Question about HP LaserJet P2015 Printer
Laserjet p2015dn i am trying to set it up and i can not find the password to access the config menu
    Novelist:
  • 102 Answers
Hi in LJ P2015 there is no way to set-up password.
Press and hold download green button for 6 to 7 seconds(Not more than 7 seconds) and release it will print self test configuration page on third page netwrok configuration page three is a option called IP Address put that IP Address in the browser it will open printer page and you will be able to browse the printer.
Posted on Jul 04, 2009
    Habit-Forming:
  • 71 Answers
P2015 Cold reset procedure
A cold reset changes most system parameters in NVRAM to the factory defaults. However, unlike NVRAM initialization, a cold reset does not reset the page count, the paper tray sizes, language, or formatter number.
NOTE:
A cold reset also resets all the HP Jetdirect settings as well as the printer settings.
1. Turn off the printer
2. Press and hold the GO button.
3. Turn the printer on, and continue to hold the GO button for at least 5 seconds, but no longer than 15 seconds. During this process, the Attention LED turns on.
4. Release the GO button.
Reconfig network card with DHCP server.
Posted on Oct 07, 2009
I need to secure my gigaset 504 AGU, i put password on my router wifi but still i have a Enabled 50 clients,on my wireless network
you have put password for accessing your router( system config menu/router config menu) but not client WEP password, the router is still open access point( AP). configure a WEP key and then each/any of the client need to know this key/password to access internet via your router. good luck
Aug 14, 2011 | Computers & Internet
Tip
LOOP MOBILE GPRS settings for 6600, 3650, 3230, 3250, 6680, 6681, 6630, 5700,...
Tools > Settings > Connections > Access point > Option > New access point
Use default settings LOOPGPRS: Connection name Loopgprs Data bearer: gprs / packet data Access point: www User Name: blank Prompt password No Password: blank Authetication: normal Homepage: http://www.loopmobile.in Press ok
Press 1 time back button u will get Loopgprs BROWSER CONFIG:- come back to main menu In main menu Go to the web/services click option & select settings you will get general, in general you will get access point, in access point you have to select loopgprs as default. Now just directly got to main menu you will get web or services.
Try to browse any site.
on Sep 02, 2009 | Nokia 9500 Communicator
How can i configure the IP for the printer HP laserJet P2015dn? what is the address that I can access this printer from my PC via web brower?
For configuring the IP address on the printer, you will have to browse the printer menu, and the IP or TCP/IP should be under Network. Here is basic information about troubleshooting network issues from HP website.
Once you have set up an IP address to your printer you will be able to connect from PC via the web browser by typing in the IP address of the printer.
Dec 15, 2010 | HP LaserJet P2015dn Printer
My HP LaserJet P2015 Printer will not print. One icon is lighted up, the broken circle.
If that's the only lite on, and it is on solid. It means the printer is ready, but no job activity. Press and hold the GO button for 5 seconds. It should print a CONFIG page. Press and release the GO button and a DEMO page will print. If both of those print, the printer is good. You might have a bad cable. Look at the CONFIG page to make sure the printer has the correct address
May 06, 2010 | HP LaserJet P2015dn Printer
I changed the IP address range of my LAN and need to assign the new range of addresses to my HP printer P2015dn
Press the Menu button on the printer to open the printer’s menu and enable the Network Card – these print servers use a static IP address therefore, configure the IP address of the network card so it matches the IP range of your network. Eg. If your IP's are 192.168.0.xxx then set the network card to a high number say 100. (This is to prevent a conflict with the router issuing the same IP address to a computer on your network).
Then set the Subnet Mask IP address to 255.255.255.0
Jan 13, 2010 | HP LaserJet P2015dn Printer
Trying to setup tcp/ip settings on my hp laserjet 8150 series printer
First, make sure your Network Interface is working properly. Print a test-page. Menu--->Information------->Print configuration-page. If your machine print only one page, your interface doesn't work right. If your machine prints a configpage and a seperate network-page, you're good to go.
The easiest way is to look at the network-page and see if the machine already got a ip-adress. If it already got a ip-adress (DHCP), type that adress into your favorite web browser and do your config from the machine's web-interface.
Or you can access the printers menu.
Menu---->I/U---->EIOx settings---->TCP/IP----> and set your settings as you wish. Good luck.
Dec 14, 2009 | HP LaserJet 8150dn Printer
Where do I change the IP/Gateway/Subnet on HP LaserJet 4000
You can set these on the printer using the EIO menu.
Press menu until EIO menu appears.
press item
Config network NO should show. press value YES should show.
press select.
Press item until config tcp/ip NO shows, press value Yes press select.
This should get you into the tcp/ip menu.
use item, value and select keys to navigate to the setting you want to change.
hope this helps
Mar 24, 2009 | HP LaserJet 4000 Printer
Not Printing Lines
I would print out CONFIG pages from both printers and compare setups.
Hold down Green Button for 5 seconds
Feb 17, 2009 | HP LaserJet P2015dn Printer
Need to increase memory for HP LaserJet P2015dn
hold down go button until light blinks & if the memory amount is below 128 you can add a stick in the side slot.
Jan 16, 2009 | HP LaserJet P2015dn Printer
HP LaserJet P2015 Printer Logo
1,076 people viewed this question
Seeker5211
Seeker5211
