Question about Rowenta Perfect Iron
Soleplate is dirty
I tried ironing my son's red flannel pajamas and I burned holes in them. Now, the bottom of my Powerglide 2 has red fuzzes. How do I clean it?
Rowent sells a hot iron cleaning kit. It comes with a tube of cleaner, a piece of white terry cloth and a piece of cotton flannel. You spred some of the cleaner on the terry and iron it. Melted fabric and other grim clean right off the iron. Then you polish it up on the flannel. Good luck!
Posted on Mar 29, 2009
My steampress 660 is has black stuff coming out
Hi Beverly. The "dried stuff" is scale which occurs naturally in tap water. You should always use DISTILLED water - buy litre bottles (approx.$2.ea Home Brand) all supermarkets. Electricity off, empty out all the water in your iron. Half fill with distilled water, cover the filling hole, and shake water inside iron side to side, up and down, vigorously, empty distilled water out and watch carefully to see if water runs clear or has sediment coming out - may need to repeat this action. When water runs clear re-fill iron as normal with distilled water. Put iron on lowest STEAM setting, LIFT up iron but with soleplate facing down onto an old rag/towel (brown water may come out) press steam button on & off to try & clear the holes. Turn iron off, allow to cool. Thick cloth wipe soleplate over getting into the holes if they have not cleared. Triple wrap a wooden skewer in cloth soaked in white viegar or "scale remover" and circulate it around the blocked holes. Go very carefully do not scratch the coating on the soleplate or holes - very important. Let us all know how this goes please and if I have been of help, do hope so. Good luck, Chris
Feb 12, 2015 | Irons
Floor steamer not getting hot
follow this steps and fix it.
GOD BLESS YOU
Clean an iron:
  1. Unplug the iron and make sure it is cool before cleaning.
  2. Use a toothpick or pipe cleaner to remove buildup in the steam vents, making sure the debris doesn't fall into the vents.
  3. Use a fine sewing needle to carefully clean the spray nozzle of mineral deposits.
  4. To flush sediment from a steam iron, pour 1/2 cup water and 1/2 cup vinegar into the water tank. Place the iron on a rack over a broiling pan and set the iron to steam until the tank runs dry. Repeat if necessary. Or follow the instructions for using a commercial iron cleaner.
Service the steam and spray mechanism:
  1. Unplug the iron.
  2. Use a fine sewing needle to unclog the steam valve assembly. Also, check the valve spring and replace it if it is broken or has lost tension.
  3. If the spray pump is accessible, remove it and check for leaks by placing the spray tube in water and squirting the pump. Clean or replace as needed.
Clean a metal soleplate:
  1. Unplug the iron.
  2. Use a sponge and commercial soleplate cleaner or baking soda and water to remove dirt buildup on the soleplate. Rinse well with water and dry. Don't use harsh abrasives or immerse an electric iron in water.
  3. Use very fine steel wool (0000) or an emery cloth to remove scratches and burns on the soleplate, then clean the soleplate.
Sep 30, 2013 | Conair Compact Garment Steamer Iron
Steam iron turns itself from hot temperature to cool
1) test the electronic control for defective and follow the next steps. God bless you
Clean an iron:
  1. Unplug the iron.
  1. Unplug the iron.
Jun 11, 2013 | Irons
Water is leaking out of the bottom of my philli[s GC 9240
see the next steps and fix it. God bless you
Clean an iron:
  1. Unplug the iron.
  1. Unplug the iron.
Nov 14, 2012 | Irons
When I iron my white sheets dirty water comes out and my sheets are dirty
follow the steps and fix it. God bless you
Clean an iron:
  1. Unplug the iron.
  1. Unplug the iron.
Oct 01, 2012 | Tefal Pro Express GV 8120 Iron
Rowenta Effective
The rust spot are probably caused by iron in your tap water. I would suggest you put a solution of half vinegar and half water into the water chamber and leave in the iron overnight.
Then switch it on to steam and holding the iron over the sink or over an old towel, the dirt (residue) comes out of the holes on the soleplate. Sometimes if the iron is badly scaled you might need to repeat the descaling.
Once complete, fill again with clean water and steam away, to flush any of the remaining vinegar out of the iron.
Depending on how often you use your iron and how much iron is in your water, you might consider performing this flush process every 2 or 3 months. It will help extend the life of your iron.
Another option is to use distilled water in your iron. Distilled water has all the minerals removed.
Good Luck!
Aug 11, 2008 | Rowenta Powerglide DM273 Iron
Rowenta Perfect Iron Logo
173 people viewed this question
Top Rowenta Irons Experts
Henry  Thomas
Henry Thomas
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
