Question about Cavs JB199-250GB Karaoke jukebox & Digital Recording. Build-in 250GB hard Drive.
Cavs 199 will not power up
I checked the power cord an power outlet and all is working. i also pushed the reset button on the back side and nothing seems to work. HELP!!!!
I have a News Years Gig and need ut bad. Thanks
2 Suggested Answers
SOURCE: jb199 doesnt display welcome page,I push the power..
Pull cover off box and remove battery (small toward the front of the machine) This will reset the Bios.. after that when restarting go into the bios by pressing the "Delete" Key and hit load failsafe bios. this should fix everything.
Posted on Aug 04, 2010
How to turn on
-Make sure power cord is plug very good into the printer.
-Make sure Plug to outlet and make sure there is power there.
Try again.
Good luck
Mai
Dec 05, 2017 | HP Computers & Internet
My food disposer has no sound I need help. Could you help me?
If you open the cabinet door under the sink, you should be able to see the disposer motor. On the bottom or side, there should be a small bump that is the reset button. Push the button in and it should work again.
If it still does not work, make sure that the power cord is plugged into the outlet.
Still not working? Check the fusebox for a blown fuse or tripped circuit breaker.
One last idea: if the outlet that the disposal is plugged into is a GFCI protected plug, there will be a TEST and RESET button in the center of the outlet. Unplug the disposal cord, press the RESET button on the outlet, then plug the disposal cord back in.
Aug 31, 2015 | Food Mixers
Is there a fuse on model no jvm1540dn1ww
There should not be a fuse on your washer- what is usually the problem here you have a reset button the power cord- also be sure to check if you are plugged to a GFI circuit-
if this is the case unplug the power cord-
reset the GFI outlet (wall plug)-
plug your power cord back into wall-
and push in the reset button-
TY,
perrytradesman
Aug 13, 2014 | Karcher 2500 PSI Pressure Washer
Power does not turn on when i push the power button
first make sure there is power to the outlet if it is agfi outlet push the reset button if it clicks its working but inany case plug something in to the same prongs that you know works(eg; lamp,radio,etc to make sure it is working. If it doesn't work go to the circuit breaker and look for a breaker that is not in the on position and turn it off the turn it on to reset it. If the outlet works,check the power cord for cuts fraying or any signs of damage and replace it if it is damaged. if the cord looks fine, check tho door switch(usually a pressure switch that must be fully depressed for the machine to start working. also is ther a power light on the unit? is it a top load or front load? what brand and model # is it?
Jan 09, 2012 | GE WCVH6260FWW
My wife pushed the ice dispencer then power went out tried plugging into other outlets yet nothing
Do the other outlets you plugged it into have power and something else plugged into them work such as a toaster /blender ect?? if all outlets in kitchen out their probably is a GFCI type outlet that has the reset button on it. Sometimes their in the kitchen or depending how the house was wired when built they could be in a bathroom or even garage. One outlet has that reset button but could have up to 6 outlets wired to it
Aug 16, 2011 | LG LSC26905TT Side by Side Refrigerator
I press the power button but the machine does nothing. It's pluged in and the lcd lights up
  1. Unplug the power cord from the electrical outlet.
  2. Plug another appliance into the electrical outlet to make sure the outlet works.
    • If the electrical outlet does not work , plug the product into another outlet that does work.
    • If the electrical outlet works, but the product still does not turn on , continue to the next step.
    • The power module has a safety feature inside that protects the product during a power surge. If you experienced a recent power surge, the power module might need to be reset. Use the following steps to reset the power module.
      1. Unplug the power supply from the rear of the product.
      2. Unplug the power cord from the electrical outlet, power strip, or surge protector.
      3. If the product uses a power module with a detachable power cord, disconnect the cord from the power module.
      4. Wait 15 seconds.
      5. Reconnect the power cord to the power module.
      6. Plug the power cord back into the electrical outlet. Do not use a power strip or surge protector.
      7. Check to see if the power module has an LED.
        • If the power module does not have an LED, continue to the next step.
        • If the power module has an LED, check to see if the LED lights up.
          • If the LED does not light up, contact HP to replace the power module. To buy a compatible power module, right-click the following link, How to Buy HP , and then click Open in New Window .
          • If the LED lights up, continue to the next step.
      Step two: Test the power on the All-in-One Follow these steps to test the power on the product.
      1. Reconnect the power supply to the rear of the product.
      2. Press and quickly release the Power button (c01602202.gif ) to start a Power On/Off cycle. Do not hold the button down. Figure 1: Press and quickly release the Power buttonc01896071.gif c01733891.gif If you press and hold the Power button too long, the product might turn on and then off without restarting. If this happens, press and quickly release the Power button (c01602202.gif ) again.
      • If these steps resolved the issue , there is no need to continue troubleshooting.
      • If the issue persists , see the next step.
      Solution four: Test the power with a compatible power cord from a different product If you have another available power cord that is compatible with your product, use the alternate cord to repeat the steps in Solution three: Reset the power module and test the power .
      • If the product turns on with the alternate power cord, the original power cord caused the issue. Contact HP to replace the power cord. Right-click the following link, How to Buy HP , to buy a compatible power cord.
      • If the product does not turn on with the alternate power cord, continue to the next step.
      Solution five: Service the HP product If you have completed all the steps listed above and are still experiencing a problem, service the product.
Jan 17, 2011 | HP PSC 2355 All-In-One InkJet Printer
Nothing happens when push start button. power cord etc good ??? is this a power unit failure?
make sure the outlet is recieving power
unplug the tower from the outlet & then replug it in & see what happens
make sure all cords are plugged in correctly in the back of the tower
then if nothing happens after you push the start button, power supply & cord could be bad
the same thing happened to my daughter's pc & had to replace power supply & shorted out the motherboard
Nov 18, 2010 | HP Compaq Presario SR2050NX PC Desktop
Looking for a component diagram for cavs jb199
I can only find the user manual. I can also find a little commentary from another website. Perhaps the manufacturer can be of assistance. Or someone in the Cavs forum (listed at the top of the website page) can be of assistance.
http://www.cavsusa.com/
http://www.cavsusa.com/JB-199/JB199_Manual_080514.pdf
Cavs JB 199 II Premier Public Forums Karaoke Discussions Karaoke Scene...
Jan 11, 2018 | Cavs JB199-250GB Karaoke jukebox & Digital...
Jb199 doesnt display welcome page,I push the power knobe but it doesnt response the thing is that cavs shows me thepower is on and thats all   next step is wellcoming  but it doesnt go further     ...
Jun 01, 2009 | Cavs JB199-160GB Karaoke jukebox & Digital...
Dryer shut off towels were not yet dry, turned dial to restart dryer acts as if it isn't getting power I closed door and pushed start button. Nothing! Checked breakers and power cord at outlet all checked...
Hello mdonettaYou said,
Dryer shut off towels were not yet dry, turned dial to restart dryer acts as if it isn't getting power I closed door and pushed start button. Nothing! Checked breakers and power cord at outlet all checked okay. Any ideas.
yes, try unplugging the power cord or turning off the breaker for 5 minutes. Either will due. Some times the system needs to be reset!
If this does not work there are internal fuses that can be replaced!
Let me know how it goes!
Huuum
Sep 19, 2008 | Dryers
Cavs JB199-250GB Karaoke jukebox & Digital Recording. Build-in 250GB hard Drive. Logo
Top Cavs Audio Players & Recorders Experts
janman
da surgen
Don A
Don A
Are you a Cavs Audio Player and Recorder Expert? Answer questions, earn points and help others
