Question about Kenmore 23822 Top Load Washer
Put a spin on it
Spin cycle does complete job of removing all water. realized machine was unlevel. leveled it, but did not fix problem. i'm sure it was unlevel for quite a few years. could it be the belt has stretched out and just needs to be replaced.
  • vincent styck Apr 30, 2007
    a misdiagnose. turns out, during the spin cycle, the motor runs but the tub does not spin. if you open and close the lid or start a new spin over, then it will spin. any ideas on what might be going on.
    President:
  • 878 Answers
Vzone, you don't have a belt on this model. After the agitation, the washer should go into a nuetral drain for about 90 seconds getting rid of most of the water before spinning. See if yours is doing this. If it doesn't, the gearcase lost it's nuetral drain. The gearcase has a five year warranty on it, part only. If it's ok, the next thing I would do is check the drain pump itself, see if it has a bunch of junk wrapped up in the impeller restricting the flow. The pump comes off easy. Two clips and two clamps. Check the photo, Catriver..post back.
Posted on Apr 29, 2007
  • 1 more comment
  • Ron Marek
    Ron Marek Apr 30, 2007
    OK, now it sounds more like the timer. The fact that you have to lift the lid to go into spin tells me that trans is not coming out of the nuetral drain. The trans will not come out of the nuetral drain unless the power is interupted. If the timer is not doing it, by you lifting the lid is doing it. Without being there and by your second post, I would be leaning more toward the timer. Catriver..post back.
  • Bob Henderson
    Bob Henderson Sep 14, 2012
    You have to take the gear case out and put it on a bench that has a vise. remove the case bolts, dump the oiil
  • Bob Henderson
    dump the oil...replace the nuetral drain kit, and the cam assy. only way to fix it...
Catriver, ordered part came in today. put it in, works like new. can't thank you enough. first time working on a washing machine, went smooth. thanks again.
Posted on May 03, 2007
  • Bob Henderson
    that's a one in a million. it's always been the gear case for me..but i will keep an eye out for that...thanks. Bob H
SOURCE:
Kenmore 70 series washer was in spin cycle when the clothes within caused it to become unleveled and it was rocking. I lifted the lid to adjust the clothes to level it and found that lifting the lid
sounds like you need to adjust the feet under machins a little .Lifting lid while runnning is supposed to stop the machine .ans adjusting the wet clothes is mfg suggested fix of unbalance .
Jan 06, 2015 | Kenmore Washing Machines
Top loading Kenmore h e washer roars while spinning
kind of hard to solve without more info.but it could be unlevel find a level or borrow one and place on top of washer.make sure it reads between bubble on level.check both sides on top of washer.if you hear kind of grinding noises and shifts hard it could be transmission..
May 26, 2014 | Kenmore 24032\24036 Top Load Washer
Thin twin washer basket is VERY off balance and once a cycle runs, there is water filling up under the washer / spin basket.
You should be able to put it in spin and remove the water. if it don't you have a problem somewhere. There should be 3 springs hooked to the bottom of the tub to hold it on center if one breaks or comes loose it will be off balance. If you get water in the tub when not useing it and the water is on from the water line the water valve is leaking.If the water don't shut off when filling the water level switch could be bad.or the tube running to it could be stopped up pull the hose off the water level switch and blow through it if it bubbles in the tub it is ok. If can't blow through it it is stopped up.Hope this helps
Mar 12, 2017 | Whirlpool LTE5243DQ Combination...
Water will not drain out of front Load Kenmore 44072
Kenmore front loading washing machines will give you years of service. Sometimes things do go wrong, especially after the warranty runs out. Troubleshooting a Kenmore front loading washing machine could save you a lot of money on a repair bill. Before you call a service technician to fix your machine, attempt to resolve the issue through simple fixes first.
Washer Code Messages Your Kenmore front loading washing machine has an LED display that will give you error codes.
Will Not Spin If your washing machine does not spin, check to make sure the door has latched completely. Also remember that if your machine is in the SUD cycle it will not spin until it has eliminated the suds.
Washer Is Noisy
  • If the washer is making noise or vibrating, check to make sure it is still level. If it is out of level you can change this by adjusting the feet. Metal belt buckles and buttons in your laundry could be causing the noise as well.
  • Door Stays Locked After Cycle
  • At the end of the wash cycle, the lock will disengage after about 30 seconds. If it does not, it may be because the machine still detects that the water has not completely drained. Just select "Drain" and "Spin" and let the washer go through the cycle. Your door should unlock.
Nov 03, 2011 | Washing Machines
Spin vefy fast
A rapid spin cycle is actually a GOOD thing. This is an indication that the gearcase (transmission) and the drive motor are both running strong.
If the washer shudders during the spin cycle the first thing you need to do is check to ensure the washer is properly leveled. The following link explains:
http://www.fixya.com/support/r3868923-level_whirlpool_top_loading_washer
The model Whirlpool top loader you have, has an auto-leveler mechanism on the back two legs that can become unlevel periodicailly. You should check the washer level from time to time when it is empty. You need to also make sure the washer is level in ALL directions (front-to-back and side-to-side).
Accidental unbalance problems that can occur from washing blankets, comforters, or heavy loads of towels can also cause the washer to become unlevel and shake. This can also contribute to the level mechanism becoming unbalanced.
Overloading the washer can also cause unbalance problems. Washing blankets or conforters can cause the load weight to shift to one side of the tub. This will result in a tub that shakes violently and bangs against the cabinet. You may have to redistribute the load weight when washing heavy items. This can also occur when washing loads of towels. This is NORMAL as some heavy items do not distribute the weight evenly.
Another problem (which is less common) that can contribute to wash unbalance problems is a weak floor under the washer. If the floor flexes (even the slightest) during the spin cycle, it can cause the washer to bounce or shake. Mobile homes or laundry rooms on the second floor of a home are notorious for having weaker floor structures. This washer has a 35 gallon tub capacity. Coupled with the weight of a wet load and the spinning action, this can put a lot of centrifugal force on a floor.
If you have any questions or concerns, please post back and let me know. I hope this information is helpful to you.
Apr 25, 2010 | Whirlpool LSR5132PQ Top Load Washer
Model p801 frontload, it walk all over when in
sounds like your machine is unlevel have you taken a level to the machine and the floor and checked both , they should never walk unless they are unlevel
Dec 30, 2009 | Washing Machines
Whirlpool washer lxr9245eq1 doesn't spin dry completely
Try this... while in in spin turn your spin selector switch and listen if motor spins slower or faster.. at fast spin open your lid quick to see how fast its spinning.. check and make sure your drain line is cleared and the water flow out fast...and if its spinning too slow problem is in the gearbox area..
Jan 03, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Beeping on spin cycle
It is most likely out of balance, could be for many reasons.
1 could be too many heavy items such as jeans, towels, etc in one load.
2 could be the machine or floor is unlevel.
3 Could be a balance sensor needs replacing.
Mar 09, 2008 | Bosch Nexxt 100 Series WFMC1001UC Front...
Unbalanced load cabrio top loader
being un-level could certainly cause it im currently working on this problem for another customer on this site while i haven't had hands on with this model yet i just finished reading the service manuel on it its kind of an amazing concept in washers if either one of you are on line reply to this message hold my rating for now as i need to ask some questions
Dec 23, 2007 | Whirlpool Cabrio WTW6600SBT Top Load...
Kenmore 23822 Top Load Washer Logo
105 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
