
My dvd player will not "finalize" discs. it simply locks up, and you need to unplug unit to reset it. it has been sent to samsung, and, obviously, was not repaired.
  • 1003 Answers
SOURCE: DVD player says "no disc"
replace the player because laser lens is probably burnt out.
you can get a new player for 30 bucks at target or walmart
Posted on Jan 15, 2008
0 characters
1 Points
My vbr120 blu ray player frequently locks up when downloading netflix movies or tv selections, requiring me to unplug the player to reset.
I have the same problem. While I don't have the permanent solution, I can tell you a few things. 1) You don't need to unplug, simply hold the power button down on the unit until it does a full reset (it normally just goes into standby mode when you tap the power off button). 2) I've noticed the locking only happens if I try to watch a netflix after I've used an optical disc between resets. IMO, I believe it's a problem with the system memory not updating and won't be solved unless they put out a specific firmware upgrade for it (unlikely on such a cheap player).
Feb 06, 2011 | Vizio VBR120 Player
Samsung dvd vr-357; recorded DVD only plays on the player
You have to "Finalize" the disc before it will play on other units. Go to Disc Menu, Second choice listed(not in front of it right now) Selections to right will offer disc Finalize. Say YES.
Jul 19, 2009 | Samsung DVD-VR357
Try doing a hard reset.To do a hard reset unplug all the cords from the back of the unit for 4 hours,even the power cord.After 4hours. plug in all the cords again and then turn on your player.This should fix the issue.
May 16, 2009 | Panasonic DVD-A110 DVD Player
Can not read disk
I just sent my BDP-S300 in with same problem...the tech told me he couldn't duplicate the problem and I think I know why...the fix is to UNPLUG the power cable and leave it unplugged for a minimum of 2-3 minutes...this process clears the internal memory; it seems that if you don't clear the memory, it won't read any disc because the unit thinks the same 'problem' disc is in the drive... (don't simply hold down the power button for 5 seconds - that will 'factory reset' the unit to default settings and you will have to reset your video / audio settings) have to physically unplug the unit from the power source...If I had waited a little longer before repowering the unit, I wouldn't have had to send the unit in (obviously the unit was without power during shipping and when it was powered up, internal memory was reset and thus did not indicate any problems). One more trick I learned is this - If a disc won't eject, turn the unit off, and instead of using the Power button to turn unit on, use the Open / Close button...the tech said the unit will then eject the disc before trying to read it...Hope this info helps!
Jun 20, 2008 | Sony BDP-S300 Blu-Ray Disc Player
DVD Player won't open
Try this. This works on some brands and models.
Power up the unit. Using the remote, press and hold the 'STOP' button for about 5 seconds. Release and press the 'OK' button.
Jun 18, 2008 | Samsung DVD-V4600 DVD Player/VCR
-R and +R auto-finalize, only +RW and -RW require manual finalization - if the option is no longer available, it is because the discs are already considered finalized by the player. If the disc edit option is greyed out, and you cannot play the discs in another player, then the recorder will need to be replaced b/c it is consistently producing bad recordings. Try unplugging and replugging the recorder once just to be sure it isn't a temporary problem.
May 22, 2008 | Philips Magnavox DVD/VCR Dual Player
Samsung dvd-r135
The Disc Tray Will Not Open And/Or There Is A Disc Stuck In The Player. spacer.gif Some DVD Players manufactured prior to 2003 have a Dealer Lock or Child Lock function. This will prevent the panel buttons from operating.
This function is activated by pressing the STOP button on the front panel
and the POWER button on the remote control simultaneously for four seconds in the power on state. Repeating this sequence releases the dealer lock. When the dealer lock in activated, DEALER LOCK ON or DEALER LOCK OFF scrolls on the display.
If this does not resolve your problem there may be an error with in the player. To resolve this try the following these steps:
  1. Unplug the DVD player from the electrical outlet and leave it unplugged for thirty seconds.
  2. Plug the DVD player back in to the electrical outlet, but do not turn the DVD player on.
  3. With the DVD player off, press the [Open/Close] button on the front of the DVD player. The home theater should power on when you press the [Open/Close] button and eject the tray.
The second option worked for me...
Apr 12, 2008 | Samsung DVD-R135
Disc removal
This is what LG customer service will instruct you to do. I have a LG LDA-511:
1. Unplug your unit.
2. After unplugging, wait a few seconds then press and hold the power button (yes, while the unit is unplugged). This resets the unit.
3. Plug in your unit.
4. Press the eject button.
If the disc does not come out, then you need service from an authorized service representative.
Feb 03, 2008 | LG LDA511 DVD Player
Samsung R155 Recording from VHS Issues
The reason why you are having this problem is because you haven't finalized the disc. In able for you to play that Burned DVD that you have you need to Finalized the disc. Finalizing a recordable optical disc means writing the disc's lead-in (the Table of Contents or TOC) and lead-out information (blank data that fills up the unused space at the end of the disc) so that a DVD player will know where the various tracks begin and end. Without the TOC, a conventional DVD player will not be able to read the contents of the disc. Once the disc is finalized, no more information can be written to it. Finalizing takes about two or three minutes. To finalize a DVD-RW/DVD-R: 1. Press the Menu button with the disc stopped. 2. Select Disc Manager and press Enter or the right arrow. 3. Select Disc Finalize and press Enter or the right arrow. You will be asked twice if you are sure that you want to finalize the disc. Select Yes and press Enter. Once the disc is finalized, you cannot delete entries from the record list. After being finalized, the DVD-R/DVD-RW (video mode) operates in the same manner as a DVD-Video. Recorded discs must be finalized in order to play back in non-Samsung DVD players. A DVD-RW disc that has been recorded by DAO (disk-at-once mode) in a PC cannot be unfinalized. A DVD-RW disc that has been recorded in Video Mode on a non-Samsung recorder cannot be unfinalized by a Samsung recorder. A DVD-R disc cannot be unfinalized. Note: Finalization does not apply to DVD-RAM. If you cannot finalize a DVD-R or DVD-RW disc, make sure that Disc Protection is turned off. If you are still having difficulty, you may try calling technical support of SAMSUNG. Note: Do not turn the recorder off while it is finalizing the disc. Data on the disc will be damaged if the finalization process is interrupted.
Sep 17, 2007 | Samsung DVD-R155
Samsung DVD-VR345 Super Multi VCR and DVD Recorder Logo
42 people viewed this question
Top Samsung DVD & Blu-Ray Players Experts
Are you a Samsung DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
