Question about Thomson 24WK25U 24" TV
Line down center of screen rest of screen black
RCA model X25103SG can only see a very thin picture down the middle of the screen. The rest of the screen is totally black. Is it fatal?
    President:
  • 3,130 Answers
No not fatal, but sick. this problem you are having sounds like you have a vertical sweep problem.. It could be the vertical output IC, the sweep power supply or a capacitor or two is bad. If you have printed circuit board soldering experience, you can try and fix this yourself, but if you do not, play it safe and call in a pro to assist you in this repair as it should not cost more then 100 bucks to repair. Good Luck
Posted on Apr 29, 2007
Sinotec PHD-50HU31. First, thin line running vertically down the center of the screen. Now, only a 2cm wide horisontal line appears at the top of the screen. Rest of screen is black.
If you wish to get more details visit the site linked here. Line faults to many popular brand sets are given with illustrations. You can get an idea about the fault. http://electronicshelponline.blogspot.com/
Feb 10, 2017 | Televison & Video
What can be done to repair picture to my TV
Vertical scan output section circuit should be checked. Contact any service technician.
Aug 30, 2014 | Toshiba CF32H40 32" TV
Thin red line, green line and yellow line going across the screen
the problem is vertical collapse,i am not so sure you can trouble shoot this on your own but you can send the board to eithor pts electronics or tristate module for repair
to get a price get the number off the sticker--left hand board(looking from the back) it will start CTC195---- write down entire number before you call them
Sep 02, 2009 | RCA P52926 52" Rear Projection Television
Line across middle of screen, rest of screen black
The problelm is a defective vertical deflection system. Could be the amplifier, vertical output driver or whole printed board that supports the vertical deflection activity. It is considered to be a serious failure.
The cost of repair will be around $200 to $300.
Aug 05, 2009 | Hitachi 50UX58B 50" Rear Projection...
Screen is black except for thin line in middle of screen
The problem is in the vertical section of the main board. Bad capacitors and maybe the vertical IC. If you are not inclined to be a tech you will have to take it to a shop.. I don't know what they may charge but I normally get $69- $89
Apr 10, 2009 | Mitsubishi CS-27205 TV
I have a sharp aquos 52" with a thin vertical red line in center
If you have a thin line running down the screen, you may be looking at a service issue right off of the bat. Here is a few things I want you to try before calling sharp, 1. Reset the unit from the setup menu
2. Unplug the unit for 2 minutes then plug back in. If that does not work. Take digital pictures of the line and call sharp immediately. Make sure you tell the rep you want to sign up for the aquos advantage program that they have(extends your warranty 3 months free of charge!) because that will get you priority service on with your issue. If they cant resolve that line ,9 times out of 10 they will replace the unit. hope this helps you
Feb 15, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
10 yr old emerson tv
The problem you are having is a vertical deflection problem. The screen is being compressed to a thin white line. It's probably a defective vertical output module or transistor. This part is not too expensive. Less likely would be a vertical deflection coil, which would be more expensive because its usually glued to the picture tube and harder to replace. You'll need to take your set to service center to have it serviced.
Good Luck!
- Jim
Feb 08, 2008 | Televison & Video
Thin Red Lines on Top of Screen
Sorry, that is common for generic replacement xformers for
your make / model . There are some adjustments to minimize
the effect in servicer menu...............you can try turning down the
screen control a bit....................T.
Dec 21, 2007 | RCA F36650 36" TV
Thomson 24WK25U 24" TV Logo
91 people viewed this question
Top Thomson Televison & Video Experts
Are you a Thomson Televison and Video Expert? Answer questions, earn points and help others
