Question about Vacuums
DC07 DYSON REPLACEMENT HOSE. HOW DO YOU REMOVE IT FROM THE HANDLE. I have a kenmore whispertone 8540 canister vaccum. The electrical wires (3) to power the beater are embedded in the hose, in a spiral fashion. The yokes that hold the hose on both ends (and attach to the beater on one end and the unit on the other) have no screws or pressure latches; i don't want to use brute force as i may damage the attachment device inside the yoke. If someone can tell me the trick to get these yokes off each end, i can take it from there. thks. nelson in toronto.
  • 125 Answers
Should be a pry off dot on the underside revealing a screw
Posted on Dec 30, 2008
How to replace the cord in dyson's dc07
Things You Will Need
  • Dyson DC07 power cord
  • T15 Torx-bit screwdriver
  • Small can
  • Camera or cell phone with camera
  • Flat-head screwdriver, 3/4-inch or smaller
  • Needle-nose pliers
  • Do detach the black wire that goes to the motor as it does not require removal.
  • Do not work on the power cord when it is plugged in.
  • Do not force the plastic-covered connectors from the switch or you could break the male ends. Pull them off firmly but gently to avoid breaking the terminals.
  • Do not apply too much force to the plastic arms that hold the housing in place. The plastic arms are fragile and may break easily.
1 - Unwrap the power cord from the Dyson DC07. Detach the handle of the vacuum cleaner by pressing the release button. Pull the handle from the hose. Slide the hose down the wand and push the button at the bottom to release the hose from the machine.
2 - Press the button at the top of the dust bin handle to remove the canister bin assembly from the Dyson DC07.
3 - Lay the machine on with its back with the power switch facing upward. Locate the Torx screw directly beneath the switch actuator. Remove the Torx screw, turning it counterclockwise. Place the screw into a small can so you do not lose it.
4 - Remove the switch box housing held in place by the Torx screw just removed. Carefully pry upward on the two plastic arms that clip the housing in place. Take a picture with your cellphone or camera of the open housing to make it easier to reinstall the wires where they belong in the channels and spaces provided.
5 - Center the needle-nose pliers on the female connectors from the power cord attached to the switch. Apply equal force to pull them from the male ends of the switch. Also detach the two wires that connect together within the housing, identified by the clear plastic connector between them. Depending on your machine\'s manufacture date, the wires might have different colors. For example, they may be white and brown, all white or one could be blue. Disconnect a total of four wires -- two from the switch and the two connected together. Leave the other wires alone.
6 - Trace the electrical cord on the machine until you reach its protective cover where it enters the Dyson DC07. Lift up the cord protector to remove it from the vacuum. The cord protector has slotted sides that fit within the plastic. Slide the cord protector from the power cord.
7 - Remove the plastic covers that protect the female ends on the power-cord wires that connect to the switch. The new power cord does not come with these. Insert the tip of the flat-head screwdriver through the top of the plastic connector with two internal ridges. Lift upward and away to pull the wire free from the connector. Repeat for the other wire. Push the female end into the plastic connector until it snaps into place. Repeat for the other power-cord wire.
8 - Thread the new power cord through the cord protector. If you have trouble pushing the wires through, reach in with the needle-nose pliers to pull both wires through the rubber protector.
9 - Reconnect the two separated wires back together by inserting the male end into the female end of the other wire. Reconnect the two wires from the power cord to the switch. Reinstall the switch housing on the machine. Align the wires in the channels provided to keep them from being pinched or pulled out when you reassemble the housing. Look at the photo you took earlier as a guide, if necessary. Insert the wire that goes to the motor in this channel and the white wires connected together to the left of the switch in the area provided.
10 - Put on the switch housing cover and secure it with the screw you removed earlier. Reassemble the vacuum in the reverse order you dismantled it.
Aug 27, 2014 | Dyson DC-O7 Bagless Upright Cyclonic...
Where is the filter
Dyson put filters in three locations. 1) Remove the canister, there should be a release clip in the front above the handle, this allows the top to tip backwards. 2) On the left side, at the main unit is a round cover with thumb release, this pulls straight out. These are cleanable filters, RINSE ONLY no soap!!
3) Under the canister is a filter, the cover has 3 clips which need to be pried gently to open the cover. This is a hepa filter and cannot be cleaned, it must be replaced.
Nov 09, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Was using kenmore whispertone stopped suddenly disconnected brush unit will not switch on ????
if you took the hose out of the wand assembly then it may not turn on as the hose handle has a power button on it and must be connected to turn on the unit.Also check the powerhead for a reset button (small red / or black button on the back of the head){back of head not the bottom}
Oct 05, 2010 | Kenmore 23313 Whispertone Bagged Canister...
How do you remove the electrical cord for a dyson
remove the cover right above the canister. there is a couple of screws in the front holding it in. i think they are T15 torx. that will give you access to your switches and your cord
Jan 02, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Motor goes on and off briefly at regular intervals
Sounds like you may have a bad or loose connection, could be one of wires in the hose to the handle harness or the harness itself may be causing the problem. Also be the motor or relay causing a problem.
Jan 08, 2009 | Kenmore 23313 Whispertone Bagged Canister...
Dyson DC07 vacuum.
you have to remove the hose and wand then you can get to the clip that holds the canister on the machine and with a screw driver gently prise it of the machine
Aug 30, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Replace Kenmore Vacuum Hose
check out this solution
Jun 07, 2007 | Kenmore 23313 Whispertone Bagged Canister...
Vacuums Logo
101 people viewed this question
Top Vacuums Experts
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
