Question about Insignia Digital-to-Analog Converter for Analog TVs
Digital box for analog tv not working
I have an insignia digital conversion box and it is not working. I have the antenna wire from the tv goiong to the antena port on the box and the tv wire going to the tc on the box. I have my tv on channel 3. What am I not doing?
  • rosetesler Dec 29, 2008
    I forgot to say it is an older tv and does not have the 3 jacks, red, yellow, white on the back. I am using regular cables. It was working and now it won't. I just get snow. I use channel 3, but i've tried 4 also and that didn't work.
  • 905 Answers
If you have the coax cable connections correctly connected , coax out to tv from box and antenna hooked to antenna in on the box then you may have to connect the RCA jacks, yellow = video , red = right audio , white = left or mono audio
because on these boxes you can choose in the menu to have the coax ( channel 3 or 4 ) as the output or the rca jacks ( line out )as the output . so the menu may be set for the rca jack connections untill you change it in the menu
Posted on Dec 29, 2008
  • jason Dec 29, 2008
    so does that rating you gave me mean you no longer want my help?
    if the power is on the box and everthing is hooked up right then the box is faulty and you should return it for another one
The analog tv picks up a lot more stations and correct channels than the LED TV. Is it possible to set the Insignia LED NS-19E320A13 to analog? Is there a device available?
.YES IF ITS A DIGITAL TV U WILL GO TO MENU GO TO ANTENNA CHANGE FROM DIGITAL TO ANALOG OR AUTO ENTER THEN SEARCH ANOTHER WAY GET AN ANALOG TO DIGITAL SET TOP BOX FIX YA ANTENNA TO IT CONNECT TO TV BY HDMI.OR AV CABLES GET THE SET TOP. ON GO TO SCAN OR SEARCH AND YOU WILL HAVE ANALOG CHANNELS ON YOUR LED TV
Oct 08, 2015 | Insignia Televison & Video
All ready used box once. Now going back to antenna. Not receiving display or menu on T.V. screen.
All TV over the air is transmitted as a digital signal now. In order to see it on an older TV (read Analog), you must have a signal that you can receive(antenna hook up) and a digital to analog converter box. That box allows you to see your digital signal on older TVs. The signal is sent from the antenna to the box via a RF connection, and decoded to channel 3 or 4 (your choice). for further information see Consumer Report at:
http://www.consumerreports.org/cro/electronics-computers/tvs-services/non-digital-tvs/digital-converter-boxes/digital-tv-converter-boxes-first-look-3-08/overview/digital-tv-converter-boxes-first-look.htm
Jan 09, 2011 | Insignia Digital-to-Analog Converter for...
My Insignia Converter boxes - 7-19-09
Switch to a powered DTV antenna.
Your analog antenna may be too far out of range to effectively pick up signal.
Thanks for using FixYa!!
Jul 19, 2009 | Insignia Digital-to-Analog Converter for...
I still use my VCR to tape my favorite shows. How would that wor
what regular channels don't you get ?
to get the vcr to record the box you will need to either plug the box audio / video output jacks into the vcr audio / video input and antenna to tv OR plug RF antenna out of box to antenna in on the vcr and vcr antenna out to tv( or the video/audio out jacks on vcr to tv )
Jan 19, 2009 | Insignia Digital-to-Analog Converter for...
Do you need a special antenna to hook up a dtv digital to analog
You need a TV antenna, nothing special about it. Hook the antenna up to the converter box, the box up to the TV.
Jan 10, 2009 | Insignia Digital-to-Analog Converter for...
Insignia digital tv converter/indoor antenna no signal
Ok first I can save you some money. Take your "HDTV" antenna back. There is nothing different about the antennas needed receive analog and digital signals. If you got reception without your converter box, use the same antenna with your converter box.
Next let's see if there is a problem with the box. Hook up a television with the antenna. How many stations do you get? Now hook up the same television & antenna, but this time put the converter box between the antenna & the TV. Do not turn on the box. Now how many stations do you get? If the number is different, the box is not allowing the antenna signal to pass through. That is bad. You want your signal to pass through the box so you can still pick up stations that don't broadcast digitally. Some areas of the country will not be covered by digital stations from all major broadcasters when the changeover happens in Feb.
My suspicion is either you did not have the antenna hooked up to the converter box when you searched for channels OR you are in an area that is not yet broadcasting digitally.
I hope this helps you solve your problem. Thank you for using FixYa and feel free to add more questions here by using comments.
Jan 09, 2009 | Insignia Digital-to-Analog Converter for...
Hooking up converter box when i have a dvd player and direct tv
Hook your Insignia box between your antenna and your television. You still need the antenna.
Jan 01, 2009 | Insignia Digital-to-Analog Converter for...
Need to hook up dvd/vcr combo with converter box
Connect your rabbit ears to the Insignia. Connect the Insignia to the antenna input on the "cvd/vcr combo". Now turn on the television to show the "cvd/vcr combo".
The Insignia simply goes between your antenna and your television. In your case you also have a vcr so if you want the VCR to be able to play and record digital stations you will need the Insignia between the vcr and the antenna.
Dec 28, 2008 | Insignia Digital-to-Analog Converter for...
Installed Insignia box, keep getting No Signal
You need a stronger antenna. Many of the VHF channels moved over to UHF thus if your current antenna doesn't pick up UHF, you will not pick up those channels.
Dec 11, 2008 | Insignia Digital-to-Analog Converter for...
Insignia Digital-to-Analog Converter for Analog TVs Logo
234 people viewed this question
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
jason
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
