Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
F1 problem on Fischer and Paykel Dishwasher.
What is a F1 problem
  • wyang1 Jan 07, 2009
    My double drawer Fisher & Paykel keeps giving me F1 error at end of wash cycle, with upper drawer. Both drawers then beep alternately. Pressing power button does not erase problem.
  • 232 Answers
NO POWER TO LOWER DRAWER, CHECK POWER AT BOARD IN LOWER BACK CORNER BEHIND DRAWER,CHECK FOR BROKEN WIRE TO LOWER DRAWER,CAN ALSO BE THERMAL FUSE ON HEATER PLATE,COULD ALSO BE CONTROL BOARD IN LOWER DRAWER.GOOD LUCK there is a drawing taped inside behind the drawer. oops sorry about all caps prideapplianceser@sti.net
Posted on Jan 01, 2009
2 Suggested Answers
  • 30 Answers
SOURCE: RE: Fischer paykal F1 code
F1 fault means the flood switch on the base of the dishwashers has been activated.
nine times out of ten its the lid motors.
You can remove the two kick plates on the bottom of the dishwasher.
Dry out the water in the base with a sponge.
only one draw will be leaking water??
This allows you to use the second draw until a serviceman shows up.
Dry the base out A.S.A.P, because you have a electronic board that sits on the base. cheers
Posted on Aug 27, 2008
How do I replace the outlet hose?
The exact steps depend on the make (brand name) and model of your dishwasher, but in all cases, you will have to pull the dishwasher out from under the counter. If it's an "American" dishwasher (Whirlpool, Kenmore, KitchenAid, GE, Frigidaire, etc.), you will see the hose clamp that connects the drain hose to the dishwasher, and it will be easy to disconnect the hose from the dishwasher. But if you've got a "foreign" dishwasher (Samsung, LG, Bosch, Fischer-Paykel), replacement is much more difficult and should be left up to a professional dishwasher repairman.
May 15, 2015 | Dishwashers
Tip
How to take dishwashing liquid out of aid dispenser
I read a few tips on this site about the above problem.
Then rang Fischer and Paykel. My dishwasher is a two drawer.
They suggested using chux rolled up and pushing down aid dispenser.
After pulling out, throw out and keep doing this with a fresh rolled up piece of chux.
I did it about three times. Then I slowy poured some water in. Used fresh chux rolled up. Repeated the process a couple of times. Then repeated with dry chux, till it was all dry as much as possible. Then I poured half a cup of white vinegar onto the bottom of dishwasher and did a rinse cycle, checking for foam, every now and again.
The white vinegar stops the foam.
All seemed good.
Then I did an empty full wash "test". All good at the end. No froth at all during cycle.
After the "test" wash, I filled the aid dispenser with "rinse aid" not dishwashing liquid.
All up it took me about 20 minutes.
Thought I would pass on. And don't panic, (like I did). The woman at Fischer and Paykel was so helpful and said it is a common thing, so I didn't feel so bad.
on Nov 18, 2016 | Fisher and Paykel Dishwashers
Keep blowing fuses
This means there is water collected on the base of the dishwasher cabinet under the bottom drawer. You will need to disconnect the dishwasher mains plug and take the bottom drawer out to dry the base out. Follow instructions in this manual (page 7 step 2) to remove the drawer.
Fisher Paykel DishDrawer Installation Instructions ManualsOnline com
Jan 08, 2014 | Dishwashers
Fischer and paykel drawer dishwasher has no power to drawer, power at outlet, was flashing F1 prior to shutting down, thanks
If you have a double drawer unit then please confirm what is happening with the other drawer. Most likely the base of the dishwasher under the bottom drawer has flooded and brought down the power with it. The power board sits under the bottom drawer. BE CAREFUL NOT TO TOUCH THE DISHWASHER BEFORE SWITCHING OFF THE MAINS POWER SUPPLY TO THE DISHWASHER AS THE CIRCUIT MAY BE LIVE AND GIVE A SHOCK. You will have to take the bottom drawer out and see what is happening under it.
Jan 16, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
F1 code on my Fischer Paykal drawer dish washer . This is the flood sensor . It was. tripped when water was splashed in a plug that shares the same Circuit. How do I reset the sensor?
Not sure if the flood sensor will trip if the water is splashed into the mains plug. F1 can also occur if the power to the top drawer has failed. Flood sensor trips when water collects at the base of the dishwasher housing under the bottom drawer.
I think the problem you mention has caused the power to the top drawer to fail due to a spike when the splash on the power plug occured. This is very easy to see. Check if the display on top drawer is blank.
Nov 04, 2012 | Fisher and Paykel Dishwashers
Disher washer is giving a signal F1 for repairs Model DD603SS
F1 means flood. Below is a link to a video that will show you how to fix the issue if you want to download the video.
http://www.appliancerepairlesson.com/shop/dishwasher-videos/fisher-paykel-dishwasher-repair/
Good luck
Mar 01, 2011 | Fisher and Paykel DD24DCFX6 Dishwasher
F1 error code continuosly
here is a link to a downloadable repair video. This video explains how to repair a f1 error code and how to replace the rotor.
Mar 01, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Problems with fischer paykel self cleaning oven
Sounds like Clothes Washing Machine To Me!!--Methinks You have "Posted Incorrectly"--Stay Upright --Des.
Dec 15, 2008 | 2006 Fischer MRX 650
Hi and welcome to FixYA.com!
Here are links to the two most popular Fisher Paykel Wall Ovens:
OD/OS301:
http://www.fisherpaykelparts.net/partmanuals/545619C_Aerotech_UGM_USw1.pdf
OD/OS302:
http://fisherpaykelparts.net/partmanuals/599194C_Aerotech_ugm_USw.pdf
If neither od these is your model, let me know which one you have and I will locate a use and care guide for you.
Hope this helps and Happy Holidays from the FixYa crew!
Dec 15, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher Paykel F1 error / double dishwasher drawer
F1-water on bottom of dishwasher. Uselly it cost by broken drain hose. Need expert tech to fix the problem.
Dec 01, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
187 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Owen Barnes
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
