Question about IBM 3581 Ultrium Ultrium Tape Drive
3581 Autolder problem
The two rubber rollers are damage. Can you help me with the part number?
Thank
    Problem Solver:
  • 6 Answers
You can try nsasia@hotmail.com i send my IBM 3581-H17 there for repair and upgraded from IBM 3581-H17 to IBM 3581-H23.
They do advance replacement too.
Posted on May 06, 2009
3581 Err 7
Cartridge compatibility problem
Dec 23, 2011 | IBM 3581 Ultrium Ultrium Tape Drive
I dont have a problem I just need to know what product I need to clean the rubber rollers on a weekly basis
Using liquids & chemicalsmay damage the rubber rollers or harden them. It is not at all necessary to clean the rollers on weekly basis. Instead you may clean them once a month with a soft, lint free cloth damped in luke warm water to remove any dust. Rubbing the rollers excessively may damage the rollers.
Also, keep the printer in a clean dust free environment and keep the printer covered if not in use for a long period of time.
Hope it helps! Good Luck!
CreativeTECH
Mar 30, 2011 | Panasonic KV-S1025C
Proform Crosswalk Dual Motion Cross Trainer Treadmill. motor works great. Rubber on right side under the moving belt has come off so belt slips when in use
I think you are talking about the front roller. It has a rubber sleeve that helps to grip the walking belt. Sometimes you can tighten this enough to keep it from slipping but you run the risk of overtightening and damaging both rollers. We recomend replacing that roller.
Oct 24, 2009 | Proform Crosswalk 500 Treadmill
I need the authorization numbers of my adobe photoshop cs2.
You will have to either contact adobe, or purchase a legitimate copy.
May 31, 2009 | Adobe Photoshop CS for PC
Can I disable the lower print tray?
Hi wogan2:
Normaly when you get this problem it means that you need to replace the feed rollers in that tray.
Inspection
Rollers:
Replace the rollers when you see any of the following defects:
 Flat spots
 Out of roundness
 Cracked rubber
 Loss of traction (tackiness) causing pick or feed failures.
Xerox paper pick roller
Part # 401-0882-00
Hope this helps
May 21, 2009 | Xerox Phaser 8200 Laser Printer
No power on IBN 3581 L28 Autoloader tape drive
I believe you can get Repair / Power supplies from Sanwork.com.
Mar 23, 2009 | IBM 3581 Ultrium Ultrium Tape Drive
Royal Cash Register
Hi. There are several reasons for this.
The most common one is not replacing the ink roller on time. If the old roller had felt falling off of it, then it will block up the drum.
The second is re-inking the roller. If you do this, you end up with a sticky mess and a lot of smudging.
Other than that, pieces of paper stuck in the paper path are common.
You should inspect the drum again. This is the little group of rubber numbers that spin around and hit the paper while printing. You will usually find sticky muck on the numbers, and you may have to clean them several times. You need to turn the drum as you clean it. Try to use the gears at the side if they are visible. A dry Q-tip is best, as alcohol may damage the thin rubber. Try cleaning the drum again, and look for any improvement. If itgets better on some numbers, then you are probably on the right track. Also, if you could send me a picture of the bad print, that may help also.
Good luck.
Mark
Aug 09, 2008 | Casio Parts Cash Register PC Desktop
Error on IBM 3581 tape library.
Error 5 states that there is a problem with the drive and not the library, either the tape path or read/write head. Replaced drive - works fine
Apr 01, 2008 | IBM 3581 Ultrium Ultrium Tape Drive
How do I clean the Fuser Roller
Metho.
No use inkjet stuff in laser machines.
May need to replace Fuser.
Dec 25, 2007 | IBM Infoprint 8 Laser Printer
Help
hi im jules_09,check the fuser unit paper are folded because the rubber roller is worn out then the black line is also cause by scratch or damage upper or hot roller in the fuser unit.if the hot roller or uuper roller is fine check the drum unit if the opc drum is damage or scratch then check also the drum cleaning blade or roller,blak line in copy indicate one or two part either in the fuser unit or drum unit is damage.
Nov 15, 2007 | Panasonic FP-7735 Black and White Copier
IBM 3581 Ultrium Ultrium Tape Drive Logo
295 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
