Question about Electrical Supplies
5500 watt yamaha gas generator
They gave me the wrong instruction manual with my generator
they gave me a honda one.
is there a website i can download the proper manual??
we have no power and im at work for 30 more minutes please contact me asap
  • Anonymous May 07, 2009
    Thanx heaps this was what i needed exactly cool
4 Suggested Answers
  • 5603 Answers
SOURCE: Honda motor runs fine but will not generate power
try this site:
http://www.endtimesreport.com/dead_gen.html
Posted on Nov 02, 2009
  • 80 Answers
SOURCE: Im wondering what kind of oil to put in my 5500
Use a good quality single weight oil 30w
Posted on Oct 19, 2010
  • 185 Answers
SOURCE: 5500 watt generator won't start.
With starting fluid, it runs, so this means spark and compression and valves closing properly. You mention gas flow, so gasolene is getting to the carb. This would then leave the problem being in the carb if indeed fuel is present at the carb. If you take apart the carb right now, is there fuel in the bowel? Or, remove the bottom screw on the carb, does gas flow out? Does it flow continuously or does it quit? This will indicate if the float valve is indeed opening. The only thing if you have fuel in the bowel and no start, even with the choke closed, is that the main jet must be plugged. Had the unit been sitting for quite a while with gasolene in it? Gas can "varnish" after a few months and this can cause plugging of the jets and other passages. How old is the gas in the unit? Old gas won't burn in the engine and this can also be a problem. Drain the tank, and carb, put some new gas in the unit and try it. You might have to take the carb apart again and use some carb cleaner to blow the **** out of all the carb passages. This should get it going again. Now, most important, when you get it running again, you need to adjust the engine speed so that you do not burn out any electrical equipment. If you have access to a frequency meter, plug it into the 120 volt outlet on the generator and adjust the speed so that the frequency with no load is 62 - 63 hz. This will allow the generator to drop to 60 hz under load. The adjustment is a 5/16 nut, right side of the upper engine, facing you.
Posted on Jan 31, 2011
Starter cord replacement of EF 1000IS Generator
Mentioned here and a general video
Search Results
Recoil Starter Assembly - Yamaha EF1000iS Service Manual [Page 39]
https://www.manualslib.com > ... > Inverter > EF1000iS > Service manual Yamaha EF1000iS Manual Online: Recoil Starter Assembly. ... RECOIL STARTER ASSEMBLY. 1. Install: 1. 2. Install: NOTE: Hook the edge of spiral spring to the ... Inverter Yamaha EF6300iSDE - 5500 Watt Inverter Generator Owner's Manual.
How To Replace Pull Start Cord on Honda eu2000i Generator ...
? 7:07
https://www.youtube.com/watch?v=5WAuEW8decY May 27, 2016 - Uploaded by Tula's Endless Summer
http://tulasendlesssummer.com Here is a short video on how to replace the pull cord on a Honda 2000 watt ...
Yamaha EF1000iS Service Manual Recoil Starter Assembly
May 20, 2018 | Garden
5500 watt generator will not run my 2hp air compressor
5500 watt generator will meet the 1491.4 watt requirement of the 2 hp compressor motor
given that 5500 watts generator is rated continuously at around 4500 watts and will handle spikes to the 5500 watts when electrical components start there should be plenty left
consider the possibility or a motor below full capacity, carby problem ( jets blocked , water, blocked air filter not getting full throttle from the governor lever, worn rings, type of fuel in use --E mix)
Nov 18, 2015 | Electrical Supplies
Service manual required
I can't find a free download on the internet, most are Owner's manuals or are not for the exact model you want - I don't know how similar similar models are. You might try the following:
http://cdn.powerequipment.honda.com/pe/pdf/manuals/00X31Z376011.pdf (from Honda, EU7000is owner's)
Honda EU7000i Model Info Super Quiet 7000 Watt Inverter Generator Honda...
This is the shop manual for the EU6500is model ($44)
Honda EU6500is Generator Shop Manual
owner's for the EU6500is
http://www.freeproductmanual.com/honda-eu6500is-manual
Finally a link to the search results most of the were taken from
https://uk.search.yahoo.com/search;_ylt=A9mSs2tVBShVngQA_xZLBQx.;_ylc=X1MDMjExNDcxNzAwMwRfcgMyBGZyA2FsdGF2aXN0YQRncHJpZANyOTBfV1hQeVNvT0twcW5oS3NxWlFBBG5fcnNsdAMwBG5fc3VnZwM0BG9yaWdpbgN1ay5zZWFyY2gueWFob28uY29tBHBvcwMwBHBxc3RyAwRwcXN0cmwDBHFzdHJsAzMwBHF1ZXJ5A0hvbmRhIEVVNjUwMGlzQSBzZXJ2aWNlIG1hbnVhbAR0X3N0bXADMTQyODY4NjQ3NQ--?p=Honda+EU6500isA+service+manual&fr2=sb-top-uk.search&fr=altavista
You could try contacting Honda (relevant division) also; if they will provide the manual you want, it might be free
10.April.2015
Apr 10, 2015 | Honda EU6500isA - 5500 Watt Electric Start...
Onan marquis gold gas generator 5500 stops running after 5 minutes
Check fuel pump pressure, how long has it sat. What load is on after it stops?
Jun 10, 2014 | Onan Marquis Gold Quiet Gas Generator 5500...
Looking for a manual for a pow'r gard 7500 watt generator
Go to the HONDA website and probably get one to download on line!
Dec 24, 2012 | Electrical Supplies
Had to tickle the throttle on my yamaha 3500 watt
You should have automatic or manual choke control. Try to find it and open it during start. After that you can close it if stable work is achieved.
May 30, 2010 | Yamaha 4500 Watt Electric Start Generator...
VALSI 5,500 WATT GENERATOR WILL NOT START
All generators need to be run once a month. All things from the tank to the and including the carb will get gummed up with dried out fuel. I have a whole house generator and a 5500 watt gen set on my motor home. I keep fresh fuel in the stand alone house generator in California in case of a bad earthquake. I drain the gas after every run and keep all vehicles full of fuel just in case. Run gen sets at least once a month or pay pay pay!!
Apr 05, 2009 | Watts Onan Portable Generator - 4000 ,...
Electrical Supplies Logo
244 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
