Question about Frigidaire GLTF2940ES Front Load Washer
Washer Froze, Spin Cycle Sounds like Jet Engine
I purchased a model LTF2140ES0 Frigidaire front-loading washing machine in 4/2005. I moved this fall and a few days ago my washer froze, then thawed, cracking my solenoid and flooding my enclosed porch and basement. I have replaced the solenoid and the machine operates fine except the spin cycle now sounds like it's being broadcast through a cranky megaphone. It seems to spin fine, although my husband seems to think it is not spinning as fast. We took the back off and it seems like the noise is coming from the motor. Should I replace the motor or does something else scream out at you guys? Thanks for your help.
  • 179 Answers
When it goes into a high spin does it sound like a freight train in your house if so your bearings are going bad
Posted on Dec 29, 2008
I have frigidaire washing machine that will spin after the wash cycle . The water stays in the machine and the machine cuts off . what is causing this ?
Restrictions in the drain. The washer has a filter in the rubber line that is hooked to the wash tub to the drain pump.
Feb 29, 2016 | Frigidaire Washing Machines
Fridgidaire front-loading washing machine model # LTF2140ES0 will not spin
Good Afternoon Friend,
I understand that your Frigidaire washer, model# LTF2140ES0, will not spin. To try and resolve your washer not spinning, please try the following:
    1)Check your washer door and make sure it is completely closed.
    2)Check your dispenser drawer and make sure it is completely closed.
    3)Your load might be too small. Add 1 or 2 similar items to help balance the load.
    If the above does not work, I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Turn the power back on and try any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully.
    -Best Regards-
    WP
Jun 20, 2014 | Frigidaire Washing Machines
Tub inside washer froze up with ice. how do i thaw it out correctly and is there anything i need to check before starting it up again?
warm the room up where the washer is located ,let it thaw out by itself ,it should be ok ,if yuou get a leak a hose may have split
Jan 16, 2013 | Frigidaire ATF6000ES Front Load Washer
My front load machine sounds like a jet engine with mtal tools clanging in it durning the spin cycle
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Jun 29, 2011 | Frigidaire ATF6000ES Front Load Washer
How do you replace the door switch on Frigidaire ltf2140es0 front load washer?
You will need to remove the wire ring on the door seal and carefully peal back the seal to reach your hand in to hold the door switch as you remove the 2 screws. Then pull it out and unplug wires one at a time and plug into the new one. This is a easy DIY and only takes about 15 minutes.Here is a link that should help Door switch replacement
Feb 05, 2011 | Frigidaire ATF6000ES Front Load Washer
Our front load washer had standing water in the bottom of the barrel. The repair man over the phone said it sounded like the drain was clogged. He initially couldnt find a clog anywhere and had to take...
The washtub suspension allows it to move but when overloaded it will move rather more than it is designed for and could open a gap between the washtub and the door large enough to allow items to slip through.
The suspension is carefully designed to absorb the out of balance forces, with which the washer would be noisy and tend to "walk" around the kitchen. These days consumers demand smoother and quieter performance from their washers and so it is increasingly important not to overload them.
A friend called out the service engineer to his new washer that he had been operating just like his old one. The engineer began by plugging in a laptop and looking accusingly at him said he had overloaded his new machine nine times in the few weeks since it was delivered. Guessing is no longer an acceptable method of loading the washing machine...
Mar 23, 2017 | Frigidaire ATF6000ES Front Load Washer
The drum is loose when the washing machine is not in use. When it's in use it makes a loud whirring noise like a train going through my house. This happens on an empty load as well. The machine is a front...
Check out this tip I wrote about the noise and vibration that front load washers can make..
heatman101
Aug 29, 2010 | Frigidaire GLTF1670A Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
293 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
