Question about HP Pavilion dv6000z Notebook
Trust webcam with yahoo messenger
I just got a trust webcam and i try for 2 weeks now to make it work with yahoo messenger. What can i do?
  • tat4u
    tat4u May 11, 2010
    not giving us much info there but you need sp2 at least to use messenger for voip and video
  • allyssa_depp May 11, 2010
    Well, what is the product number?
Yahoo messenger cant read my built in webcam.
Hi Morgan,
Please first check whether your webcam works as stand alone device or not( by stand alone i mean whether it works without yahoo msgr or not)
After that check whther your webcam works with other messengers like SKYPE and GOOLE TALK messengers or not.
Most probably you may need the Webcam driver softwarefor your acer, for that you can contact Acer.Acer technical support number is 1-800-816-2237 and they are open 7 days a week on central time. Weeks days they close at 9.00pm central time, and weekends they close at 5.00pm central time.
if the problem is not with acer then you can try the following ;
http://help.yahoo.com/l/us/yahoo/messenger/contactus/index.html?pir=e2joXBJibUnk6jXe6wzjjnga5jNcGq_12_JHeiEXsOOZfKQrR1xJNE0dgpH_eXxa4yAU7tlNumGE_pGddjWK0BPqfjftGw--
This is my best effort to provide you the solution, so please rate me accordinly.
Good luck :-)
May 05, 2010 | Acer Tablets & eReaders
My laptop HP Pavilion dv6565us, suddenly webcam stopped working, it says web cam not connected recently i down loaded yahoo messenger 10
Your downloaded file of Yahoo Messenger 10 could have a virus on it which tells the computer something in the port you are using is not connected. Try a different usb port on your computer, Or your webcam could've just died. My webcam died after 1 week of use.(Labtec webcam) I would suggest trying different ports, Un-installing and re-installing, or purchase of a new webcam
Hope this helps. Please don't forget to rate. Thanks ^^
Feb 24, 2010 | HP Pavilion dv9000z Notebook
WEBCAM NOT WORKING WITH YAHOO MESSENGER
try to go to yahoo messenger and then preferences and look for the camera source, make sure that the camera source is your webcam if its not choose it, try it and then tell me if it wont work.
Jun 02, 2009 | Logitech 961462-0403 Webcam
My webcam works on msn messenger but not yahoo messenger. It is a HP webcam. Is there a compatibility issue? Should I change my webcam?
No there is no compatibility issue. But you cannot use cams simultaneously on 2 messenger. Make sure that when you using it in Yahoo messenger than msn is totally shut off. Try this it should help you.
If my advice helps you, than please feel free to rate me.
Thanks
Mar 22, 2009 | Logitech Webcam
Webcam not working..says not found!
solution 1: reinstall your yahoo messenger
solution 2: reinstall your web cam driver again.
Jan 19, 2009 | Acer Aspire 5500 5570-2609 Laptop
Won't work on yahoo
Yes, just make sure its only Yahoo since you can't use your webcam on multiple applications at the same time. Only 1 at a time.
Try this and tell me what will happen..
1. Open your main Yahoo Messenger window
2. Click on Messenger on the Menu bar and click Preferences
3. Go to Webcam option and click Camera Source
4. Check if your webcam is listed - if it is, make sure its the one selected
Then try to check if you can start your webcam on YM. Goodluck!
Nov 07, 2008 | Microsoft LifeCam VX-6000 Webcam
Yahoo messenger - Webcam is not connected
You cannot access camera source until the webcam is running in Messenger - try setting it up from scratch
1) The webcam is working outside of Messenger
2) Reboot webcam by unplugging the USB connection and inserting it again - its important if its been used elsewhere and prior to chat.
BODY,.aolmailheader {font-size:10pt; color:black; font-family:Arial;} a.aolmailheader:link {color:blue; text-decoration:underline; font-weight:normal;} a.aolmailheader:visited {color:magenta; text-decoration:underline; font-weight:normal;} a.aolmailheader:active {color:blue; text-decoration:underline; font-weight:normal;} a.aolmailheader:hover {color:blue; text-decoration:underline; font-weight:normal;} YAHOO SPECIFICATION
To find out what the requirements are for messenger webcams, check out the following.
http://help.yahoo.com/l/us/yahoo/messenger/messenger9/webcam/mstacamreq.html
Once you have your webcam working outside of Yahoo Messenger you have to configure it to messenger CONNECTION
Open messenger - on top toolbar > messenger > preferences > connection - select 'no proxies' or 'connect direct to the internet' depending on the version of messenger you have
make sure your internet connection and country are correct in the 2 lower boxes > apply > ok TESTING
> messenger > my webcam - warning panel will come on click 'ok' and your webcam will launch. DEFAULT
With webcam still running > Messenger > Preferences > Webcam > Camera Source - set your webcam as default using dropbox. > Camera Settings - adjust settings to suit. > Apply > OK PERMISSION OPTIONS
>messenger > preferences > webcam - make your selections about who you will allow to view you
IN USE Your contacts may need to configure their connection the same as above or they may also get a "webcam not connected" message
Jun 16, 2008 | Logitech QuickCam Express Web Camera
Logitech QuickCam Pro for Notebooks
Bob P,
I have Logitech Quick Cam STX not exactly what you have but I think close. I got it to work with Messenger. I have made it through the installation. Not sure what I did to make it work.
I would assume it can be done. If you think it would help to compare our settings some how or for me to help in some other way please let me know. I will be online lots during the day next week as I am not working next week.
Good luck.
Dec 06, 2007 | Logitech Webcam
My cam wont work on messenger.
YAHOO Problem Hi, 1. Verify your internet connection. If it is possible change your DNS IP Address. 2. Try Updating your yahoo messenger >> http://messenger.yahoo.com/download.php Hope this helps
Sep 14, 2007 | Labtec Webcam Pro
HP Pavilion dv6000z Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
