Question about Nintendo Wii Fit for Wii
I'm trying to go through the setup to WII fit. My child did the body test with no problems a couple of days ago. I keep getting an error (fidgeting) when I try to take the body test.
  • 3 more comments
  • gobrigavitch Jan 02, 2009
    Wii board constantly tells me I'm fidgeting and the green blob is way off to one side. I thought the board was defective, but I'll try the setup screen that I've read about and see if I can sort it out.
  • norcrosa Jan 22, 2009
    I am having the same problem. The board was working fine for about 3 weeks and then today for no reason it keeps giving us an error and/or says to push A because we are fidgeting. I can get it to go through the body test, but the it completely wrong, weighing us about 24 pounds less and the balance tests are impossible and completely wrong. HELP!
  • Anonymous Jan 27, 2009
    Please please please help, my centre of balance is way off, i clicked she settings bit to test it and it said that the balance board is not functioning property and the top left part of the board had a cross on it. It said to refer tot he manual but i cannot find that anywhere is there anything else i can do to fix it?
  • Anonymous Jan 31, 2009
    Exactly the same thing the guy tried to do the fix for this probablem wasn't helpfull at all. What more information do you need. You stand still. The fit says your fidgeting. End of story. No thick carpet. No weak bateries. No fidgeting.
  • gobrigavitch May 11, 2010
    I thought your help was not very helpful at all. If you read the problems we are having you would see that we have done all of the steps you suggested. The boards are malfunctioning. They won't center when they had been every time before that. They also say they are defective on the setup screen and advise calling support. My guess is that one of the 4 sensors has quit and that is why everything is so scewed to the opposite side.
    I don't think it is a fixable problem. Replacement seems to be the only solution
    Sniper:
  • 80 Answers
Please be a bit more detailed in the problem. The Wii Fit Balance Board is very sensitive to weight shifts. Ensure that you allow the board to calibrate properly. To do this, I would suggest the following steps:
1) Place balance board on a sturdy, flat, smooth surface. If you have average-shag carpet, be sure to use the little adapters that fit over the feet. If the carpet is too thick, then it will NOT work properly. You may want to consider a small piece of plywood or something similar to set between the carpet and Balance Board.
2) Don't step onto the board until it has calibrated (this is when the board establishes its zero point). It will clearly say "Starting Up" followed by "Ok, Step On." After this, you can generally stay on the board unless a particular routine asks you to get off or for some reason it needs to recalibrate.
3) Finally, you must ALWAYS back out all the way to the Wii Fit Plaza (where you pick your Mii) if you change players. Once the board is configured for one player, it will only be suitable for that individual. Its sensitivity is based on an individuals weight. For instance, if the board is calibrated for a 3-year old's Mii, and an adult decides to play any of the routines on that Mii, the board will be over sensitive (calibrated for the lighter weight). Conversely, if an sdult's Mii is selected and a child plays a routine, the board may not detect the movement.
I hope these steps will help. If not, please offer a step by step explanation on what you are doing and I will try to reassess your situation.
Thanks!
Posted on Jan 27, 2009
  • VentureForth Feb 02, 2009
    I appreciate your honest comment to my suggestion. I would have assumed that if the sensor is bad (and says so on the troubleshooting), then that is not a problem ANYONE here can fix, therefore I did not include the most obvious solution which is, of course, calling the manufacturer.
  • VentureForth Feb 04, 2009
    In addition, please reserve a rating of '1' for truly inappropriate replies. If the suggestions are not helpful at all, a minimum rating of '2' is appropriate.
    Thanks for using Fixya.
2 Suggested Answers
  • 80 Answers
SOURCE: I'm trying to go through
If your Wii Fit Balance Board is on carpet, be sure to use the extra foot pads that came with your board. If your carpet is really thick, you may need to use a flat woodend board to set the balance board on.
Finally, make sure that you are NOT using your child's Miii to do your own balance test. Each user of Wii Fit must use their own Mii character.
If you don't like my suggestion, please don't rate this suggestion a '1'. If my suggestion doesn't help, the problem may exceed the scope of what can be answered here. You will need to contact Nintendo directly through their website and open a problem ticket.
Good Luck!
Posted on Feb 04, 2009
Why the demand for fidget spinner raised?
These fidget toys have been developed in 1990, and now it has become a big trend.
The demand for these Fidget Spinner raised till 2017, due to its various health benefits. It provides relief from stress and many types of body pain.
It is also used in curing mental disorders like concentration problem, anxiety, ADHD, stress, autism, etc.
newbea-hand-spinner-tri-spinner-fidget-spinner-toy-stress-reducer-perfect-for-add-adhd-anxiety-and-autism-adult-children-0-2-tvoytpwmmbngoh4u0g2w5xcz-1-0.jpg
Jun 02, 2017 | The Computers & Internet
I have used my wii fit plus 3 times with no problem but yesterday i did body test then went training first few games were fine then it started saying my weight was a little different than before do i want...
Yes, it's completely normal. To avoid this, try to take the BMI test at the same time everyday. If you have a big meal in between the weights, it might say that.
Also, the batteries on the board may be running low. Try with some new ones and see if the problem persist.
Also, try keeping the Wii Balance board on a flat hard surface, such as the floor. Do not use it on thick carpets since it might report bad measurements.
Hope this helps.
Aug 26, 2010 | Nintendo Wii Fit Plus for Wii
My wii fit keeps say pleasae step off me and press a when i go to do the body test
Replace your Wii Fit Plus board and/or DVD disk. I had the same problem. The seller has gave me a new Wii Fit Plus set (instead of the 1st one), and everything was OK. I don't know if the problem was in the board or in the DVD disk.
Aug 14, 2010 | Video Game Consoles & Games
Keeps telling me I am fidgeting - tried everthing
Try borrowing a friends Wii balance board and connecting it to your own Wii then try. If it works fine it's a fault with your current wii balance board and you need to buy a replacement. If it still says your fidgeting I would get other individuals to try it, if it doesen't fidget for them it is you fidgeting. If it does say they are fidgeting & you already know your wii balance board is working the same as your friends then the surface your playing on is too un-even (probably too much of a balky carpet) or uneven floorboard/tile (whatever your floor material)
Hope this helps.
Apr 09, 2010 | Nintendo Wii Fit for Wii
Wii balance board won't register
Try putting on the extension feet then you should not have that problem.
- Make sure nothing is on it or under it that could mess with the sensors.
- If the problem persists your problem is the Wii board and it might need to be re-calibrated.
Mar 22, 2010 | Nintendo Wii Fit for Wii
Disc doesn't work when I change from body test to training on Wii
Wii Fit? The problem can be that your Wii is modded (IF ITS MODDED), or that the disc contains scratches.
Nov 21, 2009 | Nintendo Wii Console
I keep getting the message to "step off and press A" for the body test.
You need to step off the pad, wait until it tells you to step on. Then you push A to conduct the body test. If your pad is turned off push the button on the front of the wii fit pad then repeat the first steps i described.
Aug 03, 2009 | Nintendo Wii Fit for Wii
Wii Fit Doesn't work
Do not stand on the Wii fit board until it says to. The board needs to reset itself before any tests are completed. For best accuracy, complete all the initial tests and follow the instructions to the letter.
Feb 05, 2009 | Nintendo Wii Fit for Wii
I'm trying to go through the setup to WII fit. My child did the body test with no problems a couple of days ago. I keep getting an error (fidgeting) when I try to take the body test. Tried to do fit test...
Good Luck!
Jan 17, 2009 | Nintendo Wii Fit for Wii
Nintendo Wii Fit for Wii Logo
972 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
