Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
Replace clock timer
I bought the board that needs to be changed but dont know how to do it.
  • 640 Answers
Ok bobo lets go....always unplug unit first...pull the range from the wall,,,best if you get behind it if you can,,,now you those 8 phillips head screws around the top back of console..remove that bact console panel...now there 4 screws holding the clock in remove screws but not the wires..let the old board just hang from wires,,your close now ...put new board in there did you get the overlay with the new board ,,no..so take that flim strip overlay of the old one,,ok mount the new clock put back for screws,,,take the old clock timer connection off one by one and put on new clock ,,...you did it,,,just reverse to put together,,,
Posted on Dec 29, 2008
Replaced EOU43002X element, clock/timer now dead
Make sure there is power to the timer. Should be a fuse somewhere.
Mar 19, 2014 | Electrolux Ovens
I only have a fan, clock and timer that works...I need a schematic to find out which part to replace ...I replaced the relay board and that is how I got the clock fan and timer. Just have tried so many...
Is this a gas or electric oven? One cannot begin to troubleshoot until this is determined. What is the make and model?
What is it not doing?
Nov 03, 2013 | Ovens
Hotpoint oven bs43
you need to send the full model number,most likely you have a bad clock assy.even though your clock might work it comes with the clock and a computer board all together.i never heard of resetting a timer,i do know that if you unplug or shut down the power from the fuse box for 5 to 10 minutes sometimes resets the computer just like a regular house computer, it sounds like your loosing power and i don't think resetting anything is gonna help you,also make sure you have 240 volts going to the oven,but if the fan and light are not working and no heat it sounds like you have a bad clock assy.if it's in good shape and depending on the age you might want to call someone in to check it for you,if it is the clock assy. it might not be avalable anymore but there are companies that can rebuild the clock assy. you have.good luck with your oven.
Jul 10, 2013 | Ovens
My GE wall Oven Model #jctp18ba1bb is not working.the board is blankm the only thing that works is the oven light.Is there any kind of thermal fuses etc. in this oven.thge control board was replaced 8...
When you say board I assume you mean the electronic clock/timer. This timer directly affects the oven operation. Even if the internal oven fuse is blown or the thermal overload is tripped the electronic timer and oven light will always work. If the oven light works and the electronic timer/clock does not I'd say that the timer/clock is faulty.
Feb 10, 2011 | GE Profile 30" Built-In Single Electric...
I didnt get a user manual with my creda cooker dont know how to set the timer
try this site for your manual
kitchen.manualsonline.com/manuals/.../creda/creda_oven_product_list.html
hope this helps
Apr 28, 2010 | Ovens
Hi I have a Tappan oven model TGF357CCSF. The clock display andtemperature display is working but it is very dim. I have been told the I need a control panel 316028350 which is no longer available is this...
Hey - That part is available thru AppliancePartsPros online listing is clock/timer.  Part # AP2125110     $203.75   These timers are old-timers anymore. Can be hard to find, and at 200 bucks, make ya think twice. Gas model is probably worth it though.  Either way- it's an electronic clock that has had 120v running through it for 20 yrs or so. Time to replace for sure. Let me know if this info helps-  have more if needed-  Thanks--Ed
Mar 16, 2010 | Ovens
Oven will not stay on
HI. this is a control fault that can be confirmed by unplugging the unit for 5 minutes. if the control continues to cycle from auto to manual, replace the control board(EOC/Clock)
May 28, 2009 | Ovens
Display light faded and now gone
Supposedly the electrolytic capacitors on the display board need to be replaced. See: http://applianceguru.com/forum1/18842.html
Jan 15, 2009 | Thermador SC302T Electric Double Oven
F2/E1
F2-E1 - Touch Pad (Keypad) Cable Unplugged -
Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure.
Select the 'cancel' function and wait 60 seconds.
If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
It appears your timer/clock has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&^%$#
Jul 12, 2008 | Whirlpool GBD307PDS Electric Double Oven
Cannot set clock Model RBS245PDB2
you need to replace the clock timer board..
Aug 09, 2007 | Whirlpool RBS245PDS Electric Single Oven
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
102 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
