Question about Activision Call of Duty 2 for Windows
Call of Duty : Dark screen in single mood
I have tryed everting to check up all setting and nothing is wrong..
Only it takes long time to startup the program and it get dark screen and around 30 sek u can here the sound okay too
best regards
Mogens
  • MICHIKO17 Apr 13, 2009
    AFTER DOWN LOADING PROGRAM WHEN I HIT PLAY GAME THE SCREEN GOES BLACK THE MUSIC PLAY. BUT HE SCREEN REMINDS BLACK.
  • 22 Answers
Try to press the windows button and go to the desktop. if no response try ctrl+alt+del, if it works go back in the game and it should work.
If nothing works or responses try set your computer hibernation mode and start it up again and that should most defenantly work. have the same prob on my laptop and the last example works every time.
Posted on Jan 06, 2009
I was welding and it quit feeding the wire now I don't hear relay clicker nothing when I pull the triggerwhat could be wrong
first thing to check is the over load reset button as all welders have a duty cycle for welding if that period is exceeded , the machine shuts down until it is cooled down
the duty cycle is the time of welding allowed in relation to the amps required to weld
for example with a 200 amp welder set at 200 amps with a 20% duty cycle for every 20 minutes of welding you have to allow 80 minutes to cool down
if however you have a 200 amp welder with a 20%duty cycle but it is welding at 20 amps then the duty cycle is extended dramatically other than that check for a fuse or take it in for a service
Dec 15, 2015 | Welding Tools
I have a new tablet, charged and protected but when I was changing contrast settings it went black and I cant get the screen to come back on past startup
Sorry about this.
Well, seeing it is a new tablet, either of two things can be done.
Your tab is booting beyond Startup but you ain't seeing it because of the contrast/black screen setting.
To confirm; step into a dark room/space and hold a flashlight very close to the screen, you'd see your tab is at its home screen already.
Anyway, you will have to default factory reset it as it is or you could attempt to navigate (while in the dark room/space and using/holding the flashlight) Swipe to open/unlock it----Settings----display and brighteness-----brightness----'move cursor up to increase brightness'. Done.
Second option with dark room/space is tedious and strenuous.
Factory/hard reset is an easy option to try.
At the same time, hold/press both the volume up key/button and the power button/key.
Follow the system prompt afterwards.
Or
Press/hold down the volume down button/key and the power button.
Follow the system prompt thereafter to factory/hard reset your tab.
Best of luck.
Oct 10, 2017 | Umi PIPO S1 Android 4.1 Dual Core 7 Inch...
The pictures I take with my Nikon D100 come out really dark. It's dark when looking through the viewfinder as well. What do you think is causing this to happen?
First thing to check is the shutter control or maybe what speed your shutter is on. Check your settings and you'll probably find something is switched to the wrong setting. Try switching everything to Auto, including anything menu operated your manual should explain how to get to your on-screen menu. Try that and if no good, post back and we can take it from there.
With cameras getting more compact and buttons getting closer together and smaller it's very easy to knock a switch the wrong way without realising it.
Apr 14, 2010 | Nikon D100 Digital Camera
CMOS settings on startup
If u mean by the internal battery ..the icon battery which placed on the mainboard .. so u just need to prss F2 to adjust the current date and time .. and to get stable Download the bios update from fujitsu.com .
good luck
Nov 10, 2009 | Fujitsu Siemens AMILO D-7830 Notebook
Playstation network for online play wont load
It should work after a long time if you traded because the settings are different on different disks
Apr 07, 2009 | Sony Playstation 3 (PS3) Console
Call of Duty : Dark screen in single mod
your computer configuration does not meet the game requirements or your computer needs to be defragmented
Dec 29, 2008 | Activision Call of Duty 2 for Windows
My acer laptop screen keeps going dark because the rubber sensor in corner is sticking. lapttop thinks its closed. how do i loosen it? i've tried closing it many times but still goes dark after a minute.
if u have the mai problem as ur screen closing from time to time
why dont u adjust the power properties and change the settings to screen never close?????????????
or the setting "do nothing"
Oct 10, 2008 | Computers & Internet
White Screen
  1. Upon startup lens emerges but when screen appears it is white whereas it normally displays whatever the lens sees. When the shutter button is pressed the camera will focus and take a white picture which can be deleted. The camera does not flash although flash is set to automatic and photo taken in a dark room. Camera flashes (weakly) with flash set to manual on. Lens is unobstructed and appears to be perfectly normal. Camera was not dropped. Batteries have been changed.
Jan 19, 2008 | Pentax Optio E10 Digital Camera
Activision Call of Duty 2 for Windows Logo
337 people viewed this question
Top Activision Video Game Consoles & Games Experts
dj ese
Level 1 Expert
Zhenya Ogorodnikov
James Wishart
Are you an Activision Video Game Console and Game Expert? Answer questions, earn points and help others
